XtremeSystems Forums
Go Back   XtremeSystems Forums > Cooling > Air Cooling
Reply
Old 09-19-2009, 08:34 PM   #1
pelo911
core i7 D0 with stock heatsink , 100 degrees on 30% load
ideal temp : around 60
play need for speed shift for 3 min and the temp go to 100
what i can do?
is it normal?
the case is lian li V2010
hd4870
core i7 d0 49b
pelo911 is offline   Reply With Quote
Old 09-19-2009, 08:36 PM   #2
tool_462
tool_462's Avatar
Check to make sure the fan is running and then remount the cooler. They are usually mid to high 70's on the crappy stock cooler at full load.
__________________
i5 750 @ 4.2Ghz 8GB G-Skill RipJaws DDR3-2000 Gigabyte UD3R eVGA GTX275 730/1625/2520
tool_462 is offline   Reply With Quote
Old 09-19-2009, 09:47 PM   #3
pelo911
i remount the heatsink and clean all the dust
the fan work just fine.
and now it's worst
inside the bios the cpu temp is 92
and i can't even go inside the windows , the computer shut down!!
maybe the original paste of the heatsink are dead or not working anymore?
how come my cpu is not dead if it's working so hot for the all last 2 month?
Old 09-19-2009, 09:51 PM   #4
Asylum1
Asylum1's Avatar
Your cooler is not seated right if your getting those temps.
Try reseating the cooler and make sure your locking pins are locked.
__________________
Killer
Core i7 920 @ 4.2Ghz
EVGA X58 758 SLI
2xGTX295's in SLI
3x2Gig Kingston Hyper X 2100mhz
Corsair HX1000 Watt Modular
Water Cooling
3DMark Vantage 41312
Asylum1 is offline   Reply With Quote
Old 09-19-2009, 10:26 PM   #5
Bobbylite
Bobbylite's Avatar
whats your ambient?
__________________
Currently testing:
i920 @ 762 classified 4way 3x1gb Hypers
i670 @ e659 P55 classified 2x2gb 2400 cas7 G.skillz
2x Vapor-X 5870s 1000/1300 1.18v
Sdumper Uber Dual stage cascade -115 @ 304w Load
Bobbylite is offline   Reply With Quote
Old 09-19-2009, 10:28 PM   #6
pelo911
i try to reseating the cooler again and again
i get 92 ideal !!!
the thermal paste very dry , do you think it could be beacouse of that?
Old 09-19-2009, 11:31 PM   #7
flak-spammer
You've been using the same thermal paste for each remount? If so that explains your problem, you'll need new paste.
flak-spammer is offline   Reply With Quote
Old 09-19-2009, 11:57 PM   #8
pelo911
i will go to microcenter first thing in the morning
what is the best thermal paste:
http://www.microcenter.com/search/se...ate_group=HJ1J
thanks
Old 09-20-2009, 12:53 AM   #9
iTravis
iTravis's Avatar
Send a message via Yahoo to iTravis
Do you overclock the CPU? If at stock speed then it's ridiculously high, just go to your local MicroCenter and grab an after-market cooler: problem solved. As for thermal paste I would go with MX-2 but if they don't have it then AS5 will do the job just fine.
__________________
1st Rig
CPU: Core i7 920 @ 4.2Ghz Mobo: eVGA X58 Classified CPU Cooler: Prolimatech Mega Shadow
GPU: Diamond HD4870X2 RAM: 3x2GB Corsair Dominator DDR3 1600 PSU: Corsair HX850W
Sound card: AuzenTech X-Fi Forte 7.1 HDD: OCZ Agility 120GB SSD OS: Windows 7 Ultimate x64
Display:
30" Dell UltraSharp 3007WFP-HC Speakers: Logitech Z-5500
2nd Rig
CPU: QX9650 @ 4.0Ghz Mobo: Asus Maximus Formula SE CPU Cooler: Thermalright Ultra 120 Xtreme
GPU: eVGA GTX 295 Co-op FTW RAM: 2x2GB G.Skill DDR2 1066 PSU: Corsair HX650W
Sound card: X-fi XtremeMusic HDD: 2TB OS: Windows XP
Display: 24" Dell UltraSharp 2407WFP Speakers: Logitech Z-5300
iTravis is offline   Reply With Quote
Old 09-20-2009, 05:35 AM   #10
Camride
Camride's Avatar
thanks
http://www.microcenter.com/single_pr...uct_id=0280314
Better than Artic Silver 5. I highly recommend it.
