XtremeSystems Forums
Go Back   XtremeSystems Forums > Cooling > Dry Ice and Liquid Nitrogen
Reply
Old 09-24-2009, 10:40 AM   #1
Duniek
Duniek's Avatar
Send a message via MSN to Duniek
I did it!, NICKELPLATED POTS !!!
this time is for test only (I dont polished pot well before nickelplating but next time will be much much better)
__________________
NEW CNC POTS
CUSTOM WATERCOOLING STUFF
MY 1ST ITX PC MY 2ND ITX PC
I reply for all private messages, if you dont get answer after 3 days, please send it again, sometimes I can forget to reply.
the fastest contact to me:
mail @ duniek1986@poczta.fm or MSN with the same adress
Duniek is offline   Reply With Quote
Old 09-24-2009, 10:43 AM   #2
Asylum1
Asylum1's Avatar
Looks good.
__________________
Killer
Core i7 920 @ 4.2Ghz
EVGA X58 758 SLI
2xGTX295's in SLI
3x2Gig Kingston Hyper X 2100mhz
Corsair HX1000 Watt Modular
Water Cooling
3DMark Vantage 41312
Asylum1 is offline   Reply With Quote
Old 09-24-2009, 10:48 AM   #3
Elloquin
Quality work as usual Mike. Shiny :P
__________________
Originally Posted by chew* View Post
Nonsense,
There is no spoon.
Elloquin is offline   Reply With Quote
Old 09-24-2009, 11:11 AM   #4
TMWH
TMWH's Avatar
That dosen't affect the cooling at all? If not looks great man!
TMWH is offline   Reply With Quote
Old 09-24-2009, 11:14 AM   #5
chew*
No rest for the weary
chew*'s Avatar
+1.
Nickel plating protects the finish but is a poor thermal conductor at ln2 temps...
In this case if the contact area is lapped, it might actually aid in keeping cold in however.
It's useless for heatpipes however....actually hinders the copper heatpipes coated with nickel from dissipating heat.
__________________
heatware chew*
AMD is Back in Black Lifes more fun at -190C
How To Behave On An Internet Forum
http://www.thewavingcat.com/2008/02/...eed-the-troll/
Originally Posted by Sampsa View Post
1) Normal ES: Available to partners and press before the product actually launches. These are usually close to retail parts, maybe one stepping/node before retails. From my experience (I've had access to AMD & Intel ES CPUs before the official launch around 8 years) normal ES CPUs are actually usually worse than retails because manufacturing process develops all the time and retails keep getting better. Every Phenom II press sample (not even marked as ES but couple weeks earlier than retail parts) I've tested so far have been worse than normal retails.
chew* is offline   Reply With Quote
Old 09-24-2009, 11:15 AM   #6
Duniek
Duniek's Avatar
+1.
protect and you dont have any loss of performance
even better bcoz nickelplating make surfaces more flat
__________________
NEW CNC POTS
Old 09-24-2009, 02:31 PM   #7
overclocking101
overclocking101's Avatar
that looks hot man! much better looking than the copper one!
__________________
MAXIMUS RAMPAGE SE::::E8400 E0(1.25V VID)@4500MHZ::::2XHD4870512MB::::8GB CRUCIAL DDR2 800MHZ::::WATERCOOLED::::ULTRA 1KW 12V SINGLE RAIL PSU::::WIN7 X64
http://ocguru.webs.com/
overclocking101 is offline   Reply With Quote
Old 09-24-2009, 02:41 PM   #8
Vivi
take me to the manbar
Vivi's Avatar
Send a message via MSN to Vivi Send a message via Skype™ to Vivi
i doubt it will effect performance
you did a good job duniek!
at -100 to -190 not even toothpaste instead of normal paste between core and pot will effect performance
__________________
Vivi is offline   Reply With Quote
Old 09-24-2009, 02:50 PM   #9
Fatalbert
Fatalbert's Avatar
I like this nickel plated
__________________
Originally Posted by dinos22 View Post
SuperPi is like caviar. It's an acquired taste.
