XtremeSystems Forums
Go Back   XtremeSystems Forums > Cooling > Vapor Phase Change Cooling
Reply
Old 09-24-2009, 06:51 AM   #1
Foamy
Banned
Wip : Single stage
Hi folks,
After my single stage practise unit i thought it was time to make something worthy to use With some luck i found a free and useable coolgroup. It had some nice components in it and all they needed was some refurb loving
Here are some pics to start with
The victim
Trading old for new
Made proces, paintjob
The compressor is a pretty strong Uniti hermetique CAE9460T.
I wil update this now and then while more has been done
Foamy is offline   Reply With Quote
Old 09-24-2009, 07:03 AM   #2
Buckeye
Phantom is here :)
Buckeye's Avatar
WoW nice find there
That thing is just begging to be made into a SS unit
__________________
Jinu 2 Stage Cascade
http://www.youtube.com/watch?v=-zDu-Xgt400
Phantom LN2 Pot - First Encounter
http://www.youtube.com/watch?v=dLo7Dr_kR2U
How I cool my benching lab
http://www.youtube.com/watch?v=PLgwW...eature=related
Buckeye is offline   Reply With Quote
Old 09-24-2009, 08:29 AM   #3
MeltedDuron
Dothan FTW!
MeltedDuron's Avatar
Send a message via AIM to MeltedDuron Send a message via MSN to MeltedDuron Send a message via Yahoo to MeltedDuron
My god the speed that your moving on with this!! Looks gash but a nice find untill i saw the paint job and looks new again. Keep up the amazing work. You've gotten the skills now and by the looks the eye for detial to go with it!
__________________
.:Melted's Hardware:.
.:My Workstation::Sorta Done:.
.:Intel E4300@3ghz(375*8):2gb G.Skill HZ 6400@500mhz:Sapphire X1950pro:Gigabyte GA-G33M-DS2R:550w FSP Blue Storm:80gb and 160gb WD SATA2:Cheap MATX Case:.
.:Panasonic Toughbook CF-T2:.
.:Pentium M 753 (900mhz ULV):256MB:40GB:12.1" Touchscreen:. .:Not too shabby for a 2.4lbs of pwn:.
I've been using Intel ever since AMD put an end to my socket A fun. I was almost going to go back when I saw the cheap AM2 chips, but they suck Viva La Chipzilla!
MeltedDuron is offline   Reply With Quote
Old 09-24-2009, 11:21 AM   #4
clear cmos
clear cmos's Avatar
Send a message via ICQ to clear cmos Send a message via AIM to clear cmos Send a message via MSN to clear cmos Send a message via Yahoo to clear cmos Send a message via Skype™ to clear cmos
that is to say l'unite hermetique.....
__________________
my English is very
clear cmos is offline   Reply With Quote
Old 09-24-2009, 12:27 PM   #5
SexyMF
Needs more time
SexyMF's Avatar
They are noisy compressors.
SexyMF is offline   Reply With Quote
Old 09-24-2009, 12:59 PM   #6
Foamy
Banned
I have question concerning compressor connection,
How do i connect properly?
3 wires 1phase 220V, 2 capacitors, 1 running and 1 start capacitor..
*-edit*
This problem has been solved, motor up and running!
Old 09-26-2009, 03:20 AM   #7
Foamy
Banned
A bit more work has been done
Overall look without fanhouse
New vibrationpads underneath the compressor, the old ones were really grannystyle
Any comments on the de-superheater coil?
The suction lenght?
I'm going to take 2.4M cappilair
Old 09-26-2009, 04:00 AM   #8
clear cmos
clear cmos's Avatar
my opinion is better placed desuperheater vertically, length of the suction line & capilary tube is only a matter of taste
__________________
my English is very
Old 09-26-2009, 07:58 AM   #9
sdumper
-100c club
sdumper's Avatar
The suction lenght?
Desuper is a little long for a large compressor you really only need 1 or 2 coils for vibration.
__________________
http://valid.canardpc.com/show_oc.php?id=606830
Seller/Buyer Reputation:
Heatware: http://www.heatware.com/eval.php?id=50905
Ebay: {Family Account} Kasyg3 http://myworld.ebay.com/kasyg3/
Ebay: {My personal Account} Sdumper http://myworld.ebay.com/sdumper/
iTrader: http://www.blazingpc.com/forum/itrader.php?u=28
sdumper is offline   Reply With Quote
Old 09-26-2009, 11:17 AM   #10
MeltedDuron
Dothan FTW!
DSHC is fine. it'll stop the vibes and add a bit more cooling
__________________
Old 09-26-2009, 02:29 PM   #11
SexyMF
Needs more time
SexyMF's Avatar
DSHC is not necessary for a single-stage system. You only need 2 or 3 large loops to dampen the vibration from the compressor onto the condenser joint.
