XtremeSystems Forums
Reply
Old 09-17-2009, 06:48 PM   #1
liguhy
liguhy's Avatar
Larger Thermochill radiators?
So, I absoutely love the Thermochill PA 140.3 radiator, but it's been hard to see if it could fit my A05N without permanet PCI slot modification and loosing my drive bays.
Are they coming out with a PA 140.2 or PA 140.1 radiator? I know there's a single-pass PA 160, but I can't find it anywhere (PPCs, frozencpu, sidewinders, petras, dangerden, mountainmods, newegg) except for mountainmods. It's out of stock at DangerDen. I know it's not the newest thing on the block, but it seems still quite a well sized radiator, especially for tight spaces. Aside from the obvious fan choice problems and fan performance problems over 120mm fans/radiator combo, I really like it's possibilities.
Is it not distributed anymore or is demand too low to stock or what?
The coolest thing about it, over say a PA 120.2 or other dual radiators, is I could throw it in my A05N with a 140mm PSU and still have space to stack some hard drives (see picture)! Using a PA 160 would allow me to use a PSU at least 160mm long (ATX mobo edge) or longer to approx. 253mm (depending on ram installed) if I took out the HDDs. It is also thinner than the all other dual radiators, which are all dual pass. If I mount the fan on top of the rad and draw air through the case bottom, through the radiator, and into the case, I wonder if I'd even need a shroud if I seal the fan well enough.
__________________
__________________________________________________
Last edited by liguhy; Today at 1/2 second ago. Reason: You can always edit your writing more...and I'm anal-retentive.
liguhy is offline   Reply With Quote
Old 09-17-2009, 07:27 PM   #2
Froggy
Froggy's Avatar
I have two & LOVE them. Once you account for the shroud depth, the thickness is similar to the double pass monsters. Also you could have a local sheet metal shop make custom shrouds so that you can mount a 140mm fan to the rad. I did & am pleased with the end results.
I am still waiting for a better selection of 140mm fans though.
__________________
Asus P5Q Pro(1613m), E8600(440x10, 24/7: 440x9.5), 4GB Ram(528Mhz), 9800GTX KO(800/1998/2462) Accelero GTX
300GB Velociraptor, Corsair HX620,
HSPC Top deck station, TR IFX-14(2x140mm & 1x120mm fan)
My HeatWare 65-0-0
Froggy is offline   Reply With Quote
Old 09-17-2009, 08:08 PM   #3
liguhy
liguhy's Avatar
I love Thermochill PA 140.3 and PA 160, but....the FANS!
What 140mm fans did you use? Yate Loon D14SM-14 or D14BM-14? What do you think about this debate over using 120mm fans on larger radiators
__________________
Old 09-18-2009, 01:50 PM   #4
marcus000
marcus000's Avatar
Send a message via MSN to marcus000
See here:
http://forum.watercoolinguk.co.uk/sh...ad.php?t=10473
marcus000 is offline   Reply With Quote
Old 09-19-2009, 02:49 PM   #5
phinix_mike
As you can see from that forum, I asked TC if there will be 140.2.
So its confirmed, I wonder, and probably that will be the truth - 140.2 will be similar in performance to 120.3.
__________________
::: E8500@4GHz :: GTX280 :: 2x VERTEX 30GB RAID0 :: DFI JR P45-T2RSR :: 4GB Dominator 8500 :: Dell 24" :::
::: Water cooling: OCZ HF-MK1 CPU block :: Aquagrafx G200 :: Feser 240:: DDC 18W + XSPC res/top :::
::: K45 :: Celeron 430 1.8GHz :: 2GB RAM :: Samsung 750GB :::
projects: ::: “PHINIX CUBE” ::: "PHINIX nanoTOWER" :::
phinix_mike is offline   Reply With Quote
Old 09-19-2009, 03:36 PM   #6
liguhy
liguhy's Avatar
Couldn't you just subtract 140mm length from the PA 140.3 to get the 140.2 dimensions? I assume the endtanks, etc would be the same and all that would be different is the extra 140mm worth of radiator. That'd make the PA 140.2 a theoretical 142 x 340 x 60mm. Not bad, figuring a PA 120.2 is 128 x 304 x 61mm and a PA 120.3 is 126 x 430 x 64mm. I'd much rather try to fit a PA 140.2 into my A05N than do the permanent PCI slot modding required for the PA 140.3.
__________________
Old 09-19-2009, 03:56 PM   #7
phinix_mike
same here... You could put two 140.2 instead of 140.3 and cutting PCI slots...
__________________
Reply
Thread Tools
Rate This Thread:
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
Powered by vBulletin® Version 3.7.0
Copyright ©2000 - 2009, Jelsoft Enterprises Ltd.
XtremeSystems
