XtremeSystems Forums
Reply
Old 09-19-2009, 10:00 AM   #1
pelo911
powder coat the inside of lian li v2010 , can i get advices?
i should drill the rivet out.
after the powder coating finish.
instead of rivet , i could use TAP to drill M3 hole and use M3 screws?
what is the length of screws should i need?
what is the size of the screws in the case? (mother board tray, hdd , psu , side windows and more...)
i want to replece everything to black , can you help me to find and choose?
taps:
http://www.mcmaster.com/#taps/=3p8k99
screws:
http://www.mcmaster.com/#machine-screws/=3p8oub
http://www.mcmaster.com/#socket-cap-screws/=3p8plo
pelo911 is offline   Reply With Quote
Reply
Thread Tools
Rate This Thread:
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
XtremeSystems
