XtremeSystems Forums
Go Back   XtremeSystems Forums > Cooling > Vapor Phase Change Cooling
Reply
Old 09-21-2009, 04:24 AM   #1
Sam__
Sam__'s Avatar
Which compressor
I found two old chiller units in a clear out the other day. I was hoping to get an SS built out of one of them.
Which compressor would be best??
Aspera J6220A 64BA09 - 3/4 HP 230v R-12 H.S.T. Medium Temp
5/8" sea suction Service valve
GS26TB
Nominal motor power [kW]: 1,02
Cylinder count: 1
Displacement [m³/h]: 4,51
Cylinder capacity [cm³]: 25,93
RPM [min-1]: 2900
Weight [kg]: 22,7
Oil charge [dm³]: 0,887
Thats all the info i can find on them.
__________________
"Computers in the future may weigh no more than 1.5 tons."
- Popular Mechanics, 1949
"I think there is a world market for maybe five computers."
- Thomas Watson, chairman of IBM, 1943
Heat
Sam__ is offline   Reply With Quote
Old 09-21-2009, 09:49 AM   #2
Sam__
Sam__'s Avatar
anyone got any ideas which ones best for SS?
__________________
Heat
Old 09-21-2009, 10:05 AM   #3
clear cmos
clear cmos's Avatar
Send a message via ICQ to clear cmos Send a message via AIM to clear cmos Send a message via MSN to clear cmos Send a message via Yahoo to clear cmos Send a message via Skype™ to clear cmos
i think electrolux better than aspera, because your aspera look older than electrolux
__________________
my English is very
clear cmos is offline   Reply With Quote
Old 09-21-2009, 11:51 AM   #4
Sam__
Sam__'s Avatar
aparenlty these are for higher loads and would be better off in a chiller situation.
__________________
Heat
Old 09-21-2009, 12:50 PM   #5
SexyMF
Needs more time
SexyMF's Avatar
I'd use the 3/4 HP Aspera. The 1kW beast is will be badly matched to a single stage unless you plan on a multi-head unit.
The two things I believe are important for compressor selection is HP and application (LBP/MBP/HBP).
The good thing is that you can build everything with a certain compressor and then just swap it out if it doesn't work out.
SexyMF is offline   Reply With Quote
Old 09-21-2009, 01:01 PM   #6
Sam__
Sam__'s Avatar
ooo multi headed unit, i like that idea.
__________________
Heat
Old 09-21-2009, 01:16 PM   #7
fatguy1992
Correct me if I'm wrong but 1kw = ~3500BTU. That is way less then a 3/4hp unit. My 3.5kw unit is only 12000BTU which is a bit over 1hp.
EDIT: I think you might be right, I always get confused converting the kw's.
fatguy1992 is offline   Reply With Quote
Old 09-21-2009, 01:28 PM   #8
bartx
bartx's Avatar
Send a message via MSN to bartx
1kw = 3410 btu
But this is about cooling power, not motor size. At example I have rotary, which is 10700 btu (which is 3,1kw) but motor size is 1hp (750w)
bartx is offline   Reply With Quote
Old 09-22-2009, 05:58 AM   #9
Foamy
Banned
already found some specs on evap temp?
Foamy is offline   Reply With Quote
Reply
Thread Tools
Rate This Thread:
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
Powered by vBulletin® Version 3.7.0
Copyright ©2000 - 2009, Jelsoft Enterprises Ltd.
XtremeSystems
