Hi there,
Im new to watercooling, so please correct me if I say anything stupid or do something that is inappropriate. I have read the forum rules and a lot of posts here and in other forums, but you guys seem to be the guru’s and I’d like to learn from the best.
I will try to explain what my goal is, what I have figured out myself and then I would like to hear your comments, improvements, etc.
I am looking for:
- a silent computer, looks are less important, but that doesn’t mean it has to be ugly
- a new project: after aircooling, Watercooling seems to be the next fun timepassing
therefore I would like to cool my CPU and GPU
- enough room for future upgrades. I don’t want to be forced into buying a complete WC setup when I upgrade my mainbord, CPU and GPU.
My current system:
Case: Enermax Pandora CA3030
Mainboard: ASUS M2N32 SLI deluxe
CPU: AMD X2 6000+ (3.1GHz versie)
GPU: Sapphire HD4770
PSU: Coolermaster SilentPro 600W
Planned Future upgrades:
Short term: CPU replacement by a Phenom-II 940BE. Although maybe I will skip this since my money is probably going into the WC-setup.
Long term: Upgrade of Mainboard, CPU and GPU. Possibly i5 or i7 and HD5870
In both cases (long and short term) I would like to reuse as much of my WC-setup as possible.
The WC set I had in mind:
- pump: MCP655 (with original top, maybe I will get a custom top as an upgrade)
- radiator: either the Black Ice GT Stealth 360 or the XSPC RX360
- Fans for the rad: 3 x Nexus 120mm Real Silent 1000 RPM (are these OK?)
- Reservoir: Swiftech MCRes-Micro Rev2
- CPU-block: either D-Tek FuZion Universal v2 or Swiftech Apogee GTZ
- VGA block: Swiftech MCW60-R Universal
- RAM coolers GPU: Swiftech MC14 RAM heatsinks (are these necessary?)
- fittings: What fittings to use? I have found short and long fittings, from different companies, which do you prefer and why?
- tubing: Masterkleer ½ ID. How much do I need?
- hose clamps: I am completely blank on these ones, what are the easiest and safest clamps I can get
- Cooling fluid: 2 litres of Feser One Cooling Fluid
Important questions:
- I have read things on electrical corrosion, will these parts work together? Or am I sour in a few months time?
- Will this work? Will this be silent?
- Am I overshooting my goal? Can I reduce costs somewhere and still get good results (silence).
OK thats it, I am open to suggestions and looking forward to your opinions on the questions I have. Please tell me why some things can be done differently or better, so I can learn.
~ Supergroover
