XtremeSystems Forums
Reply
Old 09-17-2009, 06:30 AM   #1
bigKr33
Possible bad news
Many of you probably have seen my worklog *liquid night* on here about a month or so ago. I'm still out of town and will be back in a couple of weeks from my 2 month trip. As you know the new video cards from amd are coming out very soon. The gtx275 I have now was just a temporary card until the new gen comes out. However seeing as to how long the 5870x2 is (11.8") I may have to scrap my project now. My 10.5" 275 barely fits as it is. Now the only option I have is to swap the hdd slot with the optical drive slot to gain maybe a 1.25". This is a bummer
__________________
Gaming PC
Lian li v1000 modded | xeon w3520 #3903A472 (looking forward to gulftown )| Foxconn BloodRage x58 | Muskin Redline 3x2gb 998691 | Evga gtx275 (for now) waiting for gt300... | pc p&c 910 psu | 7200.12 Seagate 500gb | Dell Ultrasharp 2408wfp | Windows 7 professional x64
Watercooling: Heatkiller 3.0 LT / XSPC rx-240 rad / ddc 3.2 w/ XSPC top / EK res100 / Bp 1/2" true silver fittings / black 1/2" Feser tubing
Home Theater
46" Sony bravia xbr4 | xbox 360 elite | Arcam avr280 rcvr | Paradigm studio 60's v.5 (fronts) bi-amp'd | Paradigm studio cc-590 v.5 (center) | Paradigm studio 10's v.5 (rear) | Velodyne impact 10" sub | Richard Gray power conditioner
Heatware
bigKr33 is offline   Reply With Quote
Old 09-17-2009, 09:07 AM   #2
Utnorris
Utnorris's Avatar
Why not move thehard drive cage to the bottom of the case and turn it sideways and place it next to the rad? Or even place it down under the back case fan. You have plenty of room in there to move the HD cage to anther spot. I wouldn't scrap it due to the GPU size. You could also got to two HD5870's instead of the HD5870x2. Performance should be the same.
__________________
CPUID http://valid.canardpc.com/show_oc.php?id=484051
http://valid.canardpc.com/show_oc.php?id=554982
New DO Stepping http://valid.canardpc.com/show_oc.php?id=555012
4.8Ghz - http://valid.canardpc.com/show_oc.php?id=794165
Mountain Mod UF2O
I7 920 (3849B018)/Blood Rage/ XFX HD5870/ 6Gb (3x2Gb) OCZ 1866 Ram @ 1600 6-6-6-16-1t timings / Inte M-25 80Gb SSD x 2 RAID 0
W/C System
(CPU) Phase (GPU) EK Water Block and Water Chiller / B*P/Koolance Compression Fittings.
Utnorris is online now   Reply With Quote
Old 09-17-2009, 09:17 AM   #3
jadeskye
jadeskye's Avatar
get the dremel out! cut a lump off
__________________
"If we hit that bullseye, the rest of the dominos will fall like a house of cards. Checkmate."
jadeskye is offline   Reply With Quote
Old 09-17-2009, 09:50 AM   #4
mozis
Dunno if there is enough space, but maybe go vertical and try:
Either this way or turn it 90 degrees clockwise :p
That wouldnt require alot of modding..
__________________
HW: E8600 (lapped)/P5Q-Deluxe (1805)/G.Skill F2-8500CL5D-4GBPK/EAH4850/ST3160+ST3320+WD1500HLFS
WC: EK Supreme/EK4850 FC/PA120.3/MCP655
mozis is offline   Reply With Quote
Old 09-17-2009, 10:06 AM   #5
Wolf132
Wolf132's Avatar
Why dont you scrap that huge harddrive mounting thing, and get http://www.performance-pcs.com/catal...ducts_id=25357 . And you can just powdercoat them the same color as your case. Save you 2-3 inches
__________________
Asus P5Q-Delux, Q6600 @ 3.7
2x 120.2PA Thermochill
MM H2GO
EVGA GTX 260
OCZ vertex 60g w/Win 7 Pro
Corsair 850HX
NEC 20wmgx2
Wolf132 is offline   Reply With Quote
Old 09-17-2009, 11:36 AM   #6
Diverge
Diverge's Avatar
Or just scrap the optical drive, get an external USB optical drive for when you actually use disks. I had a similar, but slightly different problem (lack of drive bays after getting a T3 res), and i just bought a samsung external DVD burner. works great for when I actually need to use a CD/DVD
__________________
[DFI LP Jr P45-T2RS] [Q6600] [8GB G.Skill F2-8000CL5D] [Seasonic S12 600W] [Windows Server 2008 (64bit)] [ATI 1800XL]
[DFI JR X58-T3H6] [i7 920 D0 3849A866] [12GB OCZ OCZ3B2000C9LV6GK] [Corsair CMPSU-750TX] [Windows 7 (64bit)] [EVGA 280 GTX][OCZ Vertex 30GB x3 Raid0]
Diverge is offline   Reply With Quote
Old 09-17-2009, 12:00 PM   #7
jim0ne
Totally agree with Diverge. I took out my optical drive also, cause first off.. it was making to much noise for me and secondly, i hardly use it. I have an external slim dvd burner and plug in when i need it. This will clear some space.
jim0ne is offline   Reply With Quote
Old 09-17-2009, 01:21 PM   #8
Armitage
Armitage's Avatar
Or put the GPU in a different slot.
__________________
Armitage is offline   Reply With Quote
Old 09-17-2009, 01:36 PM   #9
millertime359
Xtreme Mentor
millertime359's Avatar
+1 If it is only 1 card, either x16 slot will work. You could just move it into the other slot.
__________________
Project Millertime: The Core I5 build
Crunching/folding box on air: AMD Athlon X2 7750 Black Edition; Sapphire Radeon HD 4830; Gigabyte MA78GM-US2H; Lian Li PC-V351; Windows 7 RC
millertime359 is offline   Reply With Quote
Old 09-17-2009, 05:40 PM   #10
bigKr33
These are all pretty good ideas. I didn't even think about an aftermarket hdd slot. Oh and as for the weird mounting positions, I don't want to do that because of the powder coating (very thin coat). However I'm actually thinking of getting it repowder coated. Alot of battle scars on the case trying to install hardware.
I'm still out of town right now. i should be back in the next couple of weeks. I'm trying to get this rig done, but work gets in the way sometimes. Make sure you guys look out for pics of the rig when its finished. Will try getting overclocking results in as well.
__________________
Gaming PC
Home Theater
Heatware
Reply
Thread Tools
Rate This Thread:
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
Powered by vBulletin® Version 3.7.0
Copyright ©2000 - 2009, Jelsoft Enterprises Ltd.
XtremeSystems