Originally Posted by K404 View Post
"My Backup is bigger than Your Backup"
Fatalbert is offline   Reply With Quote
Old 09-24-2009, 04:32 PM   #10
[XC] gomeler
Diablo 3! Who's Excited?
[XC] gomeler's Avatar
Send a message via AIM to [XC] gomeler
lol was talking to K|ngp|n a few months back about doing this to an F1EE. Still want to try it but I need to find a few things first Nice job with the plating,looks slick.
__________________
Team PURE is about kickass pirates and unicorns defeating ninjas.
[XC] gomeler is offline   Reply With Quote
Old 09-24-2009, 04:34 PM   #11
SNiiPE_DoGG
Permanently > 50ºC
SNiiPE_DoGG's Avatar
Send a message via AIM to SNiiPE_DoGG Send a message via MSN to SNiiPE_DoGG Send a message via Skype™ to SNiiPE_DoGG
+1.
nickel plating is a very very thin coating, I doubt it hinders much of anything.
__________________
Project
SNiiPE_DoGG is offline   Reply With Quote
Old 09-24-2009, 05:38 PM   #12
chew*
chew*'s Avatar
It won't hinder his pot, unless he did all the way to the internals with it......if anything it will help as long as the "base" internals did not get plated.
Might want to look up the heat and cold analysis of certain metals in the periodic table before you say that it doesn't hinder as it can in the wrong applications....Heatpipes would be one of them...
Gold plating on electrical connections is very thin......and it makes a diff
__________________
heatware chew*
Old 09-24-2009, 06:05 PM   #13
[XC] gomeler
b/c gold doesn't oxidize and therefore maintains its electrical conductivity
__________________
Old 09-24-2009, 07:32 PM   #14
chew*
chew*'s Avatar
Yep but that works for gold plating on brass/copper etc.
Same principle applies for heat exchange as well....even the quality of copper used can effect heat exchange but thats better discussed in another thread.
Bottom line at ambient or ln2 temps nickel has poor heat/cold exchange but in the application duniek is using it in it is actually a +........it might only be a +1% but a + plus bling is a +.....
I can acchieve the same +% just by swapping out my aluminum wall on my pot for acrylic....
__________________
heatware chew*
Old 09-24-2009, 07:44 PM   #15
WhiteFireDragon
Xtreme Cruncher
WhiteFireDragon's Avatar
Send a message via AIM to WhiteFireDragon
this plating won't do anything to the thermodynamics. you guys know that the layer is only a few atoms thick right? and besides, the CPU/GPU is not temperature sensitive, especially on extreme temperature scales.
anyways, that plating looks very nice, although bling and benching just hasn't really mixed before
__________________
e8600 @ 4.5ghz
rampage extreme
hd4650 512mb
2x1gb tracers
audigy 2zs
120gb vertex
HX520w
WhiteFireDragon is offline   Reply With Quote
Old 09-24-2009, 09:29 PM   #16
Otternase
Otternase's Avatar
Nice...
I will try it here with me, just missing the time
http://www.nibor.ath.cx/
__________________
Asus Blitz Formula QX6850@3,8Ghz/ Gskill PC8500GBHZ/ Asus 8800Ultra@ SilentX BlackEdition/ BeQuiet 1000W
Otternase is offline   Reply With Quote
Old 09-25-2009, 02:28 AM   #17
clear cmos
clear cmos's Avatar
Send a message via ICQ to clear cmos Send a message via AIM to clear cmos Send a message via MSN to clear cmos Send a message via Yahoo to clear cmos Send a message via Skype™ to clear cmos
nice gpu pot, can u pm me price of this pot?
__________________
my English is very
clear cmos is offline   Reply With Quote
Old 09-25-2009, 11:33 PM   #18
lesstutrey
lesstutrey's Avatar
Send a message via AIM to lesstutrey
Hard to mix bling, apart from hwbot medals, especially once insulated... though i do recall some gold plated pots that dino and a few others got in limited run.
