XtremeSystems Forums
Reply
Old 09-23-2009, 12:37 AM   #1
Titan7171
So my watercooling setup cost $300
6 x *** NEW *** Bitspower Premium G1/4" High Flow 1/2" Fitting - Black Matte Finish $17.94
10 x Reuseable Clamps - For 1/2" Tubing (3/4" O.D.) - Black $9.90
10 x Tygon 3603 1/2" ID (3/4" OD) Clear Tubing $34.90
1 x *** NEW *** Watercool MO-RA 2 Extreme Performance 9 X 120mm Radiator Core
- Fitting Size: 1/2" OD $124.95
for the above $201 shipped
Enzotech Sapphire $43 shipped
XSPC dual bay res/pump $47 shipped
Hope it turns out ok.
__________________
Phenom 965 BE@4.1ghz
Enzotech sapphire/Mo-Ra extreme rad
Asus M3A79-T Deluxe
ht 2200mhz / nb 2800mhz
2x2gb Gskill ddr1066 5,5,5,15,24,2T
Sapphire 4850x2
Enermax Infinity 650 crossfire
case: XCLIO A380PLUS-BK
4.44ghz air
4.4ghz superpi 1M 15.694
http://s271.photobucket.com/albums/j...1569444ghz.jpg
22,949 06 Phenom 965@ 4.2ghz Sapphire 4850X2@700/1150
13,954 Vantage, Phenom 940 4.1ghz Sapphire 4850X2@700/1180
If I dont get every single drop out of my cpu I feel like someone is stealing from me
Titan7171 is online now   Reply With Quote
Old 09-23-2009, 01:15 AM   #2
tomslick.ca
what 9 120mm fans do you plane to use?
tomslick.ca is offline   Reply With Quote
Old 09-23-2009, 06:50 AM   #3
zeropluszero
zeropluszero's Avatar
Send a message via MSN to zeropluszero
THISSSS
OMG hahahahahahahahahahaha
__________________
Cosmos S - Q9550 E0 - EVGA 780i FTW - 4GB Dominator 8500 - SLI GTX280 - 150GB Velociraptor - Enermax 85+ 1050W
Parallel Loop using EK MultiLink Reservoir
CPU Loop: Heatkiller 3.0 CU (Nickel plated) - Feser 360 (S-Flex G) - MCP350 + EK Plexi Top - EK Reservoir
NB/SB + GPU Loop: EK 280 Nickel Plexi - Bitspower 780i Fullcover - Feser 240 (S-Flex G) - MCP355 + EK Plexi top
zeropluszero is offline   Reply With Quote
Old 09-23-2009, 06:52 AM   #4
millertime359
Xtreme Mentor
millertime359's Avatar
You might run into issues with your pump and raidaitor chices. The Mo-Ra is a restrictive rad and that pump works great as long as restriction is low. See here for rad: http://www.xtremesystems.org/forums/...d.php?t=226445 and here for pump: http://martin.skinneelabs.com/XSPC-D...mp-Review.html The Sapphire is a high flow block though, so that might help. If you haven't ordered yet, I would say to get a Swiftech MCP355 and a XSPC dual bay res or a Swiftech MCP655 and a Typhoon III if you want a bay res setup. There are other tops and res' if you don't care.
__________________
Project Millertime: The Core I5 build
Crunching/folding box on air: AMD Athlon X2 7750 Black Edition; Sapphire Radeon HD 4830; Gigabyte MA78GM-US2H; Lian Li PC-V351; Windows 7 RC
millertime359 is offline   Reply With Quote
Old 09-23-2009, 06:52 AM   #5
WeeMaan
What was the question again?
__________________
Project TJ07 WeeMaan edition in progress...
i7 920 @ 4,4ghz, P6T Deluxe, Corsair Dominator, Amd 4850 (temp), OCZ Vertex 60gb + Samsung F1 1tb
Heatkiller copper, Thermochill 120.4, DDC 3.2
WeeMaan is offline   Reply With Quote
Old 09-23-2009, 07:05 AM   #6
zeropluszero
+1
consider a dual pump set up with DDC's, or a different rad perhaps.
__________________
Old 09-23-2009, 07:11 AM   #7
SNiiPE_DoGG
Permanently > 50ºC
SNiiPE_DoGG's Avatar
Send a message via AIM to SNiiPE_DoGG Send a message via MSN to SNiiPE_DoGG Send a message via Skype™ to SNiiPE_DoGG
yes, that pump you have in the OP is far too weak I am afraid :\
__________________
Project
SNiiPE_DoGG is offline   Reply With Quote
Old 09-23-2009, 10:30 AM   #8
Titan7171
Well for the price I got the res/pump it will have to do till I can upgrade, I definitly wanted the rad so I wasnt going to switch that out because of restriction. my weakest link is the pump but Ill see how it works out for the short term. Ill be posting some results compared to my aircooled setup.
