XtremeSystems Forums
Reply
Old 09-21-2009, 02:05 PM   #1
ed.howell
Need help using some old W/C parts on new system!
Hi guys,
Well after a long couple years out of the loop, no pun intended LOL, I decided to upgrade to the system in my sig. For now I am considering/debating on watercooling only the CPU or just sticking with good air cooling if the W/C parts I have aren't worth the trouble or waste of time.
Here are the parts I have lying around:
Dangerden Heatercore with shroud
Weapon Heatercore with shroud
Swiftech MCP600 pump
Swiftech MCP650 pump
Probably about 8-10 Sanyo Denki San Ace 120mm fans
Obviously my old waterblock won't work, so I picked up a
Swiftech Apogee GTZ. (only have a couple more days to return it if I decide to go with good air cooling.)
My case is the original CM Stacker.
I would like some comments/suggestions/opinions on what I should do.
Sell everything and start over? Use what I have for now? Just go with good air cooling?
Thanks in advance!!!
Ed
__________________
920 DO @ 4015Mhz 191X21 1.280Vcore HT on, Speedstep, Energy Saver and all other settings enabled!!
MCP600--Dangerden heatercore--Apogee GTZ--Weapon heatercore back to the pump with a T-line. All fans are 120mm Sanyo Denki San ace's--Temps between 56-61C
Asrock X58 Xtreme, 6GB Corsair XMS3 1530Mhz 8-8-8-24 1.639V, QPI-3441Mhz, NB-3441Mhz, VTT-1.27, CPU PLL-1.82
Evga 260 Superclocked
Corsair 620HX PSU
Windows 7 Ultimate 64bit
8 Seagate internal HD's totalling 2.5TB, Need to consolidate to fewer larger drives!!
2 Seagate external HD's also totalling 2.5TB's
The Original CM Stacker Case
Heatware
ed.howell is offline   Reply With Quote
Old 09-21-2009, 02:35 PM   #2
faster3200
faster3200's Avatar
How big are the heatercores?
With your current parts list you could certainly build a good CPU loop with that. Except the San Ace need to go away... to me.
__________________
"Everything is amazing and nobody is happy".
- Louis CK
faster3200 is offline   Reply With Quote
Old 09-21-2009, 03:02 PM   #3
ed.howell
Oops, guess the size of the heatercores would help!!! They each hold (2) 120mm fans.
The Dangerden heatercore is 2" x 6" x 9.5"
The Weapon heatercore is 2" x 5.75" x 10.75"
Whats wrong with the San Ace's? Especially if they are undervolted. Any fans you would personally recommend that are quiet and provide good air flow?
Thanks,
Ed
__________________
Corsair 620HX PSU
Heatware
Old 09-21-2009, 03:41 PM   #4
Petra
I am Xtreme
Petra's Avatar
Send a message via AIM to Petra
Nothing... faster just wants yours
Anyway, it looks like you have a pretty good cache of parts there--should be great for a CPU loop
__________________
I'm doing science and I'm still alive...
Petra is offline   Reply With Quote
Old 09-21-2009, 03:43 PM   #5
faster3200
faster3200's Avatar
You could use either the MCP600 or the MCP650. The 650 won't perform as well and will be louder, but is a solidly built pump where as the 600 (rev1) had issues iirc. If you have a rev2 you should be good. The 650 is a D4 which is slightly better than a MCP655-B or Vario at setting 4. So both of your pumps are better than some commonly used ones. You could go with one of those rads and have decent temps with those fans+shrouds. Going with both might be slight overkill, but your temps should be great.
San Ace are great fans. I was just joking, hence the "go away to me".
__________________
- Louis CK
Old 09-21-2009, 03:58 PM   #6
millertime359
Xtreme Mentor
millertime359's Avatar
I misread that too. Good luck with the build.
__________________
Project Millertime: The Core I5 build
Crunching/folding box on air: AMD Athlon X2 7750 Black Edition; Sapphire Radeon HD 4830; Gigabyte MA78GM-US2H; Lian Li PC-V351; Windows 7 RC
millertime359 is offline   Reply With Quote
Old 09-21-2009, 04:54 PM   #7
ed.howell
Yeah I definately misread that one!!!! Thought you meant "in your opinion"
How could I tell if my 600 was a rev1 or rev 2 (the serial # is S010002369 if that means anything)? I can't find a rev# anywhere on the pump.
Nevermind, its a rev2 (google is amazing ). Any serial # starting with an S is a rev2 FYI.
How would you guys set the loop up using the 600 and both heatercores? You said that using both heatercores might be overkill. How much do you think it would actually help? For a couple degrees C its probably not worth it.
Where would you put the rads? I could put them both right off the back of my case by making a custom bracket/spacer at work. Or I could put one at the bottom of the case and make a bracket for the second off the back of the case. I can fit the weapon heatercore and shroud in the front of my case but I lose all of my hard drive space. I really dont want to start cutting up my case.
Thanks,
Ed
__________________
Corsair 620HX PSU
Heatware
Old 09-21-2009, 04:56 PM   #8
ed.howell
Glad I wasn't the only one!!
Thanks!!!
__________________
Corsair 620HX PSU
Heatware
Old 09-22-2009, 04:20 AM   #9
ed.howell
Any suggestions from post #7?
Thanks,
Ed
__________________
Corsair 620HX PSU
Heatware
Old 09-22-2009, 09:33 AM   #10
faster3200
faster3200's Avatar
Thanks,
Ed
I can't say exactly how much difference there would be, but for a CPU only loop certainly <5C probably closer to <3C depending on what speed you run the fans at.
I'm not sure where you would put them since idk what your space is like. Hanging them off the back is always a decent option.
__________________
- Louis CK
Old 09-22-2009, 09:55 AM   #11
ed.howell
Ok, thanks for your help!!!!
__________________
Corsair 620HX PSU
Heatware
Reply
Thread Tools
Rate This Thread:
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
Powered by vBulletin® Version 3.7.0
Copyright ©2000 - 2009, Jelsoft Enterprises Ltd.
XtremeSystems
