It's gonna be quite an uncommon unit, with each stage being usable as a cpu cooler independently to the lower one(s). About 4th stage evap temp, I'd be happy with about -145C loaded (R50 @ ~ 3.3bars). Anyway, what matters isn't the lowest stage evap temp but the polyvalency of the unit as a whole.
I believe each stage will have it's own evaporator/suction-line so he can use the stage he wants to hit the evap temps he desires. Only need -70C? Fire up just the first two stages. Need -140C? Fire up all four stages.
__________________
Team PURE is about kickass pirates and unicorns defeating ninjas.
That would be so cool to have a Cascade like that, it that even possible ?
Yes, with multiple evaporators and solenoids to direct refrigerant flow. I believe this is what Before is aiming for. You could also use a single evaporator but you would need a bunch of valves to direct inlet/outlet to the corresponding operating stage and would have to make sure the system vacuumed the evaporator empty after each run so as to not cross-contaminate the various stages. Multiple evaporators is simpler
__________________
__________________
1. The first rule of Bench Club is, you do not talk about Bench Club
2. The second rule of Bench Club is, you do not talk about Bench Club
3. If someone says stop, goes limp, taps out, the the benching is over
4. No bummers in the batcave, apart from unkie dave
5. One Bench at a time
6. No air, no water
7. Benching will go on as long as they have to
8. If this is your first night at Bench Club, you have to Bench