As for the fan Ill be trying out a 36cm fan to see how that works out and I also have another experiment Im going to try with the rad.........so it should be fun which is what Im looking for.
__________________
Asus M3A79-T Deluxe
Sapphire 4850x2
4.44ghz air
Old 09-23-2009, 03:26 PM   #9
Spawn-Inc
Spawn-Inc's Avatar
that 36mm rad won't do much of anything, it doesn't have the static pressure you need for rads.
__________________
CPU: Core2Quad q6600 G0 3.5GHz@1.4v (highest so far 4.2GHz)
GPU: XFX 9800GTX @ 850/1230
Ram: Samsung 4GB (4x1GB) 700MHz PC5300
Mobo: EVGA-NF68-A1 680i (P32)
PSU: Enermax Galaxy 850Watt DxX
HDD:WD5001AALS, ST3250410AS, ST3500410AS, ST3500320AS - 1.75TB
DVD: LG H26N,LG GH20LS10 both sata
LCD: Samsung 32" LN32A450, Samsung 226BW 22" wide
Sound: Logtiech Z 5500/Razor Barracuda HP-1 / AC-1
CPU & GPU: 3x Swiftech MCR320, 2x MCP655, MCW60 R2, Dtek Fuzion V2, 18 high speed yates @ 5v
3Dmark06:17,814 AquaMark:190,865
Spawn-Inc is offline   Reply With Quote
Old 09-23-2009, 03:49 PM   #10
faster3200
faster3200's Avatar
With what is basically 3x 120.3 rads on a cpu only loop, I think he can get away with a weak fan.
My only concern with the plan is that since he is using one big fan he is going to have a large dead spot making a lot of the rad worthless. A shroud would really help in this case.
__________________
"Everything is amazing and nobody is happy".
- Louis CK
faster3200 is offline   Reply With Quote
Old 09-23-2009, 04:52 PM   #11
NaeKuh
Post Soapbox Destruction
NaeKuh's Avatar
so what makes u think that adding the dead spots of 9 fans won't = the same dead spot of 1 larger fan?
__________________
Nadeshiko: *Undergoing Rebuild*
Haruhi: i7 975 12GB DDR3 eVGA Classified *Haruhi -> Nadeshiko*
Lind: Dual Gainestown 3.07
NaeKuh is offline   Reply With Quote
Old 09-23-2009, 05:50 PM   #12
lesstutrey
lesstutrey's Avatar
Send a message via AIM to lesstutrey
the shroud would help, i would certainly think, and that would kinda eliminate dead spots, and actually be more effective than a bunch of small fans (think condensers) however a fan that does a good enough job is probably gonna be a slight bit on the loud side, but 9 fans would be too. And i agree with above post, actually might even be greater dead spot area depending on a few factors if you ran 9 120's
__________________
Cooling:
Custom SS made by RunMC of under-the-ice.com
80L Cryofab CL80 Dewar
Otternase EEAL.CU
Tried: e8400,q6600,qx9650
Subzero queue: AMD Athlon 64 3000+,3200+,3500+ winchester, 3500+ newcastle, 3500+ Orleans, 3700+, 4000+, 4200x2+ & DFI LP Ultra
Intel P4: 520, 631
w3550+Bloodrage GTI,
asus commando
Inbound: sdumper SS
lesstutrey is offline   Reply With Quote
Old 09-23-2009, 06:15 PM   #13
Spawn-Inc
Spawn-Inc's Avatar
i forgot that, i have 3x 120.3's and can run passive on my q6600, but only stock.
also the dead spots on in the corners.
__________________
Old 09-23-2009, 08:49 PM   #14
Titan7171
The reason Im going with the 1x360mm is because I already have it here and I dont have to add any cost to this setup right now, later I can also go 4x 18cm fan something like the square ones available here
http://www.newegg.com/Product/Produc...217&name=180mm
or do a 8x18cm in push pull, theres always a way of doing something different. I definitely wouldnt go the 9x120mm
also the mo-ra works extremely well all across the board even so with low rpm 400-1200rpm fans (quiet)
The stuff gets here Monday
__________________
Asus M3A79-T Deluxe
Sapphire 4850x2
4.44ghz air
Old 09-24-2009, 06:31 AM   #15
millertime359
Xtreme Mentor
That rad is nice for cooling. It seems you can run some slow fans on it, the problem is its restriction. I think may run into issues with that pump you decided to get. I would keep an eye on the classifieds for some used DDCs or D5s to show up. I've seen some pop up for about what you paid for that.
