XtremeSystems Forums
Go Back   XtremeSystems Forums > Cooling > Vapor Phase Change Cooling
Reply
Old 09-21-2009, 10:41 AM   #1
Snowman89
Building a loaddummy
Finally ive started on my ss. But now i need to make a loaddummy. I have a 62x62mm tec specced for 320w at 15.4v Could i make it into a dummy? Or would it simply be easier to get a cartridge heater? Another problem im having is i cant find any cartridge heaters here in sweden, are there no resellers here? :S
Would be happy if i could use my tec but im open for suggestions. The evap has a diam of 42mm.
Snowman89 is offline   Reply With Quote
Old 09-21-2009, 10:54 AM   #2
MeltedDuron
Dothan FTW!
MeltedDuron's Avatar
Send a message via AIM to MeltedDuron Send a message via MSN to MeltedDuron Send a message via Yahoo to MeltedDuron
If you read a more here the argument with tecs was short lived. In short no you can't and using cartridge heaters is the only way
__________________
.:Melted's Hardware:.
.:My Workstation::Sorta Done:.
.:Intel E4300@3ghz(375*8):2gb G.Skill HZ 6400@500mhz:Sapphire X1950pro:Gigabyte GA-G33M-DS2R:550w FSP Blue Storm:80gb and 160gb WD SATA2:Cheap MATX Case:.
.:Panasonic Toughbook CF-T2:.
.:Pentium M 753 (900mhz ULV):256MB:40GB:12.1" Touchscreen:. .:Not too shabby for a 2.4lbs of pwn:.
I've been using Intel ever since AMD put an end to my socket A fun. I was almost going to go back when I saw the cheap AM2 chips, but they suck Viva La Chipzilla!
MeltedDuron is offline   Reply With Quote
Old 09-21-2009, 11:11 AM   #3
Riska
Riska's Avatar
Look here they ship to sweden..
http://dk.rs-online.com/web/
or here
www.mouser.com
__________________
The man with the littel Barebone!
And proud Crew of!!!
Octeamdenmark.com
Shuttle SX38P2Pro Barebone E8600cpu and HD4870X2 gfx and 2gig Crusial Ballistix PC8500 Cl5 and 2x150gig Raptor in raid 0 and 1x750 gig seagate
Msi 790FX-GD70 Mobo Amd 955-965 PHII cpus and 2gig Crucial value PC10600@800mhz 7-5-5-15 1T
And 4x500GB Seagate 7200.12 in raid0
4xHD5770 in CFQ.
Riska is offline   Reply With Quote
Old 09-21-2009, 11:16 AM   #4
Snowman89
or here
www.mouser.com
Would this do it?
http://dk.rs-online.com/web/search/s...3762391#header
The shortest i could find. Then just simply drill it into a copper/alu piece?
Edit: Seems like they dont ship to sweden because i can only pick denmark when i create a account there. You also have to have a company to buy from them
Old 09-21-2009, 11:51 AM   #5
Riska
Riska's Avatar
Yes that wil do fine
__________________
Octeamdenmark.com
4xHD5770 in CFQ.
Old 09-21-2009, 12:57 PM   #6
SexyMF
Needs more time
SexyMF's Avatar
Sweden has RS components. Since I can't read the language you will need to search for trade counters. You can do a cash sale at trade counters (I've used RS in New Zealand for many years)
http://se.rs-online.com/web/search/s...6-2391&x=0&y=0
SexyMF is offline   Reply With Quote
Old 09-21-2009, 01:31 PM   #7
Snowman89
Ah great I just rememberd the next problem... Its hard and very expensive to find copper/alu in sweden.. I was "offerd" a piece that was 100mm high and a diam of 65mm for about 100euro..
Reply
Thread Tools
Rate This Thread:
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
Powered by vBulletin® Version 3.7.0
Copyright ©2000 - 2009, Jelsoft Enterprises Ltd.
XtremeSystems
