XtremeSystems Forums
Reply
Old 09-19-2009, 04:10 PM   #1
IKIKUINTHENUTZ
IKIKUINTHENUTZ's Avatar
Send a message via AIM to IKIKUINTHENUTZ
Post How to dye water cooling tubing *Experiment*IKIKUINTHENUTZ
Did a project here and thought it would be nice to share it with everyone.
IKIKUINTHENUTZ with another great project! Experiment!
Fast summery of how the idea come to be:
Couldn't find the color tubing I wanted because I searched 2 weeks for it and asking people like Cyberdruid or companies like Saint Goblin (Tygon) who said they don't carry it, don't know,or never seen it. I was looking for Transparent black water cooling tubing. The tubing is for my IKIKUINTHENUTZized Navig Tech Station. http://www.xtremesystems.org/forums/...d.php?t=228794
I found something called Rit Liquid Dye while doing my laundry. I read the information and figure WHY NOT!
Materials used for this project:
  • A pot you will never use again
  • Rit Dye Concentrated
  • Water
  • Non Iodine Salt
  • A metal tong/strainer
  • A stove
  • Tygon R3603 1/2in. ID 5/8in. OD Laboratory Tubing cut into pieces
Directions are straight forward. What I did here is testing out with Black dye to see the results much easier.
Water in the pot with one cap of the dye. Do not put a lot of the dye in the water, the stuff is extremely dense. Sorry no measurements, I will assume I put 6 cups of water and one cap of the dye.
Put tablespoon of salt to help activate the dye and increase required temperatures to boil.
Heat it up on high until rolling boil
Once it starts rolling boil, turn off the stove and move the pot else where on to a cooler surface. Use a strainer or clamp to carry the tube in place and simply dip and stir it in while it is hot. Do not let the tube fall to the bottom or pinch the tubing while it is hot or it will make the tube warp into a different shape.
Now depending how long you leave it in the dye, your results will vary and you need to experiment on cut pieces so you know how long to leave in the tube to get your desired color before doing large pieces.
Once you think it's ready, remove it and simply flush it with tap water in a sink.
Here are some examples all next to the non dyed tubing
Now I inserted my Bitspower barbs to help you see the transparency. Each one of these represent how long I left it in the dye.
No Dip, MFG original
7 seconds
15 seconds
30 seconds
30 seconds with a re dip after flushing of 20 seconds
The last image was the tube a bit warped because I accidentally pinched it when it was real hot with the tongs.
Maybe everyone here can experiment with different Rit Dye colors, different brands of tubing, and with different results to share. Try it out if you want tubing in the color you want that you can't find.
MAKE SURE THE TUBING YOU USE HAVE HIGH HEAT TOLERANCE LIKE TYGON LABS OR YOU WILL HAVE A MESS TO CLEAN UP
Also to note that I haven't testing the tubing to see if the dye leeches out. However I will note that washing it with soap and water will not remove the dye.
__________________
Work and School, Work and School, oi!
IKIKUINTHENUTZ is offline   Reply With Quote
Old 09-19-2009, 04:25 PM   #2
heinz357
heinz357's Avatar
Awesome bit of researching there!! Don't suppose you know offhand if Rit produce UV reactive dyes at all??
heinz357 is offline   Reply With Quote
Old 09-19-2009, 04:27 PM   #3
Waterlogged
I am Xtreme
Waterlogged's Avatar
Very cool! Thanks for experimenting
I particularly like the way 15 and 30 seconds look and 7 seconds doesn't look too bad either. I may have to look into trying this myself.
__________________
Waterlogged is offline   Reply With Quote
Old 09-19-2009, 04:30 PM   #4
wondergod
I like chicken.
wondergod's Avatar
great, although may I suggest closing the ends so dye does not get on the inside and only on the outside? Wonder if it would have the same affect without the worry of the dye getting in your actual loop.
wondergod is offline   Reply With Quote
Old 09-19-2009, 05:06 PM   #5
faster3200
faster3200's Avatar
Excellent post.