__________________
Old 09-24-2009, 10:58 AM   #16
Titan7171
would running a more powerful pump in the same loop with a weak one kill the weak one?
Its like being tied by a rope to Jesse Owens then asked to keep up
what do you think of getting another of the same dual bay res/ pump to put into the loop? I wanted to add a second res/pump anyway to increase the water amount anyway?
__________________
Asus M3A79-T Deluxe
Sapphire 4850x2
4.44ghz air
Old 09-24-2009, 11:39 AM   #17
millertime359
Xtreme Mentor
Yea, a more powerful pump will kill that pump. I would just get a DDC or D5. You would be taking up 4 fronts bays with those 2 pumps. The amount of water will only help your temps if you don't run your computer for long lengths of times. If it is on for hours each day, it isn't worth having the extra water.
__________________
Old 09-24-2009, 12:23 PM   #18
Titan7171
I only need 1 drive, this is a gaming/internet rig and I have 5 bays. The computer does not stay on all day either. I wanted to have both dualbay res in there lit up with UV from behind I think it would look cool from the front.
Im going to set everything up then buy either the ddc or xspc?
__________________
Asus M3A79-T Deluxe
Sapphire 4850x2
4.44ghz air
Old 09-24-2009, 12:33 PM   #19
millertime359
Xtreme Mentor
You haven't purchased the pump yet? Well then either get a Swiftech MCP355 with the XSPC dual bay res, or get a MCP655 with the Typhoon III.
__________________
Old 09-24-2009, 01:20 PM   #20
Titan7171
Yes I got the XSPC/pump already Ive had it for 2 weeks then I got the waterblock last week then I ordered the rad and everything else 2 days ago.........but the res/pump was the first thing I got. I know you are trying to sway me off this pump/res combo because its not ideal but its to late
I wanted a second one to compliment the first and relieve some of the load off it and at the same time adding more water into the loop and having 2 dual bay res pump combo was my idea from the begining.
Im only cooling a cpu so hopefully it will work ok for the meantime.
__________________
Asus M3A79-T Deluxe
Sapphire 4850x2
4.44ghz air
Old 09-24-2009, 01:28 PM   #21
millertime359
Xtreme Mentor
The CPU block you have is high flowing, so that should help you out. The additional water a second one of those will add won't make any difference. The difference would come you if you have alot of extra water and the comp is only on for a couple hours a day.
When you plan to get another one of those pumps, I would get one of those i linked instead.
Your temps shouldn't be horrible, but they may not be as good as they could be.
__________________
Old 09-24-2009, 01:57 PM   #22
Titan7171
Ok would the amount of water make a difference if I added a GC to the loop?.........A 5870x2 is in my future.
also would I be able to add the mcp355 to the loop without damaging the pump in the res?
Hey thanks for all the help man
__________________
Asus M3A79-T Deluxe
Sapphire 4850x2
4.44ghz air
Old 09-24-2009, 02:05 PM   #23
Caoder
Caoder's Avatar
Send a message via MSN to Caoder
no if you add the mcp355 it will kill your other xspc pump, but i think just the mcp355 should be enough for a loop including the gpu because most gpu blocks aren't restrictive. also you really don't need that much water at all... won't really change anything.
__________________
Core i7 920 D0 @ 4.2 | 2 x GTX 260 | EVGA x58 SLI | 3 x 2 gb GSKILL Perfect Storm 17066CL9|
CPU under WC/ gtz + 2x mcr220
Caoder is offline   Reply With Quote
Old 09-24-2009, 02:10 PM   #24
millertime359
Xtreme Mentor
That pump combo will have to go if you get a MCP355 or MCP655
The amount of water doesn't make a difference. I may have been confusing you a bit earlier, but it really doesn't make a difference.
__________________
Old 09-24-2009, 02:12 PM   #25
Titan7171
Im under the impression that having more water in the loop makes it harder to heat up just like trying to heat up a pot of water thats half full is easier than trying to heat up a full pot of water. The more water the longer it takes to heat up keeping the overall water temp lower?
Am I wrong about this?
__________________
Asus M3A79-T Deluxe
Sapphire 4850x2
4.44ghz air
Reply
Thread Tools
Rate This Thread:
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
Powered by vBulletin® Version 3.7.0
Copyright ©2000 - 2009, Jelsoft Enterprises Ltd.
XtremeSystems
