XtremeSystems Forums
Reply
Old 09-22-2009, 05:49 PM   #1
gordy
RAM waterblocks?
does there exist any nice blocks for RAM?
I've seen only these:
http://www.frozencpu.com/cat/l2/g30/...locks_RAM.html
any copper ones, maybe thin enough to cool a full block of dimms?
gordy is offline   Reply With Quote
Old 09-22-2009, 05:51 PM   #2
WhiteFireDragon
Xtreme Cruncher
WhiteFireDragon's Avatar
Send a message via AIM to WhiteFireDragon
there's some custom ones, but other than that, OCZ has some integrated ones with their FLEX model.
edit: i just remembered corsair just release one too, but it's pretty fugly.
__________________
e8600 @ 4.5ghz
rampage extreme
hd4650 512mb
2x1gb tracers
audigy 2zs
120gb vertex
HX520w
WhiteFireDragon is offline   Reply With Quote
Old 09-22-2009, 05:56 PM   #3
overclocking101
overclocking101's Avatar
i hear mips makes one i think its mips
__________________
MAXIMUS RAMPAGE SE::::E8400 E0(1.25V VID)@4500MHZ::::2XHD4870512MB::::8GB CRUCIAL DDR2 800MHZ::::WATERCOOLED::::ULTRA 1KW 12V SINGLE RAIL PSU::::WIN7 X64
http://ocguru.webs.com/
overclocking101 is offline   Reply With Quote
Old 09-22-2009, 06:10 PM   #4
gordy
This one from MIPS just seems silly..
ideal would be like this but copper instead of stainless steel
Old 09-22-2009, 06:14 PM   #5
gordy
OCZ flex looks cool indeed.. ouch though $$$
edit: according to the reviews on newegg these blocks are alu and there are reports of leaking issues!
Old 09-22-2009, 06:47 PM   #6
Boogerlad
the mips is the most pointless thing I've ever seen.
Boogerlad is offline   Reply With Quote
Old 09-22-2009, 06:50 PM   #7
Edward88
Yep, the heatsink is made with alu, and water get in contact with it.
Not a good choise really.
Also is useless to watercool ram, with a decent heatsink and a little air flow in the case you should be fine
Edward88 is offline   Reply With Quote
Old 09-22-2009, 07:22 PM   #8
Spawn-Inc
Spawn-Inc's Avatar
the reason there are no good commercial blocks is ram doesn't need water cooling, just a well positioned fan.
__________________
CPU: Core2Quad q6600 G0 3.5GHz@1.4v (highest so far 4.2GHz)
GPU: XFX 9800GTX @ 850/1230
Ram: Samsung 4GB (4x1GB) 700MHz PC5300
Mobo: EVGA-NF68-A1 680i (P32)
PSU: Enermax Galaxy 850Watt DxX
HDD:WD5001AALS, ST3250410AS, ST3500410AS, ST3500320AS - 1.75TB
DVD: LG H26N,LG GH20LS10 both sata
LCD: Samsung 32" LN32A450, Samsung 226BW 22" wide
Sound: Logtiech Z 5500/Razor Barracuda HP-1 / AC-1
CPU & GPU: 3x Swiftech MCR320, 2x MCP655, MCW60 R2, Dtek Fuzion V2, 18 high speed yates @ 5v
3Dmark06:17,814 AquaMark:190,865
Spawn-Inc is offline   Reply With Quote
Old 09-22-2009, 07:36 PM   #9
EnJoY
XIP
EnJoY's Avatar
Send a message via ICQ to EnJoY Send a message via AIM to EnJoY Send a message via MSN to EnJoY Send a message via Skype™ to EnJoY
RAM blocks are useless these days. Back in the BH5 days they may have made sense from a heat standpoint, but not today. Cool air is all that is needed, even for the most extreme sets.
EnJoY is offline   Reply With Quote
Old 09-22-2009, 07:51 PM   #10
NaeKuh
Post Soapbox Destruction
NaeKuh's Avatar
^ +1 to this...