Sub'd to make sure I don't loose it.
I can imagine doing some creative things playing with dye concentration in different areas.
__________________
"Everything is amazing and nobody is happy".
- Louis CK
faster3200 is offline   Reply With Quote
Old 09-19-2009, 10:49 PM   #6
IKIKUINTHENUTZ
I wish Maybe I can find a UV additive and see what happens?
I got a interesting reply at OCF, maybe this would go well with the idea http://www.ocforums.com/showpost.php...94&postcount=2
Tee hee I got some ideas in my head, I just need to await my damn $1 dye from Xoxide Out of Business sale
__________________
Old 09-20-2009, 11:48 AM   #7
nkresho
nkresho's Avatar
Nice bit of research and a good idea.
Just be careful what it touches. That dye is not 100% permanent.
I've used rit in the past on clothing. I know, for a fact, that if you wash an item dyed with it, with other clothes, the dye will transfer and your laundry will be ruined. Even after quite a few washes alone (10 or so) it sill gets the other clothes.
It may stain your blocks and pump internals due to this fact too.
Just warning you, i don't mean to sound rude or anything.
__________________
920 3845B258 | P6TD | Seasonic M21D 850 | Cosmos S | GSKill 16000CL9T-6GBTD | 2x XFX 5870 CF| WDVR150 | W7 x64
Q9650 L847C037 | EP45-UD3R | Corsair 620HX | Antec 300 | GSkill 9600CL5D-4GBPI | EVGA GTX260| WD 6401AALS x3 | W7 x64
Dell E1405 | T7200 | OCZ 2M8004GK | WD 3200BEKT | W7 x64
nkresho is online now   Reply With Quote
Old 09-20-2009, 01:12 PM   #8
IKIKUINTHENUTZ
I don't think clothes have the same chemical materials in a Tygon tubing which I think the characteristics may be different.
Interesting to say that because when you dyed your clothes, what method did you use? I do know the washer machine dye method sucks ass though and any cold water way. Plus I normally hand wash dyed clothing for fear of bleeding.
Now I did decide to google up a bit on dying plastics with rit + heat and next thing you know I ran into this very fun keyboard mod on OCN
http://www.overclock.net/computer-pe...ion-guide.html
After reading a bit, these 2 post caught my interest on the subject matter
http://www.overclock.net/6842819-post23.html
http://www.overclock.net/6842834-post25.html
I decided to do a cross section on the 30 second tube
Dye did not penetrate inside because not enough time had lapse.
Is anyone here willing to run a complete loop for days with dyed watertubing + distilled water? I don't have water blocks to do this
__________________
Old 09-20-2009, 01:32 PM   #9
Boogerlad
As long as the stuff doesn't get inside, it's fine right?
Boogerlad is offline   Reply With Quote
Old 09-20-2009, 01:43 PM   #10
IKIKUINTHENUTZ
We don't know until someone test the hypothesis out that the dye will bleed after running X amount of days in a warm water cooling setup and stain stuff.
Personally it sounds safe to me that if the tubing was dyed without the dye going inside the tube sealed up during the process with some sort of sealant, it wouldn't matter about bleeding.
__________________
Old 09-20-2009, 02:50 PM   #11
nkresho
nkresho's Avatar
I used a very similar method for some cotton jeans as well as a few cotton and cotton/poly tee shirts. I boiled a pot of water and put the clothes as I turned off the stove. I stirred to get all the bubbles out and let it sit until it was cooled off. After rinsing a few times, everything went to the laundrymat to get the extra dye out. A few washes later and they were good to go. Although the dye did eventually fade quite a bit. Moreso than regular store-bought colored clothes.
I do like your cross section idea though. If you can get a bit of color penetration you should be fine. Especially since you're leaning toward dying the outside.
__________________
Old 09-20-2009, 04:50 PM   #12
Vapor
Admin
Vapor's Avatar
I dyed a couple lacrosse heads with RIT...not sure what plastic they are, but there was no way to intentionally fade it and it never seemed to fade on its own after use and abuse, even after years. The scoop edge of the heads would scrape down after awhile (especially after playing on pavement/concrete), showing the white they originally were, but that's expected.
