XtremeSystems Forums
Reply
Old 09-19-2009, 04:42 AM   #1
heinz357
heinz357's Avatar
OCZ Hydro Pulse 800 Opinions??
Has anyone here had any experience of these?
http://www.watercoolinguk.co.uk/cata...oducts_id=1712
I'm asking because I've just started on my second w/c build, and unfortunately cannot use my existing pump/res combo in it!
I only have cpu, gpu, and 2x 240 rads in my loop, but want to be able to expand it, should the need arise, but don't have the budget for one of the Laing range.
All constructive input welcome!!
heinz357 is offline   Reply With Quote
Old 09-19-2009, 05:02 AM   #2
Jamesrt2004
Xtreme Mentor
Jamesrt2004's Avatar
Send a message via MSN to Jamesrt2004
link no work =(
and... never skimp on pump. if that dies your system does
__________________
"Cast off your fear. Look forward. Never stand still, retreat and you will age. Hesitate and you will die. SHOUT! My name is…"
//James
Jamesrt2004 is offline   Reply With Quote
Old 09-19-2009, 05:09 AM   #3
dM@n
dM@n's Avatar
Send a message via AIM to dM@n Send a message via MSN to dM@n Send a message via Yahoo to dM@n Send a message via Skype™ to dM@n
It's pretty much a CPX-Pro pump. Should be fine for your needs.
__________________
Oblivion V2
Hardware:
CPU Loop:
DD MC-TDX 775 Block
Swiftech MCP-655 (D5 Vario)
Black Ice GTX 480 w/ (8) Yate Loon High-Speed Fans
Swiftech MCRES-MICRO 2
dM@n is offline   Reply With Quote
Old 09-19-2009, 05:34 AM   #4
alacheesu
If it is the CPX-Pro (certainly looks like it), then Martin reviewed it. Great pump.
alacheesu is offline   Reply With Quote
Old 09-19-2009, 05:37 AM   #5
heinz357
heinz357's Avatar
Many thanks for your swift replys, will be adding this to my shopping list immediately!!
BTW, are there any reviews on this pump anywhere, I've looked, but can't find any??
Respecting your experience, but if the likes of DD and OCZ are both putting their names to the same item, it can't be that bad, surely?? Can it??
Old 09-19-2009, 06:03 AM   #6
alacheesu
Yes, in my post above. I'm fairly certain the OCZ 800 and the CPX-Pro are the same pump.
No, I've only heard good things about that pump and never seen a single reported failure.
Old 09-19-2009, 06:57 AM   #7
heinz357
heinz357's Avatar
Thank you for your help all! After reading Martins review of it, I shall definitely make this my pump of choice, ordering on Monday!!
Old 09-19-2009, 09:28 AM   #8
RubberDuck
RubberDuck's Avatar
Send a message via AIM to RubberDuck Send a message via Yahoo to RubberDuck
Here is the pump --> http://www.frozencpu.com/products/94...-_800_Lhr.html <--
__________________
RubberDuck is offline   Reply With Quote
Old 09-19-2009, 11:11 AM   #9
Nightstar
Nightstar's Avatar
I had the first version of the CPX pump about 6,7 years ago(the one with the blue anodized aluminum body) it's internal seal failed and the electricals channeled water into my chassis. I sure hope they've improved the design.
__________________
OCZ, where life-time warranty means until we're out of stock!
Nightstar is offline   Reply With Quote
Old 09-19-2009, 03:33 PM   #10
iandh
Zombie Assassin
iandh's Avatar
I don't think the two pumps are related in any way besides name.
__________________
Phenom II 720BE
Gigabyte 790FX-UD5P
OCZ Platinum AMD edition DDR3-1600 2x2Gb
XFX 5850 1Gb
X-Fi Xtremegamer
Lian Li PC-A05B/Corsair 750HX
iandh is offline   Reply With Quote
Old 09-19-2009, 03:58 PM   #11
Waterlogged
I am Xtreme
Waterlogged's Avatar
I think your confusing the CPX with the CSP-750 made by C-Systems. I haven't been able to access their website for ~2yrs now so it kind of leads me to believe their OOB.
__________________
Waterlogged is offline   Reply With Quote
Old 09-20-2009, 03:08 AM   #12
Migi06
Migi06 is offline   Reply With Quote
Reply
Thread Tools
Rate This Thread:
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
Powered by vBulletin® Version 3.7.0
Copyright ©2000 - 2009, Jelsoft Enterprises Ltd.
XtremeSystems
