XtremeSystems Forums
Reply
Old 09-19-2009, 05:00 AM   #1
eternal_fantasy
eternal_fantasy's Avatar
How to remove clear lacquer from Heatkiller for plating?
As I seem to have posted in a pissing match thread with my question that was eventually locked, I'll try again with a new thread.
Originally Posted by Utnorris View Post
There is no polishing or cleaning involved prior to the nickel plating.
Isn't the copper top of the Heatkiller lacquer coated? It has been over a month now since I ordered the plating service from ChilledPC.co.uk, and apperently the clear laqure is a pain to remove, as the nickle will not plate on top of the lacquer.
Some mails between me and Tom @ ChilledPC-
We had all our plating back yesterday, and the Heatkiller blocks have all come out with no nickel on the top surface at all.
Im currently contacting watercool to see if they treat the surface in anyway as its ruined about 5 blocks.
We've sent them off to another plater to have a look at - to see if he can do any better.
Sorry for the delay.
I then asked how the Heatkiller plating was done before as he had posted a Heatkiller he nickle-plated on their forums;
The first block we had done was polished first, then it still came out back, was stripped and then polished and recoated. This was why our current plater basically said dont bring any more in.
The guy who has them now has been in contact with a few people and should have them done next week.
The reason its taking so long is so we can do a perfect finish for you - worst that will happen is you will get a refund and we end up with 5 blocks ruined, but lets hope it doesnt come to that!
So with almost everyone saying it takes less then 5 minutes to prepare the Heatkiller for plating, how did you guys remove the clear lacquer from the top surface of the Heatkiller?
__________________
EVGA Classified E760 - EK Full Board Block
Intel Core i7 965 - HeatKiller Water Block
ATi HD 4870X2 - EK Full Cover
Corsair Dominator TR3X6G1600C8D
3 x Intel 80GB SSD 34nm Gen. 2 on -
Areca 1231DML SATAII RAID Controller 2GB Cache
Drobo controlled: 2x1GB Western Digital RE3
Antec Signature 850W
HeatKiller CPU Block - EK 4870X2 Full Cover Block - EK Classified Full Board Block - ThermalChill PA120.3 - 3 x Noctua NF-P12 - Laing DDC Ultra 18W - Aquaero Controlled
Current Functional Motherboards selection:
ASUS P5B Deluxe - ASUS P5K Premium - ASUS Maximus Formula - ASUS Maximus Extreme
ASUS Striker II Extreme - EVGA nForce 790i Ultra - FOXCONN BlackOps - ASUS Rampage Extreme
ASUS P6T Deluxe - EVGA Classified E760
eternal_fantasy is offline   Reply With Quote
Old 09-19-2009, 05:28 AM   #2
cx-ray
V
Yes, it's clear coated. A good plater should know how to remove it with whatever solvent or acid bath.
Don't expect anything of top quality from that shop. I've been there once and waited for 7 mouths for my stuff. When it was finally delivered the custom stuff was of mediocre quality.
cx-ray is offline   Reply With Quote
Old 09-19-2009, 05:49 AM   #3
BDW88
BDW88's Avatar
Chemical paint stripper 15min paste type works best.
__________________
Mountain Mods ex. Ascension + pedestal - EVGA X58 Classified (E759) - i7 920 D0@4.3 / i7 975EE@stock - Corsair GT's 6gb 2000mhz 8-8-8-24 - Evga 285 tri-sli - 2x Intel x25m 80gb Raid0 - Corsair HX1000 + Corsair HX850 - HK 3.0 CU - HK V2 285 gpu - Bitspower chipset + mosfet - Feser 480's x4,360 x2 - mcp 355's w/ EK V2 tops x5 - San Ace 1011 x18, YL's D12SM x11 - BigNG's x2 w/ sensorbus
BDW88 is offline   Reply With Quote
Old 09-19-2009, 05:51 AM   #4
Mekrel
Mekrel's Avatar
Well I've had 1,000s of parts modded by Chilled PC - and everything has been top notch and Tom knows how much of a perfectionist I am.
