XtremeSystems Forums
Reply
Old 09-19-2009, 06:48 AM   #1
BrokenArrow
BrokenArrow's Avatar
TJ-07 Motherbaord Tray Powdercoating
Is it better to completely disassemble the motherboard tray (drilling rivets and all) to have it powdercoated?
Or do most people leave it as it came from the factory and powdercoat all in one go?
I have gone through all of the build logs and never see the powercoated motherboard tray taken apart.
BrokenArrow is offline   Reply With Quote
Old 09-19-2009, 07:11 AM   #2
MaByBoI
Xtreme Cable Management Freak
MaByBoI's Avatar
i hand spray painted mine.... i took apart the whole case.. but left the rivets and stuff in... im sure they know what theyre doing. dont worry
__________________
Blood(Rage) shall be spilt
Intel Core i7 | Enzotech Sapphire
EVGA GTX 295 co-op | Swiftech Epsilon
Foxconn BloodRage | BloodRage Waterblock
OCZ Platinum 6gb DDR3 | GTX 480 QUAD rad
Corsair HX1000W | MCP 655
Silverstone TJ-07 | FrozenQ T-Virus Res
Intel X25-M G2 SSD 80GB | Primochill UV Red Tubing 1/2"ID-3/4"OD
WD 1TB Black | Distilled Water
I also have a Macbook Air
MaByBoI is offline   Reply With Quote
Old 09-19-2009, 07:44 AM   #3
BlueAqua
I am Xtreme
BlueAqua's Avatar
Drill out the rivets and powder coat it separately.
BlueAqua is online now   Reply With Quote
Old 09-29-2009, 03:07 AM   #4
Little Man
Little Man's Avatar
Just had mine powdercoated and i left the rivets in.
CBF getting them out, then buying new ones yada yada..
Little Man is offline   Reply With Quote
Old 09-29-2009, 05:12 AM   #5
Armitage
Armitage's Avatar
I removed the backplate (Rivets), but left the PCI brackets and I/O square on there, powercoating was perfect.
__________________
Armitage is offline   Reply With Quote
Old 09-29-2009, 06:17 AM   #6
BrokenArrow
Good info. I was more worried about the little corner gusset plates.
Old 09-29-2009, 09:30 AM   #7
ExEngineer
I powdercoated without removing any rivets. Looks good.
__________________
Core i7 920 (D0) 4GHz | ASUS Rampage II Extreme | Corsair 3x2GB Dominator DDR3-1600 | BFG GTX295 H20 | Enermax Revo85+ 1050W | 2 x 120GB OCX Vertex RAID0 | 4 x WD RE3 1TB RAID10 | LG GGW-H20L Blu-ray/HD-DVD | Silverstone TJ07 | MPC355 w/ XSPC top | Feser XChanger360 rad | Magicool Pro Slim 240 rad | HeatKiller 3.0 LT | MCW-NBMAX | PrimoFlex 3/8x5/8 tube | 4 x Scythe S-FLEX SFF21F fans | 2 x Scythe Kaze-Jyuni 12mm thin fans | 2 x ATI Digital Cable Tuners (external) | 1 x Angel Dual-Analog Tuner (internal) | Win7 x64
ExEngineer is offline   Reply With Quote
Reply
Thread Tools
Rate This Thread:
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
XtremeSystems