Also, your compressor will run either way you wired it but won't run for long if you have the start and run caps switched. What values of capacitor did you use for each winding?
Old 09-26-2009, 02:34 PM   #12
Foamy
Banned
I have connected it the right way now long live the manual
original capacitors btw
Old 09-29-2009, 03:31 AM   #13
Foamy
Banned
Yesterday first test of the system .
Learned allot
it seems that evap design is really important , while gassing the system and starting it, temps were dropping very very fast to -40, once the system was filled temps dropped back to a loazy -25°c within secs...i was scratching my head, how could this be possible???
-->evap
I made a custom test evap at work , but it has no canals and the capilair lays next to the suction line, in other words , it goes in and gets sucked away before it even makes change to evaporate lol.
Anyhow, a decent evap wil be made so we can test again.
System was filled with R417A
Old 09-29-2009, 11:26 PM   #14
SexyMF
Needs more time
SexyMF's Avatar
Give us more details. What are you pressures when you have finished charging? It sounds like you don't have enough volume in the evaporators and the low side pressure is to high.
How did you determine the total charge?
Old 10-25-2009, 02:17 AM   #15
Foamy
Banned
a little late update lol,
did some finalizing on the unit, insulated the evap added mounting plate S1366 only .
I really used some ghetto stuff for this, inox plate and housing from a standard motor, placed the evap in it, a little PU mousse and done deal :-)
Getting idle around -58°/-60 Working on load tester now . Already done some overkill testing with airheater wich produces 2000W or max 300°c
Stil on R410a btw
Old 10-25-2009, 03:47 PM   #16
SexyMF
Needs more time
SexyMF's Avatar
Images are broken for me.
I've found that an airheater doesn't put much load on an evap. I'm guessing that air->copper transfer is poor, coupled with the layer of watery ice on the evap that acts as a good insulator.
Final tuning is better served on the actual CPU. Not to mention is looks cool having bottles and guages attached to the computer
Old 11-03-2009, 07:48 AM   #17
Foamy
Banned
Fixed the images
So i had R410a charged, i recharged the system with R507, temps are temps at idle but when when loading it it completely fails 250W btw. I guess it's the 9feet .028 capilair that is holding me back.
Old 11-03-2009, 07:53 AM   #18
sdumper
-100c club
sdumper's Avatar
Or your pressure is too low...
__________________
Old 11-03-2009, 08:05 AM   #19
Foamy
Banned
Hmm sorry m8 but i'm noob, could you explain wich side and how to resolve, or how i should notice this?
I always charge untill a few inches of the compressor is not frozen and my low side at 0 bar .
Old 11-03-2009, 08:21 AM   #20
sdumper
-100c club
sdumper's Avatar
Hook up your red hose to your high side the side coming "Out" of the condenser often located on the filter drier...
Hook up your blue hose to the low side often the service port on your compressor.
Whats your loaded pressure on the red hose gauge under load?
Also whats the temp of your suction line 2 to 4 inches up from your compressor under load?
If your pressure is above 225 psi and your not holding load then I would trim down to 8 feet and try again.
__________________
Old 11-04-2009, 06:11 AM   #21
Foamy
Banned
Was going to test this but in idle my low side was in vaccum and my highside around 150psi, a bit undercharged so i didn't bother to put load on it.
i'm going to swap my custom evap and suction line with a prefab from piotres or duniek . .036capilair with 10feet to start with. I really need this system to hold 250w steady at -35°c if possible.
Old 11-04-2009, 07:07 AM   #22
sdumper
-100c club
sdumper's Avatar
Sounds good
__________________
Old 11-04-2009, 07:21 AM   #23
quintus
quintus's Avatar
Maybe if it's getting colder then you will have 250watt at -35, your compressor is not that strong
From your presures is clear that you didn't charge it with enought freon, also 9feet of .028 is too much for 250watt! According to Gary's forumula you need 5feet for 225watt. 5 feet is the minimum recommended so go for 6feet and try your luck. Or best wait for a custom lfex line/evap/ cap line from some1 with more experience.
Make yourself a variable dummy heat load.
I would keep in mind that the compressor doesn't performe like it was brand new.
quintus is offline   Reply With Quote
Old 11-04-2009, 07:30 AM   #24
Foamy
Banned
my compressor is comparable with nl11f ,slighty stronger.
Old 11-04-2009, 07:32 AM   #25
sdumper
-100c club
sdumper's Avatar
Whats the compressor rated at and what is the hp?
I dont see it posted...
__________________
Reply
Thread Tools
Rate This Thread:
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
Powered by vBulletin® Version 3.7.0
Copyright ©2000 - 2009, Jelsoft Enterprises Ltd.
XtremeSystems