__________________
Cooling:
Custom SS made by RunMC of under-the-ice.com
80L Cryofab CL80 Dewar
Otternase EEAL.CU
Tried: e8400,q6600,qx9650
Subzero queue: AMD Athlon 64 3000+,3200+,3500+ winchester, 3500+ newcastle, 3500+ Orleans, 3700+, 4000+, 4200x2+ & DFI LP Ultra
Intel P4: 520, 631
w3550+Bloodrage GTI,
asus commando
Inbound: sdumper SS
lesstutrey is offline   Reply With Quote
Old 09-26-2009, 01:06 AM   #19
railmeat
railmeat's Avatar
seems fine,looks cool but why plate the contact area with nickel???i would have left that copper contact area alone being it conducts better heat vs a nickel barrier coating.diff is prob min at those temps anywayz.
how much would silver cost to do a pot that size?????anyone...guesses?
imo silver would apply better,look better and have a smoother overall finished look vs nickel.i dunno.
__________________
Stacker830 Watercooled
windows7 ultimate 64 bit!!!
DD MC-tdk on EO-e8400@4.1Ghz
1.24volt, 513x8,31c/load 55c,fsb term 1.29
Swiftech p655 pump,1\2 tygon,dd h20 nb 1.29
9x120 sunnons on lamptron fc3 controller,
triple 120mm rad.2 raptor-x 150(both xp64bit,win7)
biostar i45 mobo(this mobo is amazing)
xfi-xtrememusic,klipsch ultras, sen hd-570s
co0lermaster-1250 watt real pro p\s 99ampz!
Evga CO-0p gtX 295 on 22"Diamondtron p1230
Hi quality CRTS are built for gaming!!!O.L.E.D is the future,not Liquid Crap Displays!
cod4 @ 2048x1536 75hz/75fps
If you believe in Jesus Christ and are 100% proud of it, then put this in your sig
G@m3r 4 L1Fe!!
http://service.futuremark.com/compare?3dm06=11372480
new e8400 EO stepping
http://www.xtremesystems.org/forums/...d.php?t=224960
h20 pc pics-- gtx 295
http://www.xtremesystems.org/forums/...post3784384new
railmeat is offline   Reply With Quote
Old 09-26-2009, 08:17 AM   #20
Duniek
Duniek's Avatar
in 0,5-1mm thick of nickel performance will drop
but nickelplating shield is 10um (0,01mm so I am sure in theory and practice you dont see any perfomance loss in extreme low temps (even with waterblocks when every 1*C count
__________________
NEW CNC POTS
Old 10-02-2009, 06:41 AM   #21
tech
tech's Avatar
wow...what about performance nickel plat??more better than cooper??
__________________
Phenom II 955
ASUS Crosshair III Formula + ROG OC Station
2XPatriot Viper DDR3-1866 2GB(d9gtr)
2X EAH4870 MATRIK ROG
2XOCZ Vertex 120 GB SSD in RAID 0 + Western Digital VelociRaptor 300GB
ASUS VW246H
PCP&C 910watt
tech is offline   Reply With Quote
Old 10-02-2009, 01:42 PM   #22
chew*
chew*'s Avatar
Nickel thermal Conductivity = 90
Copper thermal Conductivity = 400 worst case scenario.....
__________________
heatware chew*
Old 10-02-2009, 04:21 PM   #23
Easybeat
Easybeat's Avatar
We nickel plate a large number or brass components where I work and the coating can go as low as 3um (0.003mm), however it usually comes in around 7um and gives a similar finish to what you can see in the original post.
__________________
Hiper HPU-4M880, Q6600@3.6Ghz 1.5V, Abit IP35-E, 2x2GB OCZ Dominator PC8500, HD2900 Pro@874-900, Watercooled
Easybeat is offline   Reply With Quote
Old 10-06-2009, 12:36 PM   #24
tiborrr
-100c Club
tiborrr's Avatar
Send a message via ICQ to tiborrr Send a message via MSN to tiborrr
Nickel plating is an electrolytic process, the plating itself is only few microns thick so there shouldn't be any impact on thermal conductivity.
tiborrr is offline   Reply With Quote
Reply
Thread Tools
Rate This Thread:
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
Powered by vBulletin® Version 3.7.0
Copyright ©2000 - 2009, Jelsoft Enterprises Ltd.
XtremeSystems