I'd be willing to try running it for awhile...but I have no extra pump at the time.
I'm really curious what Tygon Silver (my favorite tubing...LRT Pro being a very close second) would look like with the outside dyed
__________________
Current Waterblock Testing
Roundup #2: Overall Comparison Thread, Alphacool Livingstone, Alphacool Niagara, Alphacool Yellowstone, D-Tek Fuzion V2, EK Supreme, EK Supreme LT, Enzotech Sapphire Rev A., Heatkiller 3.0 LC, Heatkiller 3.0 LT, Koolance CPU-345, Koolance CPU-350, Phobya, Swiftech Apogee GTZ, Swiftech Apogee GTZ SE, Swiftech Apogee XT
Vapor is offline   Reply With Quote
Old 09-20-2009, 06:19 PM   #13
Equinediver
Equinediver's Avatar
Definately an interesting test, but after knackering a load of tubing and a rad, not to count the hours spent cleaning my pump, blocks and res from using a dye bomb, will let others try this out.
But was wondering if these plugs would stop the dye from getting inside the tubes
http://www.performance-pcs.com/catal...ducts_id=23879
I find them great for when you want to make changes and don't want to drain your whole loop.
__________________
i7 975 EVGA X58 Classified 6Gb Corsair Dominator GT 2 x EVGA 285 FTW 2x 300Gb Velociraptor in RAID 0 WD Black 500Gb
WC loop 1: HK 3.0 Fesser 360 BP VREG BP NB D5 pump
loop 2: 2 x EVGA HC's Fesser 240 D5 pump
Equinediver is offline   Reply With Quote
Old 09-20-2009, 06:24 PM   #14
momomo6789
momomo6789's Avatar
couldn't you just plug the ends of the tubes so no dye gets inside then there would be no transfer of dye to your loop ? might take longer to dye but seems like it would be worth it .
__________________
I have to be constructive and not spam !!!
Friends don't let Friends buy gaming headphones !!
momomo6789 is offline   Reply With Quote
Old 09-20-2009, 06:30 PM   #15
IKIKUINTHENUTZ
The plugs would have to be either metal or a type of plastic that doesn't melt or shrink in boiling water.
Hell, add some sand inside too to prevent the tubing getting pinched or kinked during the process.
(I wonder if that's what viper john used to make his famous U bends lol)
as a side note, anyone know any UV dyes that used for clothing? I feel like trying that stuff out.
__________________
Old 09-20-2009, 06:42 PM   #16
Vapor
Admin
Vapor's Avatar
Two concerns with using plugs (one with sand, one without).
Concern one, no sand, just air: The air would want to expand considerably if it heats up and would increase internal pressure and might pop off of a plug (and all the problems that would cause) or just burst through the weakened tubing (bigger problem, lol). Considering how poor of a thermal conductor tubing is and how brief the exposure to the boiling water is, that might not be an issue though.
Concern two, using sand to occupy the space: the weakened/softened tubing might take the form of sand (especially if the grains are large) and would create bumps on the interior walls--leading to significantly increased turbulence (and therefore a likely increase in restriction). Yeah, it would take tubing from "non-factor" to "minimal factor" in overall loop flowrates, but still
Filling the entire tube with water and sealing the ends might be the way to go Or use extremely fine grained sand
EDIT: Concern three: it wouldn't be very easy to do a long length of tubing, would it? You might need to coil it tight enough so it can fit in the pot and contain it with string or something that wouldn't interfere with the dye (and then remove the string upon removal so it doesn't leave an indent on the softened tubing).
__________________
Old 09-20-2009, 09:25 PM   #17
Arthur
Arthur's Avatar
Great thread, great job and great result. I liked 7 and 15 second ones alot.
Congrats. mate.
__________________
Extreme ways I know will part the colors of my sea, perfect color me | Arthur's WC Worklog with Lian Li PC-9
Arthur is offline   Reply With Quote
Old 09-21-2009, 04:15 AM   #18
Bad ConNecTioN
Just get a really big pot!!
