XtremeSystems Forums
Reply
Old 09-21-2009, 07:04 AM   #1
MaByBoI
Xtreme Cable Management Freak
MaByBoI's Avatar
swiftech epsilon reviews?
Has anyone used the swiftech epsilon yet? or seen any reviews for it? i cant seem to find any... are there better blocks out there? or is this one, one of the top?
thanks!
__________________
Blood(Rage) shall be spilt
Intel Core i7 | Enzotech Sapphire
EVGA GTX 295 co-op | Swiftech Epsilon
Foxconn BloodRage | BloodRage Waterblock
OCZ Platinum 6gb DDR3 | GTX 480 QUAD rad
Corsair HX1000W | MCP 655
Silverstone TJ-07 | FrozenQ T-Virus Res
WD 1TB Black | Distilled Water
I also have a Macbook Air
MaByBoI is offline   Reply With Quote
Old 09-21-2009, 08:33 AM   #2
justin.kerr
I am Xtreme
justin.kerr's Avatar
I have a couple, install is very easy, looks very good, IMHO. but can't tell you performance numbers yet, been waiting on MM for a case since July...
__________________
MM Ascension case,
Classified, 920 @ 4.6Ghz,
(2) toxic 4890's @ 1000,
Mushkin redline ascents 6gb, 1768 Mhz 7-7-6-19
(8) intel x25m RAID 0 on LSI 9260
heat killer, 2 swiftech mcr 320's, feser 360, Xspc Rx360, EK full coverage MB WB. 655 with detroit top, 355 with Xspc top
justin.kerr is offline   Reply With Quote
Old 09-21-2009, 11:42 AM   #3
MaByBoI
MaByBoI's Avatar
i cant seem to find a review ANYWHERE.... hey gabe... wanna send me one and ill write a review for you?
__________________
Old 09-22-2009, 04:29 AM   #4
MaByBoI
MaByBoI's Avatar
no one has seen anything of it yet? no reviews? no temperatures? no personal stories (doesnt include you justin. (thanks!))
Im tempted to buy one, and probably will no matter what.... and since there are no reviews.. i guess i'll be writing one.. but has anyone seen or heard anything?!
__________________
Old 09-22-2009, 05:43 AM   #5
BlueAqua
I am Xtreme
BlueAqua's Avatar
Looks pretty solid. Full cover GPU blocks are rarely reviewed as the temperature differences are negligible and make a minimal impact on performance and overclocking. As long as it fits and your card works I think you're good to go.
http://www.xtremesystems.org/forums/...hlight=epsilon
BlueAqua is offline   Reply With Quote
Old 09-22-2009, 07:46 AM   #6
MaByBoI
MaByBoI's Avatar
awesome, i will be buying one within the next 2 weeks. looks like a beautiful block
__________________
Reply
Thread Tools
Rate This Thread:
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
Powered by vBulletin® Version 3.7.0
Copyright ©2000 - 2009, Jelsoft Enterprises Ltd.
XtremeSystems