__________________
Gaming/VM Testing Rig:
  • Core i7 920 D0, 4.3Ghz @ 1.36v (with HT/Virtualization on), needs more testing
  • Xigmatek Dark Knight, OCZ Freeze
  • EVGA X58 SLI LE
  • OCZ 12GB Platinum 1333
  • EVGA 8800GT 512 SC
  • Seagate 640GB
  • Thermaltake Armor Jr.
  • Enermax Liberty 500W Modular
  • Windows 7 Ultimate x64
Camride is offline   Reply With Quote
Old 09-20-2009, 06:31 AM   #11
zalbard
Xtreme Mentor
zalbard's Avatar
Send a message via MSN to zalbard
+1
If a different TIM doesn't work out then I guess the core has extremely bad contact with the heat spreader and it's RMA time...
__________________
Donate to XS forums
>> Join Intel 4.5GHz LinX Stable Club <<
Looking for Gulftown / Westmere ES
zalbard is offline   Reply With Quote
Old 09-20-2009, 10:31 AM   #12
pelo911
i clean the surface:
put some ocz freeze
and now it's better on the ideal temp (around 42)
but again , after 3 min of prime95 it's go to 98-100 degree!!!
Old 09-20-2009, 10:35 AM   #13
road-runner
Xtreme Cruncher
road-runner's Avatar
Might just be a hot running batch also, what batch number is it?
__________________
road-runner is offline   Reply With Quote
Old 09-20-2009, 10:46 AM   #14
pelo911
batch# 3849b016
took me a month to find this CPU
Old 09-20-2009, 10:47 AM   #15
Chumbucket843
Chumbucket843's Avatar
that might be an error. the multiplier should go down if it is getting that hot.
Chumbucket843 is offline   Reply With Quote
Old 09-20-2009, 11:16 AM   #16
pelo911
so i need RMA?
Old 09-20-2009, 11:40 AM   #17
pelo911
Old 09-20-2009, 11:43 AM   #18
Andrea deluxe
Andrea deluxe's Avatar
Enter To The Bios And Set The V-core To 1.0250v
Andrea deluxe is offline   Reply With Quote
Old 09-20-2009, 12:07 PM   #19
pelo911
the problem solved.
i just cancel the CPU turbo mode in the BIOS
TDP now on 130 instead of 147 with the turbo.
ideal temp: 41
maximum load temp with prime95: 77
Old 09-20-2009, 02:49 PM   #20
road-runner
Xtreme Cruncher
batch# 3849b016
I have one of the same batch but mine runs cool with water, never tried air, and it will also do 4500mhz linx stable with 1.375 volts.
__________________
Old 09-20-2009, 03:54 PM   #21
pelo911
can you upload some pics of your rig?
or to list your watercooling system?
Old 09-20-2009, 05:21 PM   #22
KILLER_K
KILLER_K's Avatar
Originally Posted by zalbard View Post
+1
Man what are you talking about really...............
If they have this thermal compound in get it.
http://www.frozencpu.com/products/70...ams.html#blank
Also you can cut off HT and it will lower it 10 - 20 degrees most of the time.
KILLER_K is offline   Reply With Quote
Old 09-21-2009, 03:48 AM   #23
kgk
Crysis killed my wallet
kgk's Avatar
Send a message via MSN to kgk
the problem solved.
ideal temp: 41
First off, it's IDLE, not ideal.
Second, that's still kinda hot. I can't believe that turbo was causing that much of a problem.
Just for comparison, I just ran my i7 975 @ stock with the stock intel cooler on it.
Prime95 stress for 15 minutes - no higher than 67C. That's full load with 8 threads and the cooler set on low
__________________
Bill Cosby: Stewie, what do you think candy is made out of?
Stewie Griffin: Sunshine and farts! What the hell kind of question is that?!
kgk is offline   Reply With Quote
Old 09-21-2009, 04:44 AM   #24
Camride
Camride's Avatar
If my Core i7 ran at 100c at load with turbo on (assuming no other issues) I'd RMA that thing in a hurry. No way it should run anywhere near that hot on a stock cooler.
__________________
  • EVGA X58 SLI LE
  • Seagate 640GB
Old 09-21-2009, 06:10 AM   #25
kgk
kgk's Avatar
pelo911, the chip is obviously a lemon. That you think "disabling turbo" makes it all hunky dory is mind boggling. If you continue to use that chip you are asking for failure.
RMA it.
__________________
Reply
Thread Tools
Rate This Thread:
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
XtremeSystems