Bad ConNecTioN is offline   Reply With Quote
Old 09-21-2009, 06:07 AM   #19
ell
Cool, I love the 'smoked' looking one.
__________________
Asus Rampage II Extreme | i7 920 @ 4ghz (1.4v 200 BCLK) | 6 Gig OCZ Reaper 1866mhz | 285 GTX 2GB in SLi (750/1700/1380) | WD Raptors | SSD's | Thermaltake 1500watt ToughPower | Samsung SM305T |
EK Supreme | EK Mosfet Blocks | Koolance MB-ASR2E NB/SB Block | DRAM Block for MB-ASR2E | 2x EKFC285GTX-GW Nickel | MCP655 | MCP355 | TFC XCHANGER Triple & Quad Radiators |
A man who appreciates 2560x1600
ell is offline   Reply With Quote
Old 09-21-2009, 07:04 AM   #20
gillbot
gillbot's Avatar
I might try it. You could get nylon caps for the ends and just clamp them on with worm drive clamps so they wouldn't pop off. If you make your tubing length a couple inches longer than needed, you could cut off the clamped section, plus that would give you a good cross section look at the dye penetration. You could also squeeze the tubing SLIGHTLY before capping to make a negative pressure, that way it would be "normal" after the expansion from the air being heated. Might take some trial and error to get it right though.
__________________
My Heatware
RIP Loonym
安い (Yasui) - Asrock x58 Extreme w/ 9GB Nanya and Qimonda DDR3 Ram
Xeon W3580 w/ XSPC Delta V3/BIX3/MCP655/MCRes/Kill Coil
gillbot is offline   Reply With Quote
Old 09-21-2009, 07:36 AM   #21
SNiiPE_DoGG
I am Xtreme-ly inactive
SNiiPE_DoGG's Avatar
Send a message via AIM to SNiiPE_DoGG Send a message via MSN to SNiiPE_DoGG Send a message via Skype™ to SNiiPE_DoGG
Good idea IKIKU as I have said before on these boards in regards to RIT dye, there is a lot of cool effects you can make with it - with specific respect to tubing I would think some kind of spiral patter using electrical tape and possibly a hot glue pattern would be very cool
__________________
Account no longer active, see contact info to get in touch
SNiiPE_DoGG is offline   Reply With Quote
Old 09-21-2009, 09:09 AM   #22
wondergod
I like chicken.
wondergod's Avatar
I actually refine my suggestion of plugging the ends. Get a good size loop of tubing like 10-15 feet and just leave the ends out of the water/dye.
Old 09-21-2009, 09:27 AM   #23
DeanB
DeanB's Avatar
Very neat idea! I liked the smoke look alot.. I normally go for black tubing but I like the look of this alot.
If I can track down some tygon around here. I'll run a loop with this stuff.. I think the best way to fill the tube would be to preboil some hot water and salt (high salt concentration than the ink solution). that'll prevent air bubbles from forming when its in the pot.
__________________
DeanB is offline   Reply With Quote
Old 09-21-2009, 06:15 PM   #24
tiro_uspsss
I am Xtreme
tiro_uspsss's Avatar
Send a message via ICQ to tiro_uspsss Send a message via MSN to tiro_uspsss Send a message via Yahoo to tiro_uspsss Send a message via Skype™ to tiro_uspsss
this is awesome thread
__________________
DNA = Design Not Accident
the awesome FOOD
thread
WANTED
heatware / ebay
tiro_uspsss is offline   Reply With Quote
Old 09-21-2009, 07:15 PM   #25
faster3200
faster3200's Avatar
I bought some blue Rit today and am going to try it out on some generic clear and Tygon silver tubing. Hopefully I can get some (crappy) pics by the end of this week.
This better be worth the effort. I had to go into a Walmart for the stuff .
__________________
- Louis CK
Reply
Thread Tools
Rate This Thread:
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
XtremeSystems
