XtremeSystems Forums
Reply
Old 09-20-2009, 01:55 PM   #1
space_pope
XSPC RX360 vs Swiftech MCR320
Hey guys, so one of my friends told me a while back not to get the XSPC RX360, since the perforance is practically the same as the MCR320. I've seen HESmelaughs reviews on both the radiators, and also skineee's. I'll mainly be running my fans at about 1650 rpm, and based on the charts, it seems like they really are the same
However, I talked to someone and they said that when they switched out rads, they got a 5 degree drop in temps.
So im really confused right now. Can anyone tell me which is right?
space_pope is offline   Reply With Quote
Old 09-20-2009, 02:02 PM   #2
faster3200
faster3200's Avatar
If it was a while back they might have meant the XSPC RS rads, which were about the same price as the Swiftech but worse. The RX are better than the Swiftech rads, but not by 5C. Your friend's 5C temp change was most likely due to a host of reasons.
__________________
"Everything is amazing and nobody is happy".
- Louis CK
faster3200 is offline   Reply With Quote
Old 09-20-2009, 02:11 PM   #3
millertime359
Xtreme Mentor
millertime359's Avatar
+1 on Faster
If you can afford the XSPC RX360, get it. If you are running tight on the budget. The Swiftech will do just fine.
__________________
Project Millertime: The Core I5 build
Crunching/folding box on air: AMD Athlon X2 7750 Black Edition; Sapphire Radeon HD 4830; Gigabyte MA78GM-US2H; Lian Li PC-V351; Windows 7 RC
millertime359 is online now   Reply With Quote
Old 09-20-2009, 03:39 PM   #4
alacheesu
I tend to trust the people with accurate measuring equipment and rigorous testing methodology. The rads really should be the same performance-wise, unless you count fractions of a degree as significant. And if you really want to split hairs, neither of those are the best at that fan speed. The good old Thermochill PA has them both beat, but again by a tiny margin. Possibly the Feser X-changer beats them as well, which IMO is the best radiator as far as finish, features and accessories goes. Too bad it's pretty expensive.
alacheesu is offline   Reply With Quote
Old 09-20-2009, 05:44 PM   #5
meanmoe
The plots say it all. Half the price, near negligible difference in performance at those fan speeds.(my opinion, it's a matter of perspective, as Faster said, not 5C)
You may be on a different curve but the trend is the same. I like swiftech... I just wish they could spray paint as well as they build radiators.
meanmoe is offline   Reply With Quote
Old 09-20-2009, 08:32 PM   #6
skinnee
Addicted to Pie!
skinnee's Avatar
I really need to update the triple radiator comparison...
__________________
skinnee labs test schedule:
In Testing: Too much to list.
Writing Reviews: finally getting my backlog cleaned up too.
Planned Tests: Plan, what the heck is a plan.
skinnee is offline   Reply With Quote
Old 09-21-2009, 07:25 AM   #7
meanmoe
Maybe include SR1 curves?! That'd be nice.
(What you do in your free time is all you, I'm just naturally impatient)
Reply
Thread Tools
Rate This Thread:
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
Powered by vBulletin® Version 3.7.0
Copyright ©2000 - 2009, Jelsoft Enterprises Ltd.
XtremeSystems