Unless u cant get a fan anywhere near your ram, i honestly think a ram block is pointless.
And im running 12gb's of DDR3.
__________________
Nadeshiko: *Undergoing Rebuild*
Haruhi: i7 975 12GB DDR3 eVGA Classified *Haruhi -> Nadeshiko*
Lind: Dual Gainestown 3.07
NaeKuh is offline   Reply With Quote
Old 09-23-2009, 05:40 AM   #11
PaulyD
Originally Posted by NaeKuh View Post
^ +1 to this...
Agree. Running 12gb here and with zero airflow would get seriously toasty, a bit of airflow over it and its as cool as anything now. Was thinking about getting a block for it just to avoid having any more fans but in the end got the Dominator RAM cooler and set it to run at 50% speed on fan controller and it works a treat.
previously just had a 120mm fan facing towards the RAM and that did the trick too
__________________
Project: Si7ence
Custom V2000 // 920 @ 4.2ghz // 12GB Dominator @ 1603Mhz
Asus P6T6 WS Revo // 7900GT 545/725 // Custom Water
2x500gb Raid0 + 500gb storage // Dell 2407WFP
PaulyD is offline   Reply With Quote
Old 09-23-2009, 06:23 AM   #12
RADCOM
Xtreme Waterbaby
RADCOM's Avatar
You might not need it and it might not be cost effective but it sure looks good.......he said justifying his OCZ flex and Koolance memory blocks.
__________________
Respec'
System:Bunch of crappy overclocked PC's that cost an arm and a leg
"A Caesarean Milks Stops Wort"-anagram
RADCOM is offline   Reply With Quote
Old 09-23-2009, 07:06 AM   #13
HESmelaugh
HESmelaugh's Avatar
The ones by MIPS are the best looking, IMO. Aqua Computer also make a nice RAM cooler: Link.
As for how the water flows through/amount of cooling area: Who cares? It's not like RAM really needs extra cooling.
HESmelaugh is offline   Reply With Quote
Old 09-23-2009, 09:06 AM   #14
gordy
so RAM probably doesn't NEED watercooling, but in my case airflow is just not gonna happen.. I have two internal radiators pulling from the front and back and one fan exhausting the super hot air out the side.
when I run my torture test (linx, prime95, furmark, hdspeed) it will run for about 10 hours before locking up. I suspect it's the RAM temp as the other important chips are accounted for.
Old 09-23-2009, 09:17 AM   #15
Caoder
Caoder's Avatar
Send a message via MSN to Caoder
uhm start by doin sum wire management o.o;; Edit: what about reversing the fans.. hot air out cold air in.. won't kill the cooling from the rads...also you can probably put a side panel fan with a cut out and wire grill over the ram as an intake.
__________________
Core i7 920 D0 @ 4.2 | 2 x GTX 260 | EVGA x58 SLI | 3 x 2 gb GSKILL Perfect Storm 17066CL9|
CPU under WC/ gtz + 2x mcr220
Caoder is offline   Reply With Quote
Old 09-23-2009, 09:19 AM   #16
Delemon
^ +1 to this...
+1 from me too.
And after seeing that pic of your system... GREAT GOOGLEY MOOGLEY... Cable management, good sir, cable management!!
Perhaps you could mod a blowhole and mount a fan on the top of your case between the optical drive and PSU?
__________________
In Progress:
EVGA X58 Classified w/EK-FB full board block | Core i7 920 w/ Enzotech Sapphire | 6GB Gskill Trident F3-16000CL9T-6GBTD | ATI Radeon 4870 1GB | Hitachi 320GB HD x2 | Hitachi 1TB HD x2 | PCP&C Silencer 750W PSU | D5 Vario w/EK-D5 v2 | MCR320-QP w/cheap Yates (for now)
Delemon is offline   Reply With Quote
Reply
Thread Tools
Rate This Thread:
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
Powered by vBulletin® Version 3.7.0
Copyright ©2000 - 2009, Jelsoft Enterprises Ltd.
XtremeSystems
