XtremeSystems Forums
Go Back   XtremeSystems Forums > Cooling > Air Cooling
Reply
Old 09-18-2009, 10:30 PM   #1
neonblingbling
What to do with fan -1 blade?
I broke a fan and don't know what purpose it could serve me. It is a cheaper Yate Loon, so it isn't a huge loss. However, I hate to waste it. Is there any way to make it of some use? I think it would be a bad idea to glue the blade back on because it will not be balanced. The other other ideas I can think of is use the chassis as a spacer, and the wires for a different fan. Anything else?
neonblingbling is offline   Reply With Quote
Old 09-18-2009, 10:38 PM   #2
faraprejudecati
You could serve a good funeral so your friends could party!
faraprejudecati is offline   Reply With Quote
Old 09-18-2009, 10:41 PM   #3
Ar3s
Ar3s's Avatar
Send a message via Skype™ to Ar3s
Glue doesn't work, it's terrible actually. The noise and vibration will be non-stop. I would try running it on lower voltages as i do with my -1 blade panaflo. It really isn't as bad as throwing it out.
__________________
Everyday is a NiceDay
Ar3s is offline   Reply With Quote
Old 09-18-2009, 11:00 PM   #4
~CS~
Just gut the fan and keep the frame to be used as a shroud on a rad or heatsink.
__________________
That desktop i have no money to upgrade
Heat
~CS~ is offline   Reply With Quote
Old 09-18-2009, 11:42 PM   #5
eligray
eligray's Avatar
Send a message via AIM to eligray Send a message via MSN to eligray
vibrator.
Or you can knock off a blade that's nearly on the opposite side. This will get you far less vibration, and you can run it at relatively high speeds.
__________________
Originally Posted by xaxis View Post
Posted this more as a prank I guess... It's really unfeasible, unpractical, and for all intensive purposes... SHOULD NONE THE LESS BE ATTEMPTED!
eligray is offline   Reply With Quote
Old 09-19-2009, 12:06 AM   #6
neonblingbling
Originally Posted by eligray View Post
vibrator.
Genius.
I enjoy the idea of another blade breaking off while in use.
Old 09-19-2009, 09:54 AM   #7
SoulsCollective
Xtreme Cruncher
SoulsCollective's Avatar
Actually, it is possible to resurrect fans given sufficiently strong glue, time, a steady hand and patience. I once knocked a blade off the top fan of an Antec 900 (I swear there must have been a flaw in the plastic, all I did was get my knuckle in the way of the spinning blade), but couldn't afford the time and effort getting a replacement because the build was due the next day. Epoxy resin, a steady hand, some prayer and multiple tries later, and the fan is still working like new, two years later, with no extra noise or vibration that I can hear.
Now, keep in mind that those larger fans don't spin particularly quickly anyway, but still, it's worth a shot.
__________________
Rig specs
CPU:
i7 920 @ 3.8GHz Mobo: eVGA Classified 760 RAM: 3x2GB OCZ DDR3-1866 Reapers @ 1,800, CAS-8 VGA: Sapphire HD5870 @ Core 900 Mem 1,250
HDD: 6x WD6400AAKS in RAID-6 powered by Highpoint RocketRaid 3520 SFX: Auzentech X-Fi Prelude
PSU: Corsair HX-1000 Case: Silverstone TJ-09 modded for WC OS: Win7 RTM x64
Liquid-cooled
Sub-loop One
: EK-Supreme -=- MCR320, 3x Scythe S-FLEX "F" fans -=- 7/16" Pro-LRT -=- 7/16" BP compressions-=- MCP655 w. Typhoon III
Sub-loop Two: EK Classified FC -=- 2x MCR120, Scythe S-FLEX "F" fans -=- 7/16" Pro-LRT -=- 7/16" BP compressions-=- MCP655 w. Typhoon III
Peripherals
Dell 2408WFP rev.A01 -=- Audio Technica ATH-AD1000 -=- Razer Mamba -=- Microsoft "Natural Ergonomic 7000" keyboard -=-
Foundational Falsehoods of Creationism
SoulsCollective is online now   Reply With Quote
Old 09-19-2009, 11:50 PM   #8
neonblingbling
Perhaps if I can get some epoxy, I'll give it a try. However, the only adhesive I have on hand is wood glue...
