09-20-2009, 07:55 AM
#1
best i7 block
Which is the best i7 block out now? I have not looked into wc stuff since I completed my i7 build/wc setup right after release of i7. I am using a DD cpu block atm.
thanks all
__________________
Core i7 920 @ 3.8ghz
6gb Mushkin XP3-12800
Asus P6T Deluxe
GTX 260 SLI
Audigy X-Fi
PCPC 750w P75QB
42" Philips 1080p LCD
Windows 7 Pro 64
heat: doox00
09-20-2009, 07:59 AM
#2
I've seen some people @ 230 or more
i can only boot @ 218
__________________
09-20-2009, 08:03 AM
#3
depends on what you want
flowrate? good temps? best quality? aesthetics?
my favorite few:
1.EK Supreme
2.Heatkiller 3.0
3.Swiftech GTZ
there is a review thread here which should give you some useful info
__________________
† i7 ES 4.2GHz † Rampage II Extreme † OCZ Blade 2GHz†
†CrossFire 4890 1GHz † Full System Water Cooling † TJ07 †
† PROJECT: Bangra †
09-20-2009, 08:07 AM
#5
The best cpu block is the YBRIS BLACK SUN, coming soon  (i have the beta version)
__________________
Sorry for my english
09-20-2009, 08:14 AM
#6
  That was a good one
09-20-2009, 08:26 AM
#7
+1 for the Enzotech Sapphire
It has good performance for a good price.
The same block i have.
__________________
Killer
Core i7 920 @ 4.2Ghz
EVGA X58 758 SLI
2xGTX295's in SLI
3x2Gig Kingston Hyper X 2100mhz
Corsair HX1000 Watt Modular
Water Cooling
3DMark Vantage 41312
09-20-2009, 08:38 AM
#8
__________________
09-20-2009, 08:41 AM
#9
Double post, sorry
__________________
09-20-2009, 08:46 AM
#10
Admin
Originally Posted by Razer(x)
Been looking at that the past 30 minutes or so...my Italian is a little rough (interpolating Latin and Spanish  ), but the performance looks pretty damn good
Does Ybris have an English website? Any other postings about Black Sun to read?
__________________
Current Waterblock Testing
Roundup #2: Overall Comparison Thread, Alphacool Livingstone, Alphacool Niagara, Alphacool Yellowstone, D-Tek Fuzion V2, EK Supreme, EK Supreme LT, Enzotech Sapphire Rev A., Heatkiller 3.0 LC, Heatkiller 3.0 LT, Koolance CPU-345, Koolance CPU-350, Phobya, Swiftech Apogee GTZ, Swiftech Apogee GTZ SE, Swiftech Apogee XT
09-20-2009, 09:30 AM
#11
Yes, it's really good and fashioned (italians do it better  ) but no, there's no other postings 'cause the BS is still in beta (version five)
If somebody needs help can contact me
However there is no english site, but if you need i could translate to ya the words you need
__________________
09-20-2009, 09:39 AM
#12
Ha! I did the same thing.
Here are some pics. Supposedly this block cools around or slightly better than the HK 3.0 while being less restrictive. From what I can gather it is a tweaked Eclipse. This is all speculation or marketing.
Other than that I found a lot of release dates. The ones that make the most sense are November-October.
09-20-2009, 09:49 AM
#13
Wait, this isn't the Black Sun, the one of the link is ONLY a black version of the Eclipse
__________________
09-20-2009, 09:52 AM
#14
Crysis killed my wallet
And? My HK 3.0 kept my i7 @ 4.0 around 65C as well. What's the big deal?
__________________
Bill Cosby: Stewie, what do you think candy is made out of?
Stewie Griffin: Sunshine and farts! What the hell kind of question is that?!
09-20-2009, 10:24 AM
#15
Nope, it is the Black Sun. It clearly says so on the block.
I found multiple new sites with these images on them so I don't think it is a prank.
You can't directly compare results.
09-20-2009, 10:33 AM
#16
when is skinnee coming out with his tests?
__________________
09-20-2009, 10:49 AM
#17
Ok so, i have the Black Sun in my pc, i know if it's the one of the link or not  the REAL Black Sun is still under NDA
__________________
09-20-2009, 11:49 AM
#18
Really? Odd those pics are everywhere. I guess that would make sense though. I was wondering why that thread with tests didn't have any pics of it.
