XtremeSystems Forums
Reply
Old 09-25-2009, 03:10 AM   #1
nhenhophach
Xtreme Cruncher
nhenhophach's Avatar
Send a message via MSN to nhenhophach Send a message via Yahoo to nhenhophach Send a message via Skype™ to nhenhophach
DDC led mod.[Updated]
You know, XSPC made the top for Laing DDC, it have 2 holes to insert the led. But i don't like that way, so many wires around the DCC
I will show you my idea.
XSPC top
You see all DDC have this 4 holes
Take it apart
3mm led can fit in those holes
Insert leds from the top & solder them together, use 12v from DDC board
I added a 100ohm registor, just for safety. you can see a bit of it
these thin wires from a fdd cable
Finish, tidy & neat
__________________
Are you overclocker? Your PC fast? Join WCG to help community
Big thank to: heater918, DDT, Movieman, Mad mikee
Special thank to Centon
nhenhophach is offline   Reply With Quote
Old 09-25-2009, 03:17 AM   #2
GregSG
Any internal pics for the wiring?
GregSG is offline   Reply With Quote
Old 09-25-2009, 05:43 AM   #3
meanmoe
very nice...
how difficult was it to solder the leds together? And where on the board did you connect them?
meanmoe is offline   Reply With Quote
Old 09-25-2009, 05:47 AM   #4
Demthios
Demthios's Avatar
Yeah some pics of where to solder them would be great!
Demthios is offline   Reply With Quote
Old 09-25-2009, 06:46 AM   #5
jim0ne
Nice work... pic on wiring please.
jim0ne is offline   Reply With Quote
Old 09-25-2009, 08:34 AM   #6
bh3000
nice and creative !!!
bh3000 is offline   Reply With Quote
Old 09-25-2009, 02:44 PM   #7
Spawn-Inc
Spawn-Inc's Avatar
just tie into the 12v line and ground where the stock wires are soldered on
__________________
CPU: Core2Quad q6600 G0 3.5GHz@1.4v (highest so far 4.2GHz)
GPU: XFX 9800GTX @ 850/1230
Ram: Samsung 4GB (4x1GB) 700MHz PC5300
Mobo: EVGA-NF68-A1 680i (P32)
PSU: Enermax Galaxy 850Watt DxX
HDD:WD5001AALS, ST3250410AS, ST3500410AS, ST3500320AS - 1.75TB
DVD: LG H26N,LG GH20LS10 both sata
LCD: Samsung 32" LN32A450, Samsung 226BW 22" wide
Sound: Logtiech Z 5500/Razor Barracuda HP-1 / AC-1
CPU & GPU: 3x Swiftech MCR320, 2x MCP655, MCW60 R2, Dtek Fuzion V2, 18 high speed yates @ 5v
3Dmark06:17,814 AquaMark:190,865
Spawn-Inc is offline   Reply With Quote
Old 09-25-2009, 03:20 PM   #8
NaeKuh
Post Soapbox Destruction
NaeKuh's Avatar
LOL you never fail to amaze me with your crazy mods...
Those dont look like 12V LED's...
i think he has them wired up in serial.
__________________
Nadeshiko: *Undergoing Rebuild*
Haruhi: i7 975 12GB DDR3 eVGA Classified *Haruhi -> Nadeshiko*
Lind: Dual Gainestown 3.07
NaeKuh is offline   Reply With Quote
Old 09-25-2009, 03:24 PM   #9
SNiiPE_DoGG
Permanently > 50ºC
SNiiPE_DoGG's Avatar
Send a message via AIM to SNiiPE_DoGG Send a message via MSN to SNiiPE_DoGG Send a message via Skype™ to SNiiPE_DoGG
great stuff! an excellent idea
__________________
Project
SNiiPE_DoGG is offline   Reply With Quote
Old 09-26-2009, 02:31 AM   #10
nhenhophach
Xtreme Cruncher
Updated
__________________
Old 09-26-2009, 03:04 AM   #11
Utnorris
Utnorris's Avatar
Looks awesome.