Old 09-20-2009, 01:07 AM   #9
SoulsCollective
Xtreme Cruncher
Yeah, that's not going to do anything with plastic.
__________________
Rig specs
CPU:
Liquid-cooled
Sub-loop One
Peripherals
Old 09-20-2009, 05:36 AM   #10
gillbot
gillbot's Avatar
vibrator.
only if it has an even number of blades, if the count is odd, it's best to break 1/2 off of each of the 2 opposite. even then, you are guessing though.
__________________
My Heatware
安い (Yasui) - Asrock x58 Extreme w/ 9GB Nanya and Qimonda DDR3 Ram
Xeon W3580 w/ XSPC Delta V3/BIX3/MCP655/MCRes/Kill Coil
gillbot is offline   Reply With Quote
Old 09-20-2009, 05:49 AM   #11
TheGreenFoX
+1... Thats what i use to do (i happens from time to time that i put my finger into a running cheap fan)...
__________________
TheGreenFoX is offline   Reply With Quote
Old 09-20-2009, 06:41 AM   #12
Smartidiot89
Smartidiot89's Avatar
Genius.
Ouch, I think I broke something?
__________________
Nvidia GT300 yields are under 2%
Originally Posted by 64NOMIS View Post
I explain CPU's to 3 yr old. CPU = brain for computers. Now thinks CPU is in her brain. Goes to sleep without complaint.
CPU: Phenom II X2 550BE @ X4 B50
Clock: 3600MHz 1.4v 24/7 crunching stable
Memory: 2x2GB 1333MHz 6-6-6-18-24-1T
Motherboard: MSI 790FX-GD70
GPU: HD5850 or HD5870 in November
AMD Forum
Smartidiot89 is online now   Reply With Quote
Old 09-20-2009, 09:23 AM   #13
neonblingbling
I'm not positive, but I think there's no such thing as even-number-of-blades fan. I forget the specifics, or where I read it, but I think it has to do with the balance of the fan. In any case, I'm not cutting half a blade off.
I'm not into that sort of play.
Old 09-20-2009, 09:44 AM   #14
sniperbob
sniperbob's Avatar
Send a message via AIM to sniperbob
break off all the blades, cut out a round piece of cardboard and glue it to the remaining spinning part of your fan. Then glue this image to your cardboard and take control of your friends minds!
__________________
Insert inspiring sig image/quote/rig specs here
sniperbob is offline   Reply With Quote
Old 09-20-2009, 05:22 PM   #15
gillbot
gillbot's Avatar
I have a couple that have 6 blades. Though most have 5 or 7.
__________________
My Heatware
Old 09-21-2009, 04:21 AM   #16
filthysanchez
I usually just make them into shrouds
__________________
e6750|P5K-C|2x2GB G.Skill DDR2-800|eVGA 8800gt
TRUE and Accelero S1 rev 2
filthysanchez is offline   Reply With Quote
Old 09-21-2009, 05:58 PM   #17
Junimrox
Junimrox's Avatar
i've glued many blades, in 120, 70 and 80mm fans... never noticed any vibration or weird noise.
__________________
C2D E6550 2.33Ghz@3.605Ghz - P35C-DS3R
MSI 8600GTS OC - 2x2Gb OCZ PC9200@1030 5-5-5-15
4X500Gb Raid5 - Case GMC R-2
AC F7 Pro + TR HR-05 + Zalman VNF100
Junimrox is offline   Reply With Quote
Reply
Thread Tools
Rate This Thread:
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
Powered by vBulletin® Version 3.7.0
Copyright ©2000 - 2009, Jelsoft Enterprises Ltd.
XtremeSystems