It doesn't take a genious to work out that Tom is working a tight over head scheme and doesn't have a horde of people working for him.
Add to that, the fact most custom work such as plating and powder coating is out sourced to companies who's other clients are probably shipping items in the 1000's to them.
Chilled PC in my opinion has gave Watercooling e-tailers here a kick up the arse. Kustom-PCs were probably the only shop with a wide range of case modding supplies before Tom came a long and they had PATHETIC availability.
My first WC build was modded 100% by myself, but the pain of buying expensive tools and machinery that was used all but once was just plain stupid - would rather wait a few months and have a perfectly modded case and no mess.
Guess that's just me.
OP: Try Nitro-mors (think this is the name) stripper. Halfords sell it. It comes in a larger rectangular metalic can with a picture of a wooden door on the front.
__________________
If it ain't watercooled, I don't wanna know.
Mekrel is offline   Reply With Quote
Old 09-19-2009, 07:21 AM   #5
zeropluszero
zeropluszero's Avatar
Send a message via MSN to zeropluszero
I had my heatkiller nickel plated, and the plater said he had to remove the clear coat. he apparently used a sandblaster or something, because when i recieved mine back, it now has a matt finish (i'm alright with it, it looks different) catch is, i had Dreamaxx use her plater, and he had plated hers, and it came out perfectly smooth. so either the dude put both in an acid bath and left mine in too long, or he's sandblasted mine and not hers.
__________________
Cosmos S - Q9550 E0 - EVGA 780i FTW - 4GB Dominator 8500 - SLI GTX280 - 150GB Velociraptor - Enermax 85+ 1050W
Parallel Loop using EK MultiLink Reservoir
CPU Loop: Heatkiller 3.0 CU (Nickel plated) - Feser 360 (S-Flex G) - MCP350 + EK Plexi Top - EK Reservoir
NB/SB + GPU Loop: EK 280 Nickel Plexi - Bitspower 780i Fullcover - Feser 240 (S-Flex G) - MCP355 + EK Plexi top
zeropluszero is offline   Reply With Quote
Old 09-19-2009, 08:05 AM   #6
cx-ray
V
C'mon...even his own brand Thermochill grills looks rather average. The aluminum is brushed away too far, as in, edges of the grill are wasted away/rounded. The anodizing and brushing itself doesn't come close to Lian Li. In comparison the brushing looks like it's done with a brillo pad.
I also ask for custom cutting of a Lian Li 343B top. It came back all scratched up. In the end I did the job myself and used his item as a cutting guide
...all this after paying over $900 in advance with him repeatedly promising my order was going to be completed soon. I already counted on 2-3 months delivery time. Not the 7 months by which time my PC components were outdated. As insult to injury he was selling items in stock reserved for me to other customers and having me wait for them even longer.
What other shops and suppliers do in the UK isn't my concern. My purchasing contract was with Chilled. He is responsible for the end result.
Old 09-19-2009, 10:57 AM   #7
eternal_fantasy
Hey you got a picture of your Heatkiller with the mat finish? I'm curious about the result
__________________
Old 09-19-2009, 09:28 PM   #8
Utnorris
Utnorris's Avatar
I didn't have to do anything with my Heatkiller prior to the Nickel Plating. The company that did it said the pre-bath takes care of all of that, so it wasn't necessary for me to do anything. I assume the acid bath they use prior takes the lacquer off. The only prep I did was taking the block apart, which was 4 screws.
__________________
CPUID http://valid.canardpc.com/show_oc.php?id=484051
http://valid.canardpc.com/show_oc.php?id=554982
New DO Stepping http://valid.canardpc.com/show_oc.php?id=555012
4.8Ghz - http://valid.canardpc.com/show_oc.php?id=794165
Mountain Mod UF2O
I7 920 (3849B018)/Blood Rage/ XFX HD5870/ 6Gb (3x2Gb) OCZ 1866 Ram @ 1600 6-6-6-16-1t timings / Inte M-25 80Gb SSD x 2 RAID 0
W/C System
(CPU) Phase (GPU) EK Water Block and Water Chiller / B*P/Koolance Compression Fittings.