__________________
CPUID http://valid.canardpc.com/show_oc.php?id=484051
http://valid.canardpc.com/show_oc.php?id=554982
New DO Stepping http://valid.canardpc.com/show_oc.php?id=555012
4.8Ghz - http://valid.canardpc.com/show_oc.php?id=794165
Mountain Mod UF2O
I7 920 (3849B018)/Blood Rage/ XFX HD5870/ 6Gb (3x2Gb) OCZ 1866 Ram @ 1600 6-6-6-16-1t timings / Inte M-25 80Gb SSD x 2 RAID 0
W/C System
(CPU) Phase (GPU) EK Water Block and Water Chiller / B*P/Koolance Compression Fittings.
Utnorris is offline   Reply With Quote
Old 09-26-2009, 03:32 AM   #12
kamieldehond
looks very nice
__________________
e8500 c0 - 4275MHz - 1,344 vCore
DFI UT P45-T2RS
4x1gb D9GMH
Ati HD4870
Modded HAF 932
Watercooled:
Heatkiller v3.0 cu - D-tek Fuzion GFX 2 - PA120.1 - PA120.2 - PA120.4
kamieldehond is offline   Reply With Quote
Old 09-26-2009, 03:49 AM   #13
LogAn'sRun
LogAn'sRun's Avatar
great idea, but that means it's always on right? No stealth mode?
__________________
They say the definition of madness is doing the same thing and expecting a different result.
Howlin' Pelle Almqvist
Project Log Completed: v1000 - very first mod
LogAn'sRun is offline   Reply With Quote
Old 09-26-2009, 03:54 AM   #14
Malik[A]
Malik[A]'s Avatar
Send a message via MSN to Malik[A] Send a message via Skype™ to Malik[A]
If think u always can do your own switch on and off for LED's only
__________________
Build in progress :
Case - CM Cosmos S
Mobo - EVGA X58 Classified E759 w/c EK full block
CPU - i7 975 w/c with Watercool HK Rev. 3
RAM - Corsair Dominator GT DDR3 3x 2GB 2000MHz CL8 Core i7
GPU - EVGA GTX285 Tri-SLI, w/c with EK blocks
PSU - Corsair 1000HXEU
parts completing
Turn of my robotic brain. All my thoughts are all the same.. all insane..
Malik[A] is offline   Reply With Quote
Old 09-26-2009, 04:03 AM   #15
nhenhophach
Xtreme Cruncher
there re plenty space around the base, just add a switch next to the registor
[finding tiny switch.....]
__________________
Old 09-26-2009, 04:13 AM   #16
giorgioprimo
Xtreme Legend
giorgioprimo's Avatar
can you show were you put the resistor and how did you wire it ?
__________________
Sorry for my bad english, I'm from italy
giorgioprimo is offline   Reply With Quote
Old 09-26-2009, 05:00 AM   #17
malkiewicz
malkiewicz's Avatar
Nice work....
__________________
BenQ FP241W Black 24" LCD
Lain-Li PC v1200 Plus II Case w/ Window
EVGA x58 Classified Bios 000
i7-920 @ 4.2GHz - 1.352v Temps (23C-54C)
Windows 7 64 Bit
6GB Muskin DDR3 2000 (PC3 16000) @ 8-8-7-24 1T - 1.65v
EVGA 8800 Ultra x2 "OC" w/ Danger Den Water Block Temps (35C-54C)
EK-Supreme / 2 Alphacool Laing DDC-Pump Ultras + Extras
Power Supply / Crosair 1000HX
Seagate ST3500631NS 500GB x 3
Crosair SSD 128GB x 2
malkiewicz is offline   Reply With Quote
Old 09-26-2009, 06:51 AM   #18
Diverge
Diverge's Avatar
Looks like he has them wired in series, so if/when 1 led burns out, they all don't light. Not that leds burn out often, but good to remember for those folks that don't know basic series, parallel circuits
Also, if you have 1 led wired the wrong polarity, they all won't light. so something to remember if anyone does this and ends up troubleshooting.
