XtremeSystems Forums
Reply
Old 09-21-2009, 08:28 AM   #1
Weevil
Obsessed Member
Weevil's Avatar
Send a message via ICQ to Weevil
Effectiveness of fan shrouds?
Has anyone read any reviews, or have experience with the effectiveness of fan shrouds on radiators and cooling, do they help diminish the dead spot from the center of the fans?
Reason I am asking, is because I just ordered two new rads (magicool elegant triples) to replace my Swiftech doubles, and was wondering if I should bother with the shrouds, and if so, any recommendations on a brand or type?
Right now on my doubles, I cut the guts out of 4 old 120mm fans and used them as shrouds, I never tested with and without them so I don't know if they are doing anything other than taking up more space.
thx, any input would be greatly appreciated.
__________________
wEeViL
Browser: Intel QX9650 (3.0GHz) @ 3.6 | Water Cooled by Swiftech | Asus P5E3 Deluxe | 4GB Corsair Dominator DDR3 SDRAM 1800 | eVGA GTX 285 SSC | Customized Lian Li B25B | Antec Signature SG850 PSU | Windows 7 64 RTM
Gamer: Intel i7 920 (2.66) @ 4.0 | Water Cooled by Swiftech | ASUS Rampage 2 Gene | 6GB Corsair Dominator 1866 GT's | 2xGTX 280's | Banchetto 101 Bench Table | Antec Signature SG850 PSU | Windows 7 RC1 x64 Ultimate
Weevil is online now   Reply With Quote
Old 09-21-2009, 08:31 AM   #2
SoulsCollective
Xtreme Cruncher
SoulsCollective's Avatar
Yes, shrouds do help - there's a reason folks invented them. Shrouds will increase your airflow through your rads without increasing noise levels, but there's no exact formula to tell you exactly what to expect. For 120mm fans, the optimum shroud distance is from memory somewhere between 20 and 40mm - so old 120mm fans work just fine, no need to buy custom built shrouds when you can cheap out for the same benefit.
The important thing is to make sure that you're getting a good seal, though, so you have a sealed airflow pathway all the way to the rad surface. Air leaking out the sides is going to dramatically decrease performance, and may even give you worse performance than without the shroud.
__________________
Rig specs
CPU:
i7 920 @ 3.8GHz Mobo: eVGA Classified 760 RAM: 3x2GB OCZ DDR3-1866 Reapers @ 1,800, CAS-8 VGA: Sapphire HD5870 @ Core 900 Mem 1,250
HDD: 6x WD6400AAKS in RAID-6 powered by Highpoint RocketRaid 3520 SFX: Auzentech X-Fi Prelude
PSU: Corsair HX-1000 Case: Silverstone TJ-09 modded for WC OS: Win7 RTM x64
Liquid-cooled
Sub-loop One
: EK-Supreme -=- MCR320, 3x Scythe S-FLEX "F" fans -=- 7/16" Pro-LRT -=- 7/16" BP compressions-=- MCP655 w. Typhoon III
Sub-loop Two: EK Classified FC -=- 2x MCR120, Scythe S-FLEX "F" fans -=- 7/16" Pro-LRT -=- 7/16" BP compressions-=- MCP655 w. Typhoon III
Peripherals
Dell 2408WFP rev.A01 -=- Audio Technica ATH-AD1000 -=- Razer Mamba -=- Microsoft "Natural Ergonomic 7000" keyboard -=-
Foundational Falsehoods of Creationism
SoulsCollective is online now   Reply With Quote
Old 09-21-2009, 08:34 AM   #3
Fafeifa
Fafeifa's Avatar
Shrouds are a waste of space, just put another set of fans on the other side and enjoy better temps. In cases where space is a premium shrouds are a NO NO.
__________________
Fafeifa is offline   Reply With Quote
Old 09-21-2009, 09:28 AM   #4
Equinediver
Equinediver's Avatar
Totally disagree.
Take a look at this report/test of Martin's
http://martin.skinneelabs.com/Radiat...ng-Review.html
__________________
i7 975 EVGA X58 Classified 6Gb Corsair Dominator GT 2 x EVGA 285 FTW 2x 300Gb Velociraptor in RAID 0 WD Black 500Gb
WC loop 1: HK 3.0 Fesser 360 BP VREG BP NB D5 pump
loop 2: 2 x EVGA HC's Fesser 240 D5 pump
Equinediver is offline   Reply With Quote
Old 09-21-2009, 09:33 AM   #5
Waterlogged
I am Xtreme
Waterlogged's Avatar
Originally Posted by Equinediver View Post
Totally disagree.
+1
__________________
Waterlogged is offline   Reply With Quote
Old 09-21-2009, 09:34 AM   #6
DeathWalking
Enjoy better (~.6C) temps at the cost of doubling the noise vs. adding a shroud. Hmm, that's a toughie.
DeathWalking is offline   Reply With Quote
Old 09-21-2009, 12:15 PM   #7
millertime359
Xtreme Mentor
millertime359's Avatar
Totally disagree.
Great review.
The shrouds also help to remove that dead spot that the fan hub creates.
__________________
Project Millertime: The Core I5 build
Crunching/folding box on air: AMD Athlon X2 7750 Black Edition; Sapphire Radeon HD 4830; Gigabyte MA78GM-US2H; Lian Li PC-V351; Windows 7 RC
millertime359 is offline   Reply With Quote
Old 09-21-2009, 12:23 PM   #8
Jah
If you got the space it's a noise free performance increase. Push/pull will make more noise.
