Watercooling is better than air we know that, but by how much more.
How do we base this on what, a basic set up. CPU only pump, rad, block, res, fans?????????????
Im kinda confused to how much more powerfull WC is over air cooling on a project im working on that will use water maybe as the cooling if it can be proven to be better than air cooling but it's not for a pc but along the lines of pc stuff.
Im finding it hard to put the question into words really.
Say thus
AC can do 100w @ 60c
WC can do 100w @ 40c
Thats a 20% increase in cooling is it not?
Someone please help, im being really thick
__________________ .:Melted's Hardware:.
.:My Workstation::Sorta Done:.
.:Intel E4300@3ghz(375*8):2gb G.Skill HZ 6400@500mhz:Sapphire X1950pro:Gigabyte GA-G33M-DS2R:550w FSP Blue Storm:80gb and 160gb WD SATA2:Cheap MATX Case:.
.:Panasonic Toughbook CF-T2:.
.:Pentium M 753 (900mhz ULV):256MB:40GB:12.1" Touchscreen:. .:Not too shabby for a 2.4lbs of pwn:.
I've been using Intel ever since AMD put an end to my socket A fun. I was almost going to go back when I saw the cheap AM2 chips, but they suck Viva La Chipzilla!
Far too many variables to even begin to make accurate predictions on a percentage basis. Give us more details and possibly we could help out some more.
__________________
Rig specs
CPU: i7 920 @ 3.8GHz Mobo: eVGA Classified 760 RAM: 3x2GB OCZ DDR3-1866 Reapers @ 1,800, CAS-8 VGA: Sapphire HD5870 @ Core 900 Mem 1,250
HDD: 6x WD6400AAKS in RAID-6 powered by Highpoint RocketRaid 3520 SFX: Auzentech X-Fi Prelude
PSU: Corsair HX-1000 Case: Silverstone TJ-09 modded for WC OS: Win7 RTM x64 Liquid-cooled
Sub-loop One: EK-Supreme -=- MCR320, 3x Scythe S-FLEX "F" fans -=- 7/16" Pro-LRT -=- 7/16" BP compressions-=- MCP655 w. Typhoon III Sub-loop Two: EK Classified FC -=- 2x MCR120, Scythe S-FLEX "F" fans -=- 7/16" Pro-LRT -=- 7/16" BP compressions-=- MCP655 w. Typhoon III Peripherals
-=- Dell 2408WFP rev.A01 -=- Audio Technica ATH-AD1000 -=- Razer Mamba -=- Microsoft "Natural Ergonomic 7000" keyboard -=-
The main reason why water cooling is better is because the increased surface area of which the heat can be exchanged. And it's very easy to increase the heat exchange area for WC compared to AC.
There are other factors of course as well. Such as air resistance in the fins (both for air and water) etc.
__________________
I Are DuneCat
I Controls The Spice
I Controls The Universe
Cooler Master ATCS 840 | Corsair HX 520W | Asus P5Q Pro | Q9550 | HD4870 | Corsair Dominator 4GB PC8500 |
D-Tek FuZion v2 - EK RES 150 - Swiftech MCR-220/320 - Swiftech MCW-60 - DDC 3.2 + Petra's Top
I want to replace the condesner thats cooled via air as i have a lack of space for the ideal or perfectly sized condenser it would seam for the size of the compressor i have. The compressor is part of the heat load as too what im going too cool with it. The idea is/was that i could maybe use water cooling on a pipe in a pipe HX to replace the air cooled condenser if water proved powerfull enough. I just need some hard core figers or something to work with other than Bazx and Sachs working.
water will not get u better overclocks unless u were heat limited.
What is heat limited?
Well lets per say, if your chip can do 1.4vcore on air and pull 80C, then on water it could probably do it at 1.55vcore Thats ASSUMING ur chip can overclock higher @ 1.55Vcore.
However if you have a bad chip and its cap'd at a GHZ @ 1.475vcore, water will NOT help you overclock.
Originally Posted by Caoder
usually to achieve the amount of cooling wc can reach.. air is usually MUCH louder.
^ this is usually the advice i normally give.
And not a promised Overclock increase.
Just a single data point but my system (see sig) went from 79-80 deg C at ful load at 4.1GHz to 65 deg C under water (also in sig). So a full 15 deg C improvement.
u really cant tell people there gonna get X benifit.