Utnorris is online now   Reply With Quote
Old 09-20-2009, 06:07 AM   #9
millertime359
Xtreme Mentor
millertime359's Avatar
That pre-bath is suppose to be part of any plating process. It is a pretty harsh chemical bath that will remove any impurities.
There are a couple of rinse stages that happen during the plating process and there is a charge placed to the part. A few different things could have happened during the plating process, for your part to not plate.
__________________
Project Millertime: The Core I5 build
Crunching/folding box on air: AMD Athlon X2 7750 Black Edition; Sapphire Radeon HD 4830; Gigabyte MA78GM-US2H; Lian Li PC-V351; Windows 7 RC
millertime359 is online now   Reply With Quote
Old 09-20-2009, 07:51 AM   #10
zeropluszero
__________________
Old 09-20-2009, 08:52 AM   #11
WeeMaan
That looks really bad.. :\
Edit: How much does Tom take to nickel plate a heatkiller?
I have had only good experiences with him and his shop before.
__________________
Project TJ07 WeeMaan edition in progress...
i7 920 @ 4,4ghz, P6T Deluxe, Corsair Dominator, Amd 4850 (temp), OCZ Vertex 60gb + Samsung F1 1tb
Heatkiller copper, Thermochill 120.4, DDC 3.2
WeeMaan is offline   Reply With Quote
Old 09-20-2009, 08:55 AM   #12
Vapor
Admin
Vapor's Avatar
I think it looks SO cool
It could be a little less orange/yellow though...but maybe that's the photo
__________________
Current Waterblock Testing
Roundup #2: Overall Comparison Thread, Alphacool Livingstone, Alphacool Niagara, Alphacool Yellowstone, D-Tek Fuzion V2, EK Supreme, EK Supreme LT, Enzotech Sapphire Rev A., Heatkiller 3.0 LC, Heatkiller 3.0 LT, Koolance CPU-345, Koolance CPU-350, Phobya, Swiftech Apogee GTZ, Swiftech Apogee GTZ SE, Swiftech Apogee XT
Vapor is offline   Reply With Quote
Old 09-20-2009, 09:39 AM   #13
Darth_Penguin
Darth_Penguin's Avatar
I removed the lacquer by polishing the surface to a mirror finish. I think a polished HK looks best anyway...
__________________
Banchetto
Intel i7 920 @ 4.20|Asus P6T6 Revolution|G.Skill 6gb DDR3 1600|Sapphire 4890 Toxic|Intel x-25 E 64GB
H2O
HK 3.0 Block|Koolance P6T6 Block|355 w/ XSPC Res Top|Dual MCR320's|EK Acrylic/Nickel 4890 Block
Darth_Penguin is offline   Reply With Quote
Old 09-20-2009, 09:40 AM   #14
nkresho
nkresho's Avatar
Zero... That doesn't look right. That looks like paint or powdercoat. Maybe with metal flake in it. I'm not sure I would accept a plating job that came out that way.
__________________
Q9650 L847C037 | EP45-UD3R | Corsair 620HX | Cosmos S | GSkill 9600CL5D-4GBPI | EVGA GTX285 | WD VR 150 | W7 x64
Q9650 L932B844 | EP45-UD3R | Corsair 520HX | Antec 300 | GSkill 9600CL5D-4GBPI | EVGA GTX260 | 3x WD6401AALS | W7 x64
Dell E1405 | T7200 | OCZ 2M8004GK | WD 3200BEKT | W7 x64
nkresho is online now   Reply With Quote
Old 09-20-2009, 11:21 AM   #15
NaeKuh
Post Soapbox Destruction
NaeKuh's Avatar
+1
i love a matted look over a mirror.