__________________
"I don't have a masters degree, but even I know that mixing water and electronics is a stupid thing to do."
My girlfriend.
"It's easy to get sideways at first thinking there is ONE BEST product for each area of water cooling. But, that's not always the case - depends on your exact setup and needs."
shazza
Jah is offline   Reply With Quote
Old 09-21-2009, 01:50 PM   #9
NaeKuh
Post Soapbox Destruction
NaeKuh's Avatar
B4 u guys lash reread his statement.
Because from my point of view he's correct, and all you other guys are wrong.
Totally disagree.
So a push pull is less effective then a pull + shroud?
Umm no... push + pull > Push or Pull + shroud.
No, your assuming that your gonna run both the push and pull fans @ the same voltage of the single fan + shroud.
This is false because u will get almost 2x the pressure off the fan combo.
So in essense each fan will be turned 1/2 to 2/3rds the normal voltage. So your noise wont be that much more noticiable.
No it wont because you will require less voltage to get the same performance. You guys arent understanding it from the net benifit point of view.
Think carefully, lets assume 1 fan puts out about 80cfm and after the rad u get a 50cfm @ 12V.
Now u add 2, so you have 2 fans puts out 160 cfm, however the loss after the rad is smaller because of the push pull, so you get around 130cfm.
Do you really need 130cfm? the answer is NO. So you will turn down your push pull to mirror the 50cfm, which translates to both fans putting about 80-90cfm, which means each fan will be at 45 CFM.
Noise is 45cfm x 2 vs 1 80cfm. <--- u still think its louder?
Why is it that everyone automatically assumes push/pull will be louder?
The truth is you will require less voltage to get the same objective from push/pull.
But people quickly forget that and assume your gonna run push pull on max.
Well if thats the case, get 38mm and end it.
__________________
Nadeshiko: *Undergoing Rebuild*
Haruhi: i7 975 12GB DDR3 eVGA Classified *Haruhi -> Nadeshiko*
Lind: Dual Gainestown 3.07
NaeKuh is offline   Reply With Quote
Old 09-21-2009, 01:52 PM   #10
Weevil
Obsessed Member
Weevil's Avatar
Well I defiantly have the space ; )
__________________
wEeViL
Old 09-21-2009, 02:05 PM   #11
NaeKuh
NaeKuh's Avatar
LOL if u guys wanna get into a fan war with me...
Here is my toy i was playing with to get the best fan layout:
Old 09-21-2009, 02:20 PM   #12
Weevil
Obsessed Member
Weevil's Avatar
LMAO, alright, you win!
__________________
wEeViL
Old 09-21-2009, 02:47 PM   #13
sniperbob
sniperbob's Avatar
Send a message via AIM to sniperbob
Naekuh, what's the top speed on that hovercraft??
__________________
Insert inspiring sig image/quote/rig specs here
sniperbob is offline   Reply With Quote
Old 09-21-2009, 04:08 PM   #14
Fafeifa
Fafeifa's Avatar
Wow very well said i couldn't explain it better myself but that is what i meant. I really don't see the application of a shroud because you can run push/pull with undervolted fans and be done with it.
The PA 120.3 shroud is like 40mm thick vs a 25mm fan. Of course the best is push -> shroud -> rad -> shroud -> pull but that is very cumbersome and would be very hard and inefficient to mount it internally for that matter i would rather have 2 radiators with their own set of fans. There are more things to consider rather than the best results from reviews because we are working with constraints when building a custom system.
Sometimes lab testing doesn't mean it works the best in real world, testing afterall give us ideas and guidelines, WC has limits that are easily attainable with couple good rads, fans and a strong or several pumps, the reviews to me are just a guideline and not to be taken word for word because 1C or 2C won't make my system fail and following the reviews word for word may bring more headaches than benefits.
__________________
Old 09-21-2009, 04:12 PM   #15
_G_
<snip>
Now u add 2, so you have 2 fans puts out 160 cfm, however the loss after the rad is smaller because of the push pull, so you get around 130cfm. <snip>
Series (push pull) doesn't work like that, it increases pressure but cfm is never more than one fans rating. at best it will cut you're loss from freeair to radiator cfm.
__________________
“You Americans are so gullible. No, you won’t accept communism outright, but we’ll keep feeding you small doses of socialism until you’ll finally wake up and find you already have communism. We won’t have to fight you. We’ll so weaken your economy until you’ll fall like overripe fruit into our hands." Nikita Khrushchev
_G_ is offline   Reply With Quote
Old 09-21-2009, 04:23 PM   #16
Equinediver
Sheesh, that would need it's own PSU, cable management doesn't bear thinking about
What are you cooling, a nuclear power station?
For me, my shrouds and 25mm fans do the job nicely
__________________
Old 09-21-2009, 04:37 PM   #17
NaeKuh
NaeKuh's Avatar
i was using a very general expression.
And your right using CFM was a very bad example, i should of used static pressure.
But overall i think it gets the message across.
You accomplish = for less when you pair up was the notion i was trying to get into.
__________________
Old 09-21-2009, 05:24 PM   #18
Weevil
Obsessed Member
Weevil's Avatar
What kind of shrouds are you using?
__________________
wEeViL
Reply
Thread Tools
Rate This Thread:
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
Powered by vBulletin® Version 3.7.0
Copyright ©2000 - 2009, Jelsoft Enterprises Ltd.
XtremeSystems
