XtremeSystems Forums
Reply
Old 09-24-2009, 10:26 PM   #1
mav2000
mav2000's Avatar
HAF 922 - what size radiator
Hi,
Just wanted to check if anyone has done a liquid build with a HAF 922, and what size radiator fits on the top, without any changes or mods. Also which fans, as I would guess low profile fans would probably have to be used.
__________________
AMD Phenom II 965 BE - 4 cores @ 4 Ghz:
Thermolab baram with 2X GT's:
MSI GD70 @ 1.5b4
OCZ Platinum AMD Edition @ 1333 6-6-5-18:
Sapphire Vapor X 4870 @ 820/1125:
OCZ Modextreme 700W PSU
mav2000 is offline   Reply With Quote
Old 09-24-2009, 10:33 PM   #2
triggs75
triggs75's Avatar
I am in the middle of Wc'ing my HAF 922, look at my thread to see what I am able to put in without modding my case.
Here
This is with the Evga X58 motherboard.
Hope thats helps some
Chad
__________________
Components;
»HAF 922
»CPU: Intel Core i7 940 OC'd to 3.69
»Motherboard: Evga X58
»EVGA GeForce GTX 295
»CORSAIR DOMINATOR 6GB (3x2GB)
»WD VelociRaptor 600 (2x300) Raid 0
»WD Black 1TB (2x1TB) Raid 1
»LG DVD SATA Model
»CORSAIR 850W
»Creative Sound Blaster X-Fi 7.1
»Win7 Pro 64
»Dell 2707WFP
Water cool parts;
»RAD - XSPC RS360 & XSPC RS120
»CPU Block - Alphacool H14 Yellowstone BRB
»Black Feeser mosfet block
»Koolance MB-EVX58
»EK-Multioption RES 150
»Swiftech MCP655™ Series 12 VDC Water Pump
»Koolance-D5 X-TOP
triggs75 is offline   Reply With Quote
Old 09-25-2009, 12:14 AM   #3
mav2000
mav2000's Avatar
Thanks man...bu basically would a swiftech 240 fit uptop without needing to drill holes and stuff, or would some amount of modding be required? I see you are going for a 360..
__________________
MSI GD70 @ 1.5b4
Old 09-25-2009, 09:07 AM   #4
triggs75
triggs75's Avatar
I believe the swiftech and the XSPC RS RADS are about the same height for the 240's and 360's, the 360 is just longer. So you will be fine with the length, that is not the problem.
The concern is the height. With my XSPC RS RAD, I could not fit 25mm fans to it as it hit my RAM clips on my EVGA X58 motherboard and hit my CPU block bolts. That is why I purchased the 20mm fans to clear those two areas.
I have seen other posts and pics with other motherboards to where the 25mm fans cleared the RAM clips and not the CPU block bolts and some that cleared all but the NB chipset.
Chad
__________________
Components;
»HAF 922
»LG DVD SATA Model
»CORSAIR 850W
»Win7 Pro 64
»Dell 2707WFP
Water cool parts;
»Koolance MB-EVX58
»Koolance-D5 X-TOP
Old 09-28-2009, 11:25 PM   #5
mav2000
mav2000's Avatar
Thanks man...will keep an eye on your worklog...
__________________
MSI GD70 @ 1.5b4
Reply
Thread Tools
Rate This Thread:
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
Powered by vBulletin® Version 3.7.0
Copyright ©2000 - 2009, Jelsoft Enterprises Ltd.
XtremeSystems