__________________
Nadeshiko: *Undergoing Rebuild*
Haruhi: i7 975 12GB DDR3 eVGA Classified *Haruhi -> Nadeshiko*
Lind: Dual Gainestown 3.07
NaeKuh is offline   Reply With Quote
Old 09-20-2009, 11:39 AM   #16
millertime359
Xtreme Mentor
I'm wondering the same, seems really orange. Anymore photos of it. Looks interesting.
__________________
Old 09-20-2009, 11:53 AM   #17
woffen
woffen's Avatar
http://www.chilledpc.co.uk/shop/prod...roducts_id=998
woffen is offline   Reply With Quote
Old 09-20-2009, 12:29 PM   #18
NaeKuh
NaeKuh's Avatar
Originally Posted by woffen View Post
best to spell it out...
Product Description
This is a service to Chrome/Nickel Plate your waterblocks or any other metal part.
There is a minimum fee which we work on with the platers, so one block will cost £6.99.
However if you were to send us a batch of blocks, eg 4 then the cost will only rise to £10-£15 not 4 x £6.99. So please contact us with any enquiries you have as we may be able to batch your blocks with other customers ensuring everyone pays a fair price.
any respectable plater will acid dip the blocks first to clean it as norris said. Its part of the process.
Any Plater that gives u smack about extra work / time is just giving u excuses to charge more.
As i said the acid dip is ALWAYS part of the step, unless the plater wants to cheap his services.
The top coat is most likely a primer of some sort. It will go yam yam yam in acetone for a while, or a paint thiner and u can scrub it off, if u dont have an acid bath prepared.
But my last plater diped my blocks in nitric acid HNO3 b4 he started plating, and that came out bright as a virgin block b4 he plated it.
__________________
Old 09-21-2009, 07:01 PM   #19
zeropluszero
it is silver in person, and yeh, it's just the photo.
it's definatly plated as well, like i said, i think he's either sand blasted it, or left it in the acid bath too long. i didnt really have much of a choice, i live in victoria australia, and had it sent to perth, the other side of australia for plating, so i couldnt really say to the plater, hey, that's not exactly what i was expecting.
__________________
Old 09-21-2009, 07:04 PM   #20
millertime359
Xtreme Mentor
Looks like it got sandblasted, got anymore photos that it shows up better?
__________________
Old 09-21-2009, 07:13 PM   #21
Vapor
Admin
Vapor's Avatar
Were the tops of microchannels smooth still?
__________________
Old 09-23-2009, 07:09 AM   #22
zeropluszero
nah, it's currently in use at the moment so no other photos, except those in my worklog, which i havent gotten around to completing or posting here. check it out HERE
it's very pic heavy.
the whole top and bottom was the same finish, including the channels. the channels appeared to be fine, in that they looked more or less the same as before the plating, but slightly pitted.
i really dont think it did anything to change performance, but i dont have a before to gauge it off.
__________________
Old 10-05-2009, 11:23 AM   #23
turtletrax
turtletrax's Avatar
Looks like my heatkiller got ruined. I explained the situation in detail to them and said it is from germany and that getting another one wasn't easy or cheep. Then I didnt hear back from them for several days so I called them and the guy I dealt with "wasnt there", then I repeatedly called.
I just called again and he answered and I knew his voice and asked him how it went and he said "not good". So I get to go in tomorrow and most likely see a buggered block. If I take the time to repolish it and get it replated it should come out OK right?
Hope so.... They did such a good job on my EK stuff. Apparently they dont bath stuff properly....
__________________
My Buildlog
"If (the american) people ever allow private banks to control the issue of their money,
first by inflation and then by deflation,
the banks and corporations that will grow up around them (around the banks),
will deprive the people of their property until their children will wake up homeless.
...on the continent their fathers conquered." -Thomas Jefferson, 1802
turtletrax is offline   Reply With Quote
Reply
Thread Tools
Rate This Thread:
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
Powered by vBulletin® Version 3.7.0
Copyright ©2000 - 2009, Jelsoft Enterprises Ltd.
XtremeSystems