__________________
[DFI LP Jr P45-T2RS] [Q6600] [8GB G.Skill F2-8000CL5D] [Seasonic S12 600W] [Windows Server 2008 (64bit)] [ATI 1800XL]
[DFI JR X58-T3H6] [i7 920 D0 3849A866] [12GB OCZ OCZ3B2000C9LV6GK] [Corsair CMPSU-750TX] [Windows 7 (64bit)] [EVGA 280 GTX][OCZ Vertex 30GB x3 Raid0]
Diverge is offline   Reply With Quote
Old 09-26-2009, 10:06 AM   #19
NaeKuh
NaeKuh's Avatar
Originally Posted by nhenhophach View Post
Updated
awesome..
u did wire them up serial like i guessed.
nhenhophach: you should of done it in the dark UV.
dont think he needs one.
He has 4 wired in serial... so each is getting a respected 3V from a 12V source.
Those LED's definitely look like 3V led's.
ahhh yes...
Thinking of Xmas already are we?
But its really easy to tell which is the cat and anode on a LED.
So after you position it, it should be easy to solder and wire.
__________________
Old 09-26-2009, 02:36 PM   #20
Zeus
Xtreme kickass
Zeus's Avatar
Send a message via ICQ to Zeus
Sexy! I like it!
__________________
Asus Rampage Extreme | E8600 Q822A435 | 2x1GB CSX Diablo D9GTR | ATI HD4870 | Silverstone DA800 | Samsung F1 1TB
Watercooling: Dtek FuZion v1 | EK 4800 series fullcover | EK NB S-Max | PA120.2 & PA120.3 | DDC2+ Delrin top | EK 200mm res | Tygon R3400 3/8 tubing
Case: Murdermodded TJ-07
sub 9 sec. SPi1M
Zeus is offline   Reply With Quote
Old 09-26-2009, 03:08 PM   #21
Vapor
Admin
Vapor's Avatar
IIRC, all diodes require some form of current limiting resistors, LEDs included.
Get a LED with a barrier voltage of less than 3V and hook it up to a pair of AAA batteries, it goes pop!
EDIT: and I'm pretty sure diodes cannot act as resistors.
__________________
Current Waterblock Testing
Roundup #2: Overall Comparison Thread, Alphacool Livingstone, Alphacool Niagara, Alphacool Yellowstone, D-Tek Fuzion V2, EK Supreme, EK Supreme LT, Enzotech Sapphire Rev A., Heatkiller 3.0 LC, Heatkiller 3.0 LT, Koolance CPU-345, Koolance CPU-350, Phobya, Swiftech Apogee GTZ, Swiftech Apogee GTZ SE, Swiftech Apogee XT
Vapor is offline   Reply With Quote
Old 09-26-2009, 03:34 PM   #22
NaMcO
NaMcO's Avatar
There is a voltage drop in each LED, it's ok to use them like that Vapor.
__________________
ASUS Rampage 2 Extreme · GTX295 SLI 1792MB · Core i7 920 4.2GHz · PCPower & Cooling 750W · SupremeFX X-Fi
6GB GSKill Trident PC3-16000 · NEC DVDR · Intel SSD & Samsung HD103SJ RAID0 · CM Storm Sniper · Samsung 24"
NaMcO is offline   Reply With Quote
Old 09-26-2009, 03:57 PM   #23
Vapor
Admin
Vapor's Avatar
Unless LEDs are coming with inline resistors now, I really don't think so...
http://led.linear1.org/why-do-i-need...r-with-an-led/
Nhenhophach is using a resistor (100ohm), fwiw.
__________________
Old 09-26-2009, 04:22 PM   #24
AndrewZorn
Xτræmε ÇruñcheΓ
AndrewZorn's Avatar
i dont see why it would be any different than any other device that follows the voltage adding rule
__________________
ABANDON THE MODERN WARFARE 2 BOYCOTT.
Infinity Ward has promised revolutionary Mouse Control™ and Graphical Settings™ in the PC version of COD:MW2. Nothing more to complain about.
AndrewZorn is offline   Reply With Quote
Old 09-27-2009, 08:29 PM   #25
@29psx
you can see a bit of it in this pic
1 end solder to the 12v point directly, 1 end to the thin wire & come back to the led
i bend it over so it would fit in the space near the ddc's wire located
edit the pic for better view
@29psx is offline   Reply With Quote
Reply
Thread Tools
Rate This Thread:
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
Powered by vBulletin® Version 3.7.0
Copyright ©2000 - 2009, Jelsoft Enterprises Ltd.
XtremeSystems
