XtremeSystems Forums
Reply
Old 09-17-2009, 12:48 PM   #1
Edward88
Cooler Master Cosmos S base blueprint
Hi there.
I looking for the cooler master cosmos s base blueprint.
I want to build a new one with holes for two 120mm fans instead of one 120 fan, so i can use my mcr220 there.
I really dont want to cut the original piece because if some day i sell it
I know that i can dismantle the case but between that, and finish the new base, it'll take some time and i can't be without computer for that long because i need it for work.
Someone have done it before and made some blueprints?
Edward88 is offline   Reply With Quote
Old 09-17-2009, 02:00 PM   #2
TheNexxuvas
TheNexxuvas's Avatar
Are you wanting to cut the bottom piece out or just mod it.
Sorry trying to figure that out from your wording.
__________________
Owner:Matrix Gaming PC's
Houston TX
Sprint Technician Level III
Green Cosmos S Worklog: http://www.xtremesystems.org/forums/...=1#post4004809
TheNexxuvas is offline   Reply With Quote
Old 09-17-2009, 02:21 PM   #3
Edward88
I'm going to do a new one, but with the 2 120mm holes for the fans instead of the stock that only have one. Also i will do the hole for the drain port and whatever i need to mount the res and all the stuff.
But i need the blueprint to do all the holes that i need to mount it again in the case :p
Old 09-17-2009, 02:50 PM   #4
air_ii
But if you have the old one, can't you make necessary measurements yourself?
air_ii is offline   Reply With Quote
Old 09-17-2009, 03:51 PM   #5
Edward88
Some of them yes, but not all.
I cant dismantle it, thats the problem. So i cant measure many of the holes that i need, and also some height and length
Reply
Thread Tools
Rate This Thread:
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
Powered by vBulletin® Version 3.7.0
Copyright ©2000 - 2009, Jelsoft Enterprises Ltd.
XtremeSystems
