XtremeSystems Forums
Reply
Old 09-19-2009, 09:08 PM   #1
rehpyc
An idea over cable sleeving
Is there a reason why many of you sleeve your entire PSU rather than getting extenders for each major cable (24pin power, 4 pin power, power for GPU(s)) and sleeving only those? Seems like it'd save you the trouble of sleeving again whenever you eventually upgrade your PSU (ie when you decide to go pro with tri-sli and such).
rehpyc is offline   Reply With Quote
Old 09-19-2009, 09:20 PM   #2
Diverge
Diverge's Avatar
People who go through the trouble of sleeving every wire in their case do it for looks, and neatness. If they used extenders, then they'd have ton of extra wire they have to hide somewhere
__________________
[DFI LP Jr P45-T2RS] [Q6600] [8GB G.Skill F2-8000CL5D] [Seasonic S12 600W] [Windows Server 2008 (64bit)] [ATI 1800XL]
[DFI JR X58-T3H6] [i7 920 D0 3849A866] [12GB OCZ OCZ3B2000C9LV6GK] [Corsair CMPSU-750TX] [Windows 7 (64bit)] [EVGA 280 GTX][OCZ Vertex 30GB x3 Raid0]
Diverge is offline   Reply With Quote
Old 09-19-2009, 09:22 PM   #3
Utnorris
Utnorris's Avatar
Probably the main reason is space. Most PSU cables are around 18" to 24" and you would be just adding to that which is a lot to hide. Then there is the look of a fully sleeved PSU, much nicier in my opinion if done right.
__________________
CPUID http://valid.canardpc.com/show_oc.php?id=484051
http://valid.canardpc.com/show_oc.php?id=554982
New DO Stepping http://valid.canardpc.com/show_oc.php?id=555012
4.8Ghz - http://valid.canardpc.com/show_oc.php?id=794165
Mountain Mod UF2O
I7 920 (3849B018)/Blood Rage/ XFX HD5870/ 6Gb (3x2Gb) OCZ 1866 Ram @ 1600 6-6-6-16-1t timings / Inte M-25 80Gb SSD x 2 RAID 0
W/C System
(CPU) Phase (GPU) EK Water Block and Water Chiller / B*P/Koolance Compression Fittings.
Utnorris is offline   Reply With Quote
Old 09-19-2009, 09:59 PM   #4
Spawn-Inc
Spawn-Inc's Avatar
as already stated, if you have the space to hide the extra wire, go for it. but like me, i cannot put my side panel on as there is so many wires it can't close. it's up against the wall so i don't care . 123
__________________
CPU: Core2Quad q6600 G0 3.5GHz@1.4v (highest so far 4.2GHz)
GPU: XFX 9800GTX @ 850/1230
Ram: Samsung 4GB (4x1GB) 700MHz PC5300
Mobo: EVGA-NF68-A1 680i (P32)
PSU: Enermax Galaxy 850Watt DxX
HDD:WD5001AALS, ST3250410AS, ST3500410AS, ST3500320AS - 1.75TB
DVD: LG H26N,LG GH20LS10 both sata
LCD: Samsung 32" LN32A450, Samsung 226BW 22" wide
Sound: Logtiech Z 5500/Razor Barracuda HP-1 / AC-1
CPU & GPU: 3x Swiftech MCR320, 2x MCP655, MCW60 R2, Dtek Fuzion V2, 18 high speed yates @ 5v
3Dmark06:17,814 AquaMark:190,865
Spawn-Inc is offline   Reply With Quote
Old 09-19-2009, 10:11 PM   #5
Darth_Penguin
Darth_Penguin's Avatar
Another option would be to stick with a brand that is fully modular. I have a silverstone st60f that is fully sleeved and when I decide I need more power I will simply order another modular silverstone. all my cables will transfer right over and I will be back in business.
__________________
Banchetto
Intel i7 920 @ 4.20|Asus P6T6 Revolution|G.Skill 6gb DDR3 1600|Sapphire 4890 Toxic|Intel x-25 E 64GB
H2O
HK 3.0 Block|Koolance P6T6 Block|355 w/ XSPC Res Top|Dual MCR320's|EK Acrylic/Nickel 4890 Block
Darth_Penguin is offline   Reply With Quote
Old 09-19-2009, 11:21 PM   #6
faster3200
faster3200's Avatar
As someone who does use extenders (I have to), it is far easier to just pull off the connector and sleeve it than it is to crimp all the wires and pins then sleeve.
__________________
"Everything is amazing and nobody is happy".
- Louis CK
faster3200 is online now   Reply With Quote
Old 09-20-2009, 01:18 AM   #7
WeeMaan
Do you know if the cables on HX850 is the same as on HX620?
__________________
Project TJ07 WeeMaan edition in progress...
i7 920 @ 4,4ghz, P6T Deluxe, Corsair Dominator, Amd 4850 (temp), OCZ Vertex 60gb + Samsung F1 1tb
Heatkiller copper, Thermochill 120.4, DDC 3.2
WeeMaan is offline   Reply With Quote
Old 09-20-2009, 01:45 AM   #8
rehpyc
I was more so thinking of spending the $10-15 in extenders rather than making my own simply because I'd think that's how much it'd be worth not having to sleeve an entire PSU again, haha.
Old 09-20-2009, 09:46 AM   #9
Tom128
It's actually a good idea I never thought of, just sleeve extenders. Would make it easier and faster. I have a sleeved modular PSU so I don't care all too much but for another build that's a nice idea.
On a similar topic, how many of you have tried sleeving your tubing? I ordered 10ft of 1/8" sleeving once from sidewinders and they sent me the wrong stuff, way too big. Since it would cost more to send it back and get replaced I just kept it and sleeved my tubing since I was just about to re-do it anyways. I found out that not only did it look really nice, it acted as a very good anti-kink solution.
__________________
Game Rig: Sempron 140 @ X2 2.7Ghz / XFX 4870 1GB / 2x2GB Dominator DDR2 1066MHz
Cruncher 1: Phenom II 955BE @ 3.5Ghz
Cruncher 2: Phenom 9600BE @ 2.5Ghz
Cruncher 3: Coming soon (hopefully), i7 based.
Tom128 is offline   Reply With Quote
Old 09-20-2009, 11:10 AM   #10
meanmoe
I was planning on doing this because I do plan on swapping out PSUs at some point and I really don't want to go through the expense or trouble of doing it again.
I have 2 cases I was going to do this for. In both cases the PSU is not visible. I was going to chop the 18" power supply connector and put a connector on it and turn the rest of it into an extender. I was planning to do the same with the other non-modular cables as well. This way, the extenders will stay with the case regardless of what PSU I use.
I was curious why this wasn't more common and if there was a problem with it that I didnt know about.
Also, I think you can buy extenders uni-sleeved from frozencpu now, but they're pricey.
meanmoe is offline   Reply With Quote
Old 09-20-2009, 01:01 PM   #11
jpm804
jpm804's Avatar
This is the reason why i'm probably going to just sleeve my PSU. Started with extenders but the extra length and partial the look was not as clean as I wanted it to be.
I noticed some people are not completely uni-sleeving the PSU anymore and stopping halfway or 3/4 which I think I was thinking a good comprimise.
jpm804 is offline   Reply With Quote
Reply
Thread Tools
Rate This Thread:
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
Powered by vBulletin® Version 3.7.0
Copyright ©2000 - 2009, Jelsoft Enterprises Ltd.
XtremeSystems
