XtremeSystems Forums
Reply
Old 09-19-2009, 12:49 PM   #1
xREDMAN
need help
i recently bought a ek waterblock for my gtx 295
when i opened it up the o-ring fell out now i can't put it back in place
i tried using tape didn't work
__________________
Red Addiction:
EVGA P55 FTW
i5 750 @ 4ghz
4GB CORSAIR XMS3 ddr3 1600mhz
HD5850 stock
300gb VelociRaptor
1tb WD Caviar Green
Topower 900w
xREDMAN is offline   Reply With Quote
Old 09-19-2009, 01:30 PM   #2
MaByBoI
Xtreme Cable Management Freak
MaByBoI's Avatar
contact ek about it, they should be able to do something about it.
__________________
Blood(Rage) shall be spilt
Intel Core i7 | Enzotech Sapphire
EVGA GTX 295 co-op | Swiftech Epsilon
Foxconn BloodRage | BloodRage Waterblock
OCZ Platinum 6gb DDR3 | GTX 480 QUAD rad
Corsair HX1000W | MCP 655
Silverstone TJ-07 | FrozenQ T-Virus Res
Intel X25-M G2 SSD 80GB | Primochill UV Red Tubing 1/2"ID-3/4"OD
WD 1TB Black | Distilled Water
I also have a Macbook Air
MaByBoI is offline   Reply With Quote
Old 09-19-2009, 02:20 PM   #3
xREDMAN
nvm man i fixed it i used scotch tape
__________________
Red Addiction:
EVGA P55 FTW
i5 750 @ 4ghz
HD5850 stock
300gb VelociRaptor
1tb WD Caviar Green
Topower 900w
Old 09-19-2009, 03:34 PM   #4
millertime359
Xtreme Guru
millertime359's Avatar
Make certain you leak test it. Not certain how you used the the tape.
__________________
Project Millertime: The Core I5 build
Crunching/folding box on air: AMD Athlon X2 7750 Black Edition; Sapphire Radeon HD 4830; Gigabyte MA78GM-US2H; Lian Li PC-V351; Windows 7 RC
millertime359 is offline   Reply With Quote
Old 09-19-2009, 03:39 PM   #5
Hondacity
tape was used to keep the o-ring inplace
__________________
Hondacity is offline   Reply With Quote
Old 09-19-2009, 03:59 PM   #6
millertime359
Xtreme Guru
That's what I thought. I was more worried that it was left on.
__________________
Old 09-19-2009, 06:20 PM   #7
gabe
Mr. Swiftech
gabe's Avatar
TIP: to keep an o-ring in place, fill-up the groove with dielectric grease (vaseline works just a well), put the o-ring in place, finally gently wipe any excess grease ..
__________________
CEO Swiftech
gabe is offline   Reply With Quote
Old 09-19-2009, 06:21 PM   #8
xREDMAN
hey gabe so using vaseline is better than scotch tape?
__________________
Red Addiction:
EVGA P55 FTW
i5 750 @ 4ghz
HD5850 stock
300gb VelociRaptor
1tb WD Caviar Green
Topower 900w
Old 09-19-2009, 06:42 PM   #9
gabe
Mr. Swiftech
gabe's Avatar
well explain to me how you used tape? Typically, the problem is that the o-ring keeps poping out of its groove. This happens a lot in sharp radii. if you put a piece of tape on it, sure it will keep it in place, but you cannot close the block with the tape or it will leak, so you have to remove it. As soon as you remove the tape, the o-ring comes with it, or it wants to pop out of the groove again.
using the vasline or grease trick keeps the o-ring in place in the groove, and you can close the block like that.
__________________
CEO Swiftech
Old 09-19-2009, 06:49 PM   #10
xREDMAN
didn't work too well just tried it right now :/
__________________
Red Addiction:
EVGA P55 FTW
i5 750 @ 4ghz
HD5850 stock
300gb VelociRaptor
1tb WD Caviar Green
Topower 900w
Old 09-19-2009, 06:53 PM   #11
millertime359
Xtreme Guru
u did leave tape in, that what I was worried about. Follow Gabe's advice.
__________________
Old 09-19-2009, 06:54 PM   #12
gabe
Mr. Swiftech
gabe's Avatar
it might mean that the o-ring is not on specs. it could be too long, or too short, or the groove might be out-of specs (too shallow, or too wide, or too narrow).. As you see many possible causes for the same outcome.
is the o-ring too short? (you can't get to the groove), or too long (it buckles?)
if too short, you can lengthen it a bit by rubbing gently from the opposite side, then work your way towards the difficult spot.. if too short, do the opposite.. rub it out of the difficult spot to spread the excess material over a longer distance..
__________________
CEO Swiftech
Old 09-19-2009, 07:54 PM   #13
Utnorris
Utnorris's Avatar
Try using a hair dryer to make it more flexible so it will stay in the groove.
__________________
CPUID http://valid.canardpc.com/show_oc.php?id=484051
http://valid.canardpc.com/show_oc.php?id=554982
New DO Stepping http://valid.canardpc.com/show_oc.php?id=555012
4.8Ghz - http://valid.canardpc.com/show_oc.php?id=794165
Corsair 800D
I7 920 (3849B028)/Classified/ EVGA GTX 295/ 6Gb (3x2Gb) OCZ 1866 Ram @ 1600 6-6-6-16-1t timings / Inte M-25 80Gb SSD x 2 RAID 0
W/C System
(CPU) EK Supreme Classified (NB) EK Water Block / Typhoon III with XSPC RX360 / B*P/Koolance Compression Fittings and Quick Disconnects.
Utnorris is offline   Reply With Quote
Old 09-19-2009, 08:37 PM   #14
SNiiPE_DoGG
I am Xtreme-ly inactive
SNiiPE_DoGG's Avatar
Send a message via AIM to SNiiPE_DoGG Send a message via MSN to SNiiPE_DoGG Send a message via Skype™ to SNiiPE_DoGG
just work at it for a little while.... it takes patience and a fine touch. I think you are just getting frustrated (easy to do, as it can be difficult to get the O-ring to sit right )
__________________
Account no longer active, see contact info to get in touch
SNiiPE_DoGG is offline   Reply With Quote
Old 09-19-2009, 09:55 PM   #15
Spawn-Inc
Spawn-Inc's Avatar
if you can get it with the tape, make long piece's of tape then put the block back on and pull the tape. it should stay in place and let you remove ALL the tape.
__________________
CPU: Core2Quad q6600 G0 3.5GHz@1.4v (highest so far 4.2GHz)
GPU: XFX 9800GTX @ 850/1230
Ram: Samsung 4GB (4x1GB) 700MHz PC5300
Mobo: EVGA-NF68-A1 680i (P32)
PSU: Enermax Galaxy 850Watt DxX
HDD:WD5001AALS, ST3250410AS, ST3500410AS, ST3500320AS - 1.75TB
DVD: LG H26N,LG GH20LS10 both sata
LCD: Samsung 32" LN32A450, Samsung 226BW 22" wide
Sound: Logtiech Z 5500/Razor Barracuda HP-1 / AC-1
CPU & GPU: 3x Swiftech MCR320, 2x MCP655, MCW60 R2, Dtek Fuzion V2, 18 high speed yates @ 5v
3Dmark06:17,814 AquaMark:190,865
Spawn-Inc is offline   Reply With Quote
Reply
Thread Tools
Rate This Thread:
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
XtremeSystems
