XtremeSystems Forums
Reply
Old 09-23-2009, 11:19 AM   #1
gatecrasherlok
gatecrasherlok's Avatar
Heat Killer waterblock differences
I was just sizing up a possible water cooling setup for my rig but stumbled upon something which I found quite strange. Why is the heat killer version 3.0LT cheaper than the regular 3.0 version.
Apart from aesthetics, is there any additional flow differences between or any performance gain from getting the regular 3.0.
Heat Killer LGA1366 3.0 LT
http://www.sidewindercomputers.com/h...lerlt1366.html
http://www.sidewindercomputers.com/heatkiller1366.html
__________________
EVGA X58 Classified
Intel Core i7 920 @ 3.8ghz
EVGA 295 GTX x2 Quad SLI (0.C)
Corsair Dominator DDR3 6GB PC3-12800C8
Western Digital 150 GB Velociraptor
Thermaltake Toughpower 1200 watt
Thermalright True (Push/Pull Config)
Lian Li Pc-P80 Armoursuit
Scythe Kaze Master Fan Control
Imon VFD Display and Control
gatecrasherlok is offline   Reply With Quote
Old 09-23-2009, 11:24 AM   #2
Baulten
I don't believe so. The LT just uses a Derlin (spelling?) top instead of a full copper top. I suppose the heat transfer to the top on the full copper version would result in slightly lower temperatures... but we are talking tenths of degrees C AFAIK.
__________________
Builds: Old / New
CPU: Phenom II 940 / Phenom II 965
CPU cooler: Xigmatek s1283 / Watercooled
Motherboard: DFI LanParty 790FX-M2RS / MSI 790FX-GD70
RAM: 2x2GB G.Skill DDR2 800 / 2x2GB G.Skill DDR3 1600
Video card: GTX 260 / HD 5870
Hard drive: 2x250 GB Seagates, 1x250 GB Western Digital (SATA), 1 TB WD External
Case: Modded Cooler Master RC-690 Mid Tower / Corsair Obsidian 800D
Baulten is offline   Reply With Quote
Old 09-23-2009, 11:25 AM   #3
millertime359
Xtreme Mentor
millertime359's Avatar
The cost of copper is the reason for the price difference. Copper is a bit costly atm. The internals on those 2 blocks are exactly the same. There have been tests that show there are fractions of a degree difference between the 2. The main reason to get the copper is to have it nickel plated and have a bling block in your case. If you don't care about bling, the LT is fine.
__________________
Project Millertime: The Core I5 build
Crunching/folding box on air: AMD Athlon X2 7750 Black Edition; Sapphire Radeon HD 4830; Gigabyte MA78GM-US2H; Lian Li PC-V351; Windows 7 RC
millertime359 is offline   Reply With Quote
Old 09-23-2009, 11:33 AM   #4
gatecrasherlok
Ahh thanks for such quick replies guys, i just kept looking all over the web at different sites specs of these two block and I really could not find much info in relation to the price differences but if its the bling and the top copper material then I'd probably give it a miss. The LT looks fine to me, id rather have that than the full copper version imo.
__________________
EVGA X58 Classified
Old 09-23-2009, 04:24 PM   #5
urgrandpasdog
Between those 2, the performance is the same, the only difference is the top. The LC variant, which is cheaper than either of those, has a different base design that is not as effective.
urgrandpasdog is offline   Reply With Quote
Old 09-23-2009, 04:42 PM   #6
overclocking101
overclocking101's Avatar
also the plate inside is a bit different i believe there is less surface area as well
__________________
MAXIMUS RAMPAGE SE::::E8400 E0(1.25V VID)@4500MHZ::::2XHD4870512MB::::8GB CRUCIAL DDR2 800MHZ::::WATERCOOLED::::ULTRA 1KW 12V SINGLE RAIL PSU::::WIN7 X64
http://ocguru.webs.com/
overclocking101 is offline   Reply With Quote
Old 09-23-2009, 04:55 PM   #7
millertime359
Xtreme Mentor
The LC's pin matrix is not as dense as the the LT and CU. This offers higher flow rates, but reduces the amount of heat dissipated.
__________________
Old 09-23-2009, 04:56 PM   #8
RADCOM
Xtreme Waterbaby
RADCOM's Avatar
+1 Wot he said
"Not as effective" being 1.3 degrees temp worse and more flow according to Hesmelaugh test results.
__________________
Respec'
System:Bunch of crappy overclocked PC's that cost an arm and a leg
"A Caesarean Milks Stops Wort"-anagram
RADCOM is offline   Reply With Quote
Reply
Thread Tools
Rate This Thread:
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
Powered by vBulletin® Version 3.7.0
Copyright ©2000 - 2009, Jelsoft Enterprises Ltd.
XtremeSystems
