I've had some build up in my block, but that was due to me adding the liquid from highlighters to obtain a UV tint. Using strictly distilled, I haven't had any problems.
I'm using Koolance UV coolant. But I've heard reports of folks using distilled water and biocide and still having their blocks clog. I'll take some pics by this weekend from my result of opening the block up.
__________________ Pandora's Box:
Case - Lian Li PC-343B
Mobo - EVGA X58 Classified (759)
CPU - i7 920 (D0 stepping), watercooled w/Enzotech Luna Rev.A block
RAM - Corsair Dominator GT 2000 (8-8-8-24) w/fan
GPU - EVGA GTX295 quad-SLI, water cooled w/Koolance NX295 blocks
PSU - Corsair HX1000
O/S - Windows 7 RC build 7127
I never flushed my rads (bought new), never cleaned up my blocks or pumps (if new) and never had any block clog. All i use is FESER and if i ever change liquid colour i do flush everything real real well. Been "under water" since 2002.
As a side note, the flow rate issue I'm having is only with my CPU block. The Koolance GPU and chipset blocks I have on my 2nd loop is having no issues, and is using the same coolant.
Took apart my water coolong rig last week after 3 years and not a single problem. I have used nothing but fluid xp for the last 5 years and it's been great. Are you using a flow meter of some sort?
The pin matrix seems to help with the cloging. The GPU blocks don't really have anything to hold the dye. I have that using too much PT Nuke can have the same effect. Its one of the reasons that silver and distilled water seems to be the best bet.
@ Namco.
I have seen that people have gotten away with doing that. No one is saying not to use Feser, but if you do, know the risks. Also the flushing of the rads and blocks doesn't take a lot of time, but it is good thing to do. People have found bits of metal in blocks and people have had flux clog up their blocks. It doesn't happen to everyone, but the extra 20 mins it takes to do it may save you a few hours of headaches down the road.
edit: rambler, you have been having alot of issues with flow. Are you positive your flow meter is working properly? Also, how are your temps?
Yes, 2 FM17 flow meters. One for my CPU loop, and the other for the GPU/chipset loop. No problems with the flow meters, as I even swapped them around to be sure.
never happened to me personally, though i know someone on another board who got his fuzion very dirty somehow. If i get a used block i always open em up and brush them out with a toothbrush, i've also seen some form of blue UV coolant clog up blocks.. When i've cleaned mine there has been at most a couple pins/fins with a little black stuff stuck in between them.
__________________
Cooling: Custom SS made by RunMC of under-the-ice.com 80L Cryofab CL80 Dewar Otternase EEAL.CU Tried: e8400,q6600,qx9650 Subzero queue: AMD Athlon 64 3000+,3200+,3500+ winchester, 3500+ newcastle, 3500+ Orleans, 3700+, 4000+, 4200x2+ & DFI LP Ultra
Intel P4: 520, 631
w3550+Bloodrage GTI,
asus commando Inbound: sdumper SS
I haven't seen this happen before, could you email me picture?
I plan on taking it apart this weekend. I can post a pic here. But it's not a Koolance CPU block, and I'm not blaming the Koolance UV red coolant I'm using as the Koolance GPU and chipset blocks are fine.
I've swapped and tested every other component in the loop, and the CPU block is the only remaining item that could be causing the flow blockage.
I recently cleaned my loop and found black gunk in my heatkiller and in my gpu blocks. No mixed metals, all copper but I did use food color to get a red coolant. I suspect that it precipitated out over time.
Related question - what is the experience with Primochill dye bomb. I like the idea of red coolant but not at the expense of my loop.
__________________
i7 920 DO 3850A849 @4410 under custom water.
Asus P6T deluxe V2
3X2gb Mushkin DDR3 1600 998691
2 Sapphire 4870 1g Crossfire
Corsair Hx 850 psu
2 G.Skill titan 128gb SSDs in RAID0 Data
Intel X25-M OS drive
Windows 7 RTM
Red tubing is your best bet. Primochill makes some nice tubing in assorted colors.
Some red leds around your res can help add bling there too.
So I broke down my system and took the CPU block apart. Here's what I found:
Definately some wierd crud in the block, and it's right around the CPU block's inlet port area. So the big question - does this look like a likely cause of my CPU's flow rate dropping by almost half?
And could this stuff come from one of the bad rads I've had? I don't think this crud is coolant related.
I picked some of that crud out by hand, and it did feel like there were tiny metal shavings mixed in with it.
I think it was the replacement 1080 rad I got that started leaking, that caused this issue. As one thing I noticed after first getting that rad, that I could hear something moving around in it when I shook it.
But I've now got 2 MCR320 rads to replace the 1080. And I'm hoping by cleaning out the CPU block, that this will solve the flow rate drop issue for my CPU loop.
Hard to tell from a picture but it would appear as those most of that crud is large solid paticles. I'd say the most likely cause is your dirty rad.
Again from the picture it does not look as though you plugged up the block enough to cause a 50% reduction in flow.
If that crud does contain metal then I'd tear down your pump as the rubber impeller could be chewed up. Any pump damage will definitely cause a large reduction in flow.
__________________
Mobo: Asus Rampage Gene II
CPU: i7 920 at 3700 Mhz, NO increased volts anywhere.
GPU: Sapphire 4890 Vapor-X
RAM: G.SKILL Trident DDR3 2000 (PC3 16000) 6x2GB
HD's: 2 Velioci Raptor 300 gig + several others
Blu-Ray Writer: Pioneer BDR-203BK
DVD Scanner: Liteon SHW-165H6S DVD
PSU: Corsair HX1000
Case: Obsidian 800D
GPU Cooling: Ek Water Block CF Acetal Full Cover GPU Block 1/2IN G1/4
CPU Cooling: Heatkiller v3
Water Res: Swiftech MCRES-MICRO Clear HI-FLOW Water Cooling Reservoir
Radiator: Feser 360
Pump: Swiftech MCP350 with XSPC top
Fittings: Danger Den G1/4 to 3/8IN High Flow Barb Chrome Fittings
Tubing: 3/8" I.D. Tygon
Cooling Water Conditioning: Petra's Tech Shop ,PT-Nuke and Pentosin G11
OS: Windows Vista Ultimate x64
