XtremeSystems Forums
Reply
Old 09-23-2009, 07:52 PM   #1
pelo911
Temperature Sensor Stop Fitting to plug in Matrix Orbital MX630
Matrix Orbital Temperature Probe:
there is way to use Bitspower G 1/4in. Temperature Sensor Stop Fitting??
i want to install it into EK-Multioption RES 250 rev.2 Reservoirs
pelo911 is offline   Reply With Quote
Old 09-23-2009, 08:32 PM   #2
NaeKuh
Post Soapbox Destruction
NaeKuh's Avatar
no...
which is why i ditched the orbital and i had 2.
You want an aquereo. If you want the screen display.
__________________
Nadeshiko: *Undergoing Rebuild*
Haruhi: i7 975 12GB DDR3 eVGA Classified *Haruhi -> Nadeshiko*
Lind: Dual Gainestown 3.07
NaeKuh is offline   Reply With Quote
Old 09-23-2009, 08:57 PM   #3
pelo911
Originally Posted by NaeKuh View Post
no...
maybe some adapter or anykind of mod?!
Old 09-23-2009, 09:44 PM   #4
NaeKuh
NaeKuh's Avatar
nope.
the software itself only supports dallas digital probes.
i tried everything... its a big no. :T
__________________
Old 09-24-2009, 09:53 AM   #5
pelo911
the Matrix Orbital Temperature Probe , there is way to put it inside the Reservoirs?
Old 09-24-2009, 10:13 AM   #6
CodeNinja
CodeNinja's Avatar
Well you -could- encase it in expoxy, drill a hole in the top of the reservior, and dangle it down inside...
Where there is a will, there is a way. It won't be pretty and if you do it wrong, it could short out or leak. But it's technically doable.
Another option, if you have the money, is to get a T-Balancer bigNG, hook the Bitspower temp sensor to the bigNG, and read the values that way and push it to the Matrix Orbital display.
__________________
Asus P6T | TRUE Extreme Edition | i7 920 @ 3.8Ghz (19x200) | 6GB Corsair DDR3 1600Mhz |
XFX GTX285 Black Edition | 4x WD Caviar Black 640GB RAID10 Array | CoolerMaster Centurion 590 |
Corsair 620HX Modular PSU | Lots and Lots of Fans!
CodeNinja is offline   Reply With Quote
Old 09-24-2009, 03:44 PM   #7
pelo911
matrix orbital displays use LCDC software ,
http://www.lcdc.cc/downloads.htm
LCDC using plugin like:
Motherboard Monitor 5 , Hardware System Monitor (hmonitor) , Everest Ultimate
with the plugins LCDC show CPU and motherboard Temp.
maybe i can plug the Bitspower G 1/4in. Temperature Sensor to somewhere in my motherboard to show water temp?
Old 09-24-2009, 04:08 PM   #8
NaeKuh
NaeKuh's Avatar
There is no temp probe port on a motherboard.
Sorry, but it just wont work.
I spent a lot of time and even went out to custom people to get a probe to work in my orbital.
Martin was nice enough to make me a T with a probe, but its just too much hassle.
If you have an orbital sorry, as i said i owned 2, both the expensive VFD models, and now there just sitting in a box with the rest of my useless junk.
If you want a temp probe display get a scythe Kaze master.
__________________
Old 09-24-2009, 04:52 PM   #9
ascl
The cheapest option is a dedicated temp LED (XSPC make some), for about $5. You can snip the end off the LED probe and wire the bitspower plug into it. Or you can grab a silverstone CMD01 ($17 from amazon) and connect it to that (it will work in HWMonitor just fine without any nvidia bits), which will give you the readout purely in software.
ascl is offline   Reply With Quote
Old 09-24-2009, 09:25 PM   #10
Kibbler
Kibbler's Avatar
That's not true for all motherboards. ROGs for example:
Kibbler is offline   Reply With Quote
Old 09-24-2009, 10:47 PM   #11
Ketzer7
Ketzer7's Avatar
NaeKuh's point though is that MO display's use a very specific temp sensor made by Maxim-IC that is meant only for Dallas 1-wire communication buses which have a 3-pin connector on them. It's really not a temperature sensor in the traditional way you would think of one. It's really like a little ASIC that comes in a package that looks like a transistor and requires external power and all that.
Most of the temp sensors people are probably accustomed to using are just simple 2-lead thermistors that give a temperature based on a certain R value and k constant or something like that which can be used to calculate the temperature. That's all the Asus board is using. The two are completely incompatible like he said.
Ketzer7 is offline   Reply With Quote
Old 09-24-2009, 10:55 PM   #12
Kibbler
Kibbler's Avatar
Am I missing something? It sounds like all the OP wants to do is show the temperature on the MO display. Probe to motherboard to hardware monitor/everest/etc to PLED via USB. That should do it, no?
Old 09-24-2009, 11:04 PM   #13
NaeKuh
NaeKuh's Avatar
sure if u can find a software that will place nice with lcdc and take the temps off the board.
I stand corrected tho, i never knew there was a board that u could plug analog probes to directly..
__________________
Reply
Thread Tools
Rate This Thread:
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
Powered by vBulletin® Version 3.7.0
Copyright ©2000 - 2009, Jelsoft Enterprises Ltd.
XtremeSystems