Souls said it best because were missing a ton of variables.
Also what was the sink in comparision, whats your water system now.
Your gonna net a better delta if you were on stock and now your on a MCR320. vs if you were on a TRUE and now your on a MCR120.
This is why its impossible to answer the question with the an exact answer the op is looking for.
You watercool more because its fun, the performance and lower sound noise is a bonus.
But an Air system will net about 80-90% of what a water system can do.
The main factor is are you gonna have fun when its watered?
Appreciate the difficulty of providing a real answer without more data from the OP. Did you read my thread? That provides the background to the comparison in my case. I did say it was just one data point
__________________
Main Rig:
Intel Core i7 920 D0 @ 21 x 200 (4.2GHz) 24x7 / Gigabyte GA-EX58-UD5 / Seasonic 600W PSU / Sapphire HD 4870 Vapor-X / OCZ Intel i7 6GB (3x2GB) DDR3 PC3-10666 / Heatkiller 3.0 Cu mounted vertically, XSPC RX360, XSPC Res Top on Swiftech mpc355 / Coolermaster HAF 932 / Vista Home Premium x64
Say thus
Im moving from air
Xigmatec 1284EE and 125cfm 120mm fan
Phenom2 965@1.47v 3.9ghz
idle 35c/ game load 51c / prime95 load 55c
to water
Enzotech Sapphire waterblock
Watercool MO-RA 2 Extreme Rad
XSPC dual bay res/pump
so I will definitely be getting some results between the 2 setups within the next week or so as Im waiting on the rad.
__________________
Phenom 965 BE@4.1ghz
Enzotech sapphire/Mo-Ra extreme rad
Asus M3A79-T Deluxe
ht 2200mhz / nb 2800mhz
2x2gb Gskill ddr1066 5,5,5,15,24,2T
Sapphire 4850x2
Enermax Infinity 650 crossfire
case: XCLIO A380PLUS-BK
Water has a higher specific heat capacity than air. This means you can dump much more heat energy into water compared to air, before it's temperature will raise by 1 degree.
To the OP, what fans are you planning on using? And will that pump work well with that HUGE rad??
If water has say 5-7c more over air then thats good too me. It'll just be a case of i need to make a coil that big enough to cool 1.5Kw/1500w/5119.5BTU.
Think i need to come up with a different layout on my coil, as to wrapping it around a round object. Might be better if i wrap it around a wodden block say 4.75'' wide and 2.5'' thick. Like this...
Fan are looking to be Delta 220CFM's, they are going to be need to move air over the compressors but will draw cool air in first and suck through the rad.
Personally, i think this is in the wrong forum, since you're really asking about phase cooling, just using water to replace a condenser. Well.. you might be able to beef up a condenser with water, but cooling 1500w on water == never gonna happen with common place stuff, maybe the radiator from an IROC with some sort of iwaki bilge pump. But even with water you'd need a radiator for that to vent the heat displaced into the water, so i don't see how it would save you any space in the phase installation.
__________________
Cooling: Custom SS made by RunMC of under-the-ice.com 80L Cryofab CL80 Dewar Otternase EEAL.CU Tried: e8400,q6600,qx9650 Subzero queue: AMD Athlon 64 3000+,3200+,3500+ winchester, 3500+ newcastle, 3500+ Orleans, 3700+, 4000+, 4200x2+ & DFI LP Ultra
Intel P4: 520, 631
w3550+Bloodrage GTI,
asus commando Inbound: sdumper SS
In the end it will still be air cooled. Only you will have a water loop in between.
The water must be cooled by air. Since you can get a better cooling performance from your water radiator then from your air radiator, water cooling can be more efficient
You can get a much larger heat transfer from your processor to the water, but this extra heat must be transferred at your water radiator as well. The problem is the driving force. The driving force for heat transfer is proportional to the temperature difference and the area available for heat transfer. The temperature difference between water and air is much smaller than the temperature difference between the processor and air, but since you can get a much larger surface area at your water radiator this problem can be overcome.
Of coarse this is a very simple explanation, but in essence it is correct. In the end the air must cool the radiator (directly at the processor or indirectly via a water loop).
Reason: typo
Sod it, going to do some test with the rig and see what happens
