XtremeSystems Forums
Reply
Old 09-25-2009, 01:32 AM   #1
TheBlueChanell
TheBlueChanell's Avatar
Just Received my RX360. Questions about the loop.
The rad arrived today from performance-pcs. I was curious if there's anything that should be done to "prep" it before installing it into my case? I think I read somewhere that you should wash it out with water.
This is going to be my first loop and I've still got a couple of questions. I've decided I like the look of compression fittings so I'm probably going to use them but I wasn't sure how that would effect my tubing choice. I have read it's best to use 1/2" barbs with 7/16" tubing for a tighter fit does that also apply to compressions?
Can I mix and match barbs/compressions with out hindering the flow of the loop? I would like to use barbs for the rad and the pump.
I saw a valve on here that stops flow, if I were to put one near my pump should I put it before the inlet or after the outlet and what else would I need to make draining the loop easier and more efficient?
I'm going to be using the Noiseblocker Silent Fans but I'm unsure of which speed I should use. I know the RX360 is best suited to low speed fans but should I be looking at the 1000RPM or 1500RPM model?
-Matt
__________________
Lian Li v1010 - MSI GD70 - X4 965 @ 3.8 1.4v / NB 2.6ghz 1.25v - 4gb OCZ DDR3 1333 6-6-6-24 1.65v - 5870 1050/1300 1.25v - 120gb Agility - 1TB Caviar Black - X-Fi Forte - Corsair HX850
LC loop soon. Have: RX360, HK3.0 Lt, Micro Res v2, Primoflex Pro 7/16 ID, Watercool DDC Top. Need: DDC 3.25, Fans and Fittings.
TheBlueChanell is offline   Reply With Quote
Old 09-25-2009, 02:46 AM   #2
Russ_64
Xtreme Cruncher
Russ_64's Avatar
Some good info in this post - http://www.xtremesystems.org/forums/....php?p=3979499
__________________
Mars: DFI DK X58-T3eH6 (11/05) : Core i7 920 D0 3850A795 @ 3600 (180x20) 1.18v : 6Gb OCZ Reaper DDR3 @ 1800
2x Gainward GTX260 (216) SLI : 80Gb G2 SSD & 160Gb HDD : DVDRW : PCP&C Silencer 750w 60A : CM Cosmos S
EK Supreme LT, EK-NB, EK-FC260, XSPC RS360+RS120, MCP355 XSPCv3, Bay Res, Windows 7 x64 nv195.39
Saturn: DFI DK 790FXB-M2RSH (8/20) : Phenom II 940 Black 0850CPBW @ 3400 (17x200) 1.42v
4Gb OCZ Reaper DDR2 @ 1066 : HD4890 & HD4870 : 160Gb HDD & 2Tb RAID0 : DVDRW : PCP&C Silencer 750w 60A
CM Stacker: DangerDen MC-TDX, EK-NB, EK-FC4800, XSPC RX240+RX120, MCP655 EK X-TOP, Bay Res, Windows 7 Cat9.9
Acer X222w, Edimax 4-port KVM, DS209j 2Tb NAS, Belkin UPS
Russ_64 is offline   Reply With Quote
Old 09-25-2009, 05:14 AM   #3
century child
century child's Avatar
You should prep the rad by flushling it several times with hot water, leaving the water in the rad for a while then covering the holes and shaking it thorougly before draining and repeating. One or two final flushes with distilled water to finish off for good measure.
If you go with compressions, make sure to get the exact size to match your tubing. Too small or large and will have problems tightening them down.
Mixing and matching barbs and compressions is no problem at all.
Where you put the stop valve is completely up to you. Just place it where it is the most easily accessible. Good planning here will save you a lot of work when it comes time to drain the loop.
My opinion on fans is get the highest speed fans for the model you have decided on. If they are too loud for you then you can dial them down a bit with a fan controller. If you get slower fans from the beginning but aren't happy with the performance, you can't make them go faster, you have to replace them.
__________________
"The state must declare the child to be the most precious treasure of the people. As long as the government is perceived as working for the benefit of the children, the people will happily endure almost any curtailment of liberty and almost any deprivation." - Adolph Hitler (Mein Kampf) and most likely Jack Thompson's inspiration.
century child is offline   Reply With Quote
Old 09-25-2009, 11:33 PM   #4
TheBlueChanell
Alright thanks for the tips. I'm stoked to get everything up and running. I haven't had a desktop since I sold off my p45 setup last year.
__________________
Old 09-26-2009, 04:55 AM   #5
shazza
Xtreme Fan
shazza's Avatar
Looks like you got your questions answered, Blue Channel. Good to see you are excited about building your water cooling setup. Hope you start a work log on your project - I've found it's a great way to get feedback and get questions answered on your specific build. Good luck with your project!
__________________
MM#2 : EVGA X58 | i7 920 | Vista 64-bit | Liquid Cooling | Corsair HX1000W PSU | EVGA GTX 285 Tri-SLI | 3x2GB Corsair 12800| WD 750GB | Mountain Mods UFO-CYO
i7 920 on Air : P6T Deluxe | i7 920 | Noctua NH-U12P SE1366 HSF | Vista 64-bit | Corsair HX1000W PSU | GTX 260 (55nm) x 2 | 3x2GB G-Skill PC3 12800| WD 750GB | Maxtor 500GB | Lian Li PC-A20
shazza is online now   Reply With Quote
Old 09-26-2009, 06:15 PM   #6
TheBlueChanell
Thank you. I actually pulled my v1010 apart awhile ago and began painting the inside and prepping the case for the loop. It was actually my first time sitting down and using power tools for something other than little stuff. It was a learning experience and I did make a lot of mistakes but that's okay. I will post some pictures over the course of the next few weeks after I get things up and running. The pc is probably going to be ran off my desk and out of a case for a couple weeks. It's going to take me a few pay periods to catch up with the cost off all this stuff but that'll give me some time to see what I can do on air and learn the ropes of the Ph2 and the board. I haven't had a new AMD system in almost 2 years. I'm excited now, more than ever, to be back with the green team.
__________________
Reply
Thread Tools
Rate This Thread:
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
Powered by vBulletin® Version 3.7.0
Copyright ©2000 - 2009, Jelsoft Enterprises Ltd.
XtremeSystems
