XtremeSystems Forums
Reply
Old 09-22-2009, 06:04 PM   #1
the_real_7
the_real_7's Avatar
Primochill Typhoon III with Swiftech MCP 655
Im ordering the Primochill Typhoon III to clean up some of the hoses inside my system especially the long one traveling from the pump on the bottom to the radiator on top , and also to get rid of it being a pain in the ass to get the air out of my reservoir , now my question is my Swiftech MCP 655 the same as a laing D5 and will it fit the PTIII housing ?
__________________
Gigabyte GA-EP45-UD3P Bios F8
Intel Quad Core Q9650 9/03/09 1.25 vid Fusion Block
3.0 ghz @ 4.0 ghz 9x450 4.4.4.12
G.SKILL PI Black (2 x 2Gb) DDR2 900 4.4.4.12
CORSIAR TX850W
Diamond 4870X2 Stock
WD WD6400AAKS 640GB 7200 RPM sata Raid-0
Seagate 500 7200.11 gig jbod
Creative x-fi
Vista 64bit
Windows 7 64bit
the_real_7 is offline   Reply With Quote
Old 09-22-2009, 06:09 PM   #2
space_pope
Yeah, they are the same. It's just a re-branded LAING D5
space_pope is offline   Reply With Quote
Old 09-22-2009, 07:03 PM   #3
millertime359
Xtreme Mentor
millertime359's Avatar
Your good to go, good luck on build.
__________________
Project Millertime: The Core I5 build
Crunching/folding box on air: AMD Athlon X2 7750 Black Edition; Sapphire Radeon HD 4830; Gigabyte MA78GM-US2H; Lian Li PC-V351; Windows 7 RC
millertime359 is online now   Reply With Quote
Reply
Thread Tools
Rate This Thread:
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
Powered by vBulletin® Version 3.7.0
Copyright ©2000 - 2009, Jelsoft Enterprises Ltd.
XtremeSystems
