Originally Posted by Stvwndr219
I got it from someone else so no luck with the thermal pads. Correct me if I'm wrong but the mosfets are the little black dot things next to the big square things right? If it's flat, would I just dab a bit of arctic alumina or something on there?
Also, should I be worried if there are dark smudges on the copper bases? I can't seem to clean them off with isopropyl alcohol. Thanks!
yes u just need a little dab.
And the dark smudges is oxidation.
It wont hurt its performance, however if its annoying the crap out of you, try using some vinegar and wipe in 1 direction until it disappears, and then imediately clean off.
