XtremeSystems Forums
Go Back   XtremeSystems Forums > Cooling > Vapor Phase Change Cooling
Reply
Old 09-25-2009, 01:55 AM   #1
clear cmos
clear cmos's Avatar
Send a message via ICQ to clear cmos Send a message via AIM to clear cmos Send a message via MSN to clear cmos Send a message via Yahoo to clear cmos Send a message via Skype™ to clear cmos
Question [Help] TXV & CPEV sugestion
hi all i want to rebuild my old cascade, i changed refrigerant, evap, SLHX, Inter Stage HX, add one more stage and replace the captube into TXV (1 stage & 2nd stage) also change captube into CPEV (last stage)
Compressors :
2KS224 1.5hp (1st stage)
2KS224 1.5hp (2nd stage)
2PS156 1hp (3rd stage)
Refrigerants :
SuvaŽ 410A or SuvaŽ 507 on 1st stage
certainly r1150 on 2nd stage
mixture R1150, R14, R50 & R740 on 3rd stage
please give suggestions TXV brand and type for 1st & 2nd stage are also brand and type of CPEV for 3rd stage, waiting for advice from all
__________________
my English is very
clear cmos is offline   Reply With Quote
Old 09-25-2009, 07:58 AM   #2
clear cmos
clear cmos's Avatar
somebody can help me?
__________________
my English is very
Old 09-25-2009, 08:44 AM   #3
sdumper
-100c club
sdumper's Avatar
How did you replace captube into a TXV?
__________________
http://valid.canardpc.com/show_oc.php?id=606830
Seller/Buyer Reputation:
Heatware: http://www.heatware.com/eval.php?id=50905
Ebay: {Family Account} Kasyg3 http://myworld.ebay.com/kasyg3/
Ebay: {My personal Account} Sdumper http://myworld.ebay.com/sdumper/
iTrader: http://www.blazingpc.com/forum/itrader.php?u=28
sdumper is offline   Reply With Quote
Old 09-25-2009, 09:01 AM   #4
clear cmos
clear cmos's Avatar
just vacuuming, disassembled and brazed some replacement parts
therefore I need your advice, the right ev for my phase change systems
__________________
my English is very
Old 09-25-2009, 10:09 AM   #5
bazx
-100c Club Member
bazx's Avatar
for first stage use the danfoss tes2 works with 507/404 i would stay away from 410a unless you have very good condensing on the first stage
there is only one txv that would be any good but its for r23(danfoss teb2) on second stage that you can buy in a shop
to make one work with 1150 you will need to change the gas in the txv bulb to 1150
i get my cpevs from piotres
http://www.xtremesystems.org/FORUMS/member.php?u=15509
__________________
1. The first rule of Bench Club is, you do not talk about Bench Club
2. The second rule of Bench Club is, you do not talk about Bench Club
3. If someone says stop, goes limp, taps out, the the benching is over
4. No bummers in the batcave, apart from unkie dave
5. One Bench at a time
6. No air, no water
7. Benching will go on as long as they have to
8. If this is your first night at Bench Club, you have to Bench
bazx is offline   Reply With Quote
Old 09-25-2009, 04:42 PM   #6
piotres
-100c Club Member
piotres's Avatar
Send a message via ICQ to piotres Send a message via MSN to piotres
As bazx said .
IMO :
1st stage : Dafoss TS2 or TES2 plus 01 or 02 orifice (01 rather) plus R507
2nd stage : Danfoss TEB2 if You can use R23 there
3rd stage : I have no idea, I only have experience with Fach CPEV.
Regards
piotres is offline   Reply With Quote
Old 09-25-2009, 08:57 PM   #7
clear cmos
clear cmos's Avatar
thanx bazx and pete, i'll try looking in the local store today
__________________
my English is very
Reply
Thread Tools
Rate This Thread:
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
Powered by vBulletin® Version 3.7.0
Copyright ©2000 - 2009, Jelsoft Enterprises Ltd.
XtremeSystems