09-20-2009, 11:52 AM
#19
Yeah man
__________________
09-20-2009, 12:34 PM
#20
thanks all
You where given the link the the latest tests of i7 blocks, the "best"
is where it becomes fuzzy  If you have an unlimited budget and access to ALL the various product, then the best is always the lowest temp. with the highest flow. But as can be attested by users here we all run various blocks depending on a host of personal issue's. There will ALWAYS be another "best" just around the corner. Do you need the best? Is 1c-2c difference on the CPU a big deal, I don't think so. So for me it's a balance of what products I can get (geographically) and for what cost.
I'm currently running very old technology with the Fusion v2 and it is working fine, and I could buy it in Canada without bankrupting the bank. Having said that I will be ugrading with my newer rig (this one is 5 weeks old lol). And will be going with an Enzotech Sapphire or Heatkiller depending on what I can get without spending excess cash getting the thing to my doorstep.
I like millertime359's response.
__________________
Mobo: Asus Rampage Gene II
CPU: i7 920 at 3700 Mhz, NO increased volts anywhere.
GPU: Sapphire 4890 Vapor-X
RAM: G.SKILL Trident DDR3 2000 (PC3 16000) 6x2GB
HD's: 2 Velioci Raptor 300 gig + several others
Blu-Ray Writer: Pioneer BDR-203BK
DVD Scanner: Liteon SHW-165H6S DVD
PSU: Corsair HX1000
Case: Obsidian 800D
GPU Cooling: Ek Water Block CF Acetal Full Cover GPU Block 1/2IN G1/4
CPU Cooling: Heatkiller v3
Water Res: Swiftech MCRES-MICRO Clear HI-FLOW Water Cooling Reservoir
Radiator: Feser 360
Pump: Swiftech MCP350 with XSPC top
Fittings: Danger Den G1/4 to 3/8IN High Flow Barb Chrome Fittings
Tubing: 3/8" I.D. Tygon
Cooling Water Conditioning: Petra's Tech Shop ,PT-Nuke and Pentosin G11
OS: Windows Vista Ultimate x64
09-20-2009, 05:07 PM
#21
enzotech sapphire is about the best block out there, behind the hk 3.0. Add it's not just a difference of a shiney top or not with the LT version of the HK, all copper body makes a difference. I'd go with sapphire due to bang for buck, prefer it to my GTZ.
__________________
Cooling:
Custom SS made by RunMC of under-the-ice.com
80L Cryofab CL80 Dewar
Otternase EEAL.CU
Tried: e8400,q6600,qx9650
Subzero queue: AMD Athlon 64 3000+,3200+,3500+ winchester, 3500+ newcastle, 3500+ Orleans, 3700+, 4000+, 4200x2+ & DFI LP Ultra
Intel P4: 520, 631
w3550+Bloodrage GTI,
asus commando
Inbound: sdumper SS
09-20-2009, 05:23 PM
#22
If you google YBRIS BLACK SUN it will list several links with the word 'translate' next to it.
I was reading up on it earlier, translation works pretty well
Block definately looks interesting, needs to get in Skinnee's lab!
__________________
i7 975 EVGA X58 Classified 6Gb Corsair Dominator GT 2 x EVGA 285 FTW 2x 300Gb Velociraptor in RAID 0 WD Black 500Gb
WC loop 1: HK 3.0 Fesser 360 BP VREG BP NB D5 pump
loop 2: 2 x EVGA HC's Fesser 240 D5 pump
09-20-2009, 05:33 PM
#23
I am overall fine with the dd block but temps are not as good as other blocks I have seen reviews on. I suppose 3-4c is not really enough to worry about it. I also have my two 260's in the same loop as cpu.. idle is around 38-42c on cpu, depends on which core you are looking at, loads in the 70's if I am remembering right.. have not done a test on it since I put it all together.
__________________
Asus P6T Deluxe
GTX 260 SLI
Audigy X-Fi
PCPC 750w P75QB
Windows 7 Pro 64
heat: doox00
09-20-2009, 05:35 PM
#24
Xtreme Cruncher
Best performance - HK 3,0 CU.
Best bang for buck - HK LT, Ek Supreme LT, or that Sapphire for you US folks.
09-20-2009, 06:28 PM
#25
Xtreme Guru
HK LT and HK CU are same block, just different top. I think you are referring to the HK LC for your bang for buck.
__________________
Project Millertime: The Core I5 build
Crunching/folding box on air: AMD Athlon X2 7750 Black Edition; Sapphire Radeon HD 4830; Gigabyte MA78GM-US2H; Lian Li PC-V351; Windows 7 RC
| Thread Tools |
| Display Modes |
Rate This Thread |
Linear Mode
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
HTML code is Off
