XtremeSystems Forums
Reply
Old 09-19-2009, 12:00 PM   #1
Hglazm
Hglazm's Avatar
Send a message via MSN to Hglazm
New Case for WC mod
I'm thinking about getting a Lian-Li PC-A70F for my next WC loop. I like this because I can put the PSU up top, cut out a hole on the bottom, and easily fit in a 3x120MM rad of any thickness I like.
My main concern though is that I'll have a lot of positive air pressure, since I'll have 3x120 and 2x140 pulling in, and only 2x120 pulling out (plus a slow 140mm PSU fan)
Anybody have any thoughts on this case?
http://lian-li.com/v2/tw/product/upl...0f/a70f-02.jpg
http://www.lian-li.com/v2/en/product...25&ss_index=61
On another note, I need a new radiator and reservoir, because the rad I have now is less than quality and the reservoir I have now would be very very unattractive on that case. Also, any suggestions as to who to buy a 1156 block would be appreciated.
__________________
Q6600 @ 3.5ghz - 26c idle and 38c load
XFX 4890 - 960/1200
ASUS 4350 cut to PCIe x1
OCZ Solid Series SSD, 30GB
Black Ice II Radiator
MCP655 Pump (setting 2)
GA-EP45-UD3R
1x250GB WD
1x500GB WD
1x1TB Hitachi
Hglazm is offline   Reply With Quote
Reply
Thread Tools
Rate This Thread:
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
XtremeSystems
