XtremeSystems Forums
Go Back   XtremeSystems Forums > Cooling > Air Cooling
Reply
Old 09-20-2009, 12:21 AM   #1
pelo911
corsair dominator gt fans , make a lot of noise
dominator-gt 1866 cl7
those fans make much more noise then my intel stock heatsink and all the case fans together.
can i replece them for quiet fans?
pelo911 is offline   Reply With Quote
Old 09-20-2009, 03:21 AM   #2
momomo6789
momomo6789's Avatar
it looks as if you could replace the fans but one you get down to such a small size there all loud or dont move any air for the most part
__________________
I have to be constructive and not spam !!!
Friends don't let Friends buy gaming headphones !!
momomo6789 is offline   Reply With Quote
Old 09-20-2009, 03:48 AM   #3
fallwind
Xtreme Cruncher
fallwind's Avatar
They are 4000RPM fans so yes they are noisy. I run mine on a fan controller and once you go below 2500RPM they are quiet. You can use an inline resistor to slow them down or get a molex to 3 pin adapter and do the 5v or 7v mod on it.
__________________
Gulftown@4305Mhz 1.376v
Gigabyte EX58-UD3R F8D
3x2GB Dominator GT 1640MHz 6-7-6-18 1T
BFG 8800GTX OC 640/1000 EK full-coverage WB
Windows 7 Ultimate x64
HK 3.0-MCP655-Massive car rad!
X-FI XtremeGamer
Silverstone Strider 850w
120GB OCZ Vertex - OS
2.5TB storage
TT Armor VA8003SWA
fallwind is offline   Reply With Quote
Old 09-20-2009, 03:51 AM   #4
Smartidiot89
Smartidiot89's Avatar
Same situation as with my OCZ mem fans, with a 7v resistor they're really quite
__________________
Nvidia GT300 yields are under 2%
Originally Posted by 64NOMIS View Post
I explain CPU's to 3 yr old. CPU = brain for computers. Now thinks CPU is in her brain. Goes to sleep without complaint.
CPU: Phenom II X2 550BE @ X4 B50
Clock: 3600MHz 1.4v 24/7 crunching stable
Memory: 2x2GB 1333MHz 6-6-6-18-24-1T
Motherboard: MSI 790FX-GD70
GPU: HD5850 or HD5870 in November
AMD Forum
Smartidiot89 is online now   Reply With Quote
Old 09-20-2009, 05:33 AM   #5
Camride
Camride's Avatar
FWIW I just had to replace the fans in my OCZ memory cooler because one of them became unbalanced or the bearing died. One was fine but the other made horrible noise and was barely moving any air. Fortunately I had a pair of 40mm fans to replace them with, and I finally got rid of the LEDs!
If they're making alot of noise the fan(s) might be dying. And my OCZ fans were pretty quiet when working properly. Even better hooked up to a fan controller where you can turn them down if you want.
__________________
Gaming/VM Testing Rig:
  • Core i7 920 D0, 4.3Ghz @ 1.36v (with HT/Virtualization on), needs more testing
  • Xigmatek Dark Knight, OCZ Freeze
  • EVGA X58 SLI LE
  • OCZ 12GB Platinum 1333
  • EVGA 8800GT 512 SC
  • Seagate 640GB
  • Thermaltake Armor Jr.
  • Enermax Liberty 500W Modular
  • Windows 7 Ultimate x64
Camride is offline   Reply With Quote
Reply
Thread Tools
Rate This Thread:
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
Powered by vBulletin® Version 3.7.0
Copyright ©2000 - 2009, Jelsoft Enterprises Ltd.
XtremeSystems
