XtremeSystems Forums
Go Back   XtremeSystems Forums > Cooling > Vapor Phase Change Cooling
Reply
Old 09-24-2009, 08:39 AM   #1
MeltedDuron
Dothan FTW!
MeltedDuron's Avatar
Send a message via AIM to MeltedDuron Send a message via MSN to MeltedDuron Send a message via Yahoo to MeltedDuron
Rotary comp base mount - MODABLE?
Just quick question too back up what im think or what i hope im think is the truth and facts.
The mount on the bottom of most rotarys is it just welded on? Not sure what type of weld i'd say MIG as it's big, lumpy and nasty.
If this was ground away would that mounting plate become free from the comp? On the 2 i have here it looks like there are 3 longish welds that hold it on via the underside.
I've taken 2 photos, sorry there not amazing as i used my iPhone which aint good but all i had to hand.
__________________
.:Melted's Hardware:.
.:My Workstation::Sorta Done:.
.:Intel E4300@3ghz(375*8):2gb G.Skill HZ 6400@500mhz:Sapphire X1950pro:Gigabyte GA-G33M-DS2R:550w FSP Blue Storm:80gb and 160gb WD SATA2:Cheap MATX Case:.
.:Panasonic Toughbook CF-T2:.
.:Pentium M 753 (900mhz ULV):256MB:40GB:12.1" Touchscreen:. .:Not too shabby for a 2.4lbs of pwn:.
I've been using Intel ever since AMD put an end to my socket A fun. I was almost going to go back when I saw the cheap AM2 chips, but they suck Viva La Chipzilla!
MeltedDuron is offline   Reply With Quote
Old 09-24-2009, 09:25 AM   #2
Dualist
Dualist's Avatar
Yep, that's just mig welded on. But why do you want to remove it.?
__________________
Originally Posted by To(V)bo Co(V)bo View Post
I think ATI's big surprise is probally a FUNCTIONAL DRIVER!
Originally Posted by [XC] Hicks121 View Post
Ahhh keep it CD. You can never have enough pussy.
Dualist is offline   Reply With Quote
Old 09-24-2009, 10:51 AM   #3
MeltedDuron
Dothan FTW!
I can fit the come better in my case as currently the direction to which the mount is prevents the location i want.
I am fighting with both the suction acum and the base mount.
__________________
Old 09-24-2009, 12:20 PM   #4
trance565
if it's a good weld, you would have to grind away a bit of the actual compressor housing as well before it would come loose.
oh wait, nvm, i see what they did there... yeah, you should be able to grind it off. might be easiest to take a dremel cut off disc, and cut around the outside of the welds and leave the bit of welded sections of the mount on the unit.
__________________
emptiness
trance565 is offline   Reply With Quote
Old 09-24-2009, 04:09 PM   #5
[XC] gomeler
Diablo 3! Who's Excited?
[XC] gomeler's Avatar
Send a message via AIM to [XC] gomeler
Yup, you could just grind/cut around the welds. Would be best if you want to proceed this way, I would leave the actual hermetic case alone so as to not damage its integrity.
__________________
Team PURE is about kickass pirates and unicorns defeating ninjas.
[XC] gomeler is offline   Reply With Quote
Old 09-25-2009, 04:18 AM   #6
MeltedDuron
Dothan FTW!
It's just the welds i am thinking of grinding off. Even if i ground them down enough to where a tap with the hammer breaks the final little bit of weld and frees that mounting plate it's still a winner.
__________________
Reply
Thread Tools
Rate This Thread:
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
Powered by vBulletin® Version 3.7.0
Copyright ©2000 - 2009, Jelsoft Enterprises Ltd.
XtremeSystems
