After getting some very helpful advice from Vapour a while back about his preference of putting pumps in series rather than doing separate loops, I have finally come to put together my new i7 system and thus updated the loop.
I would like to ask the XS LC public: would you do:
#2: DDC 3.2 (XSPC Restop) --> SR1 120 --> PA 120.2 --> XSPC 4870x2 FC
I posed this question a while back and Vapour had mentioned that the GTZ might benefit from the extra DDC pump. Further, it also means that when doing CPU intensive tasks (but not utilizing the GPU), the loop can make better use of the total 6*120mm of radiator surface area, rather than being limited to 3*120 in every scenario (and same vice versa, when running a game that doesn't really stress the CPU, for eg.)
However, the Koolance QDC's (2 pairs) might negate the benefit of extra flow for the GTZ through the second pump.
One last question: If filling a loop with two pumps in series, do you only operate the first pump (so that it pumps through the second and onwards) while filling? Thanks.
Thank you XS for your patience on a question that has cropped numerous times.
EDIT: PS. The Black Ice SR1 radiators really are quite incredible.
__________________
"Language cuts the grooves in which our thoughts must move" | Frank Herbert, The Santaroga Barrier
i7 920 3924A | 4870x2 | EVGA M-ATX X58 | 6GM Corsair Dominator | Corsair HX1000 | Intel X25-M 160 G2 | OCZ Vertex 60 | WD 320 || Apogee GTZ - XSPC FC | (2)DDC3.2 | (2)PA 120.2 | (2)BI SR-1 120 || MM H2G0
E6600 L627B005 | 4870x2 | OCZ Flex II | P5K Deluxe | Corsair HX1000 || (1) Apogee GT - PA 120.2 - DDC3.2 w/ XSPC Restop (2) XSPC FC - PA 120.2 - DDC3.2 w/ XSPC Restop || MM H2G0
I think:
1. You're overthinking this.
2. The difference would likely be very small.
3. The only way to know for sure is to try both options (and post results on XS )
I think:
I voted series, though.
I sort of suspect I'll do whatever the poll outcomes.
__________________
One advantage of running them in series is that a single pump failure in a 'single pump' loop can cause you a real problem, whereas a single pump failure in a 'dual pump loop' is slightly less catastrophic.
I wouldn't worry about pump failure. There are too many built in safeties to prevent any real damage. If the CPU gets too hot it will shutdown before burning up. With dual loops you are isolating the cpu and therefore should have better temps than with the gpu in the same loop. Increase flow has very little benefit compared to isolating the cpu on it's own loop.
Good point, and something I was aware of with a CPU loop
Still, I've always felt that other components that may be isolated in an individual loop (GPUs or chipsets for example) might not provide you with the same sort of protection. GPU thermal cutoffs are particularly high and unless I'm mistaken, will not shutdown the system but rather disable/underclock the GPU until the temperature recovers to a more reasonable state.
Presumably at this point it slowly heats up again until failure?
I'm speculating here of course - I've never had the cajones to let my GPU burn up that bad
Also, unless you are running really slow fans, then the extra cooling potential wouldn't be needed on CPU only tasks. The 1 320 combo should take care of that heat load.
Multiple loops are way over-rated IMO... there is no point to them. One big happy loop is how I always do it
__________________
*:-.,_,.-:*'``'*:-.,_,.-:*'``'*:-.,_,.-:*'``'*:-.,_,.-:*'``'*:-.,_,.-:*
Q6600 @ 3.7Ghz / Maximus Formula X38 / 4GB Supertalent 6400 / 4870 HD
PC Power & Cooling 750W
Mountain Mods U2-UFO Cube
GTZ --> MCW-NBMAX --> EK FC --> PA 120.3 --> PA 160.1 --> 2x DDC Ultras in Series --> Custom Clear Res
Win7
"Artificial intelligence is no match for natural stupidity."
Originally Posted by ranker
Did you just get hit in the head with a heavy object? Because obviously you're failing at reading comprehension.
i have shut off one of my pumps as well as shut off all my fans, and at stock clocks prime95 loaded at 60C or so. but the sounds levels from my yates at 5v is acceptable to me.
__________________
CPU: Core2Quad q6600 G0 3.5GHz@1.4v (highest so far 4.2GHz)
GPU: XFX 9800GTX @ 850/1230
Ram: Samsung 4GB (4x1GB) 700MHz PC5300
Mobo: EVGA-NF68-A1 680i (P32)
PSU: Enermax Galaxy 850Watt DxX
HDD:WD5001AALS, ST3250410AS, ST3500410AS, ST3500320AS - 1.75TB
DVD: LG H26N,LG GH20LS10 both sata
LCD: Samsung 32" LN32A450, Samsung 226BW 22" wide
Sound: Logtiech Z 5500/Razor Barracuda HP-1 / AC-1
CPU & GPU: 3x Swiftech MCR320, 2x MCP655, MCW60 R2, Dtek Fuzion V2, 18 high speed yates @ 5v
3Dmark06:17,814 AquaMark:190,865
you don't really have any restrictive block in your loop so I would say separate loops.
Yes, it is certainly a consideration, but would not the GTZ benefit from extra flow? Thanks Dean.
Originally Posted by Hondacity
true no restrictive block there...
id still go for one big loop...
when everything is idling...on big loops feels alot better .................option : you can turn off 1pump too
its a lot challenging too
its way more complicated to tubitize
My thoughts mirrored, somewhat. I've always thought multiple loops to be overrated and since I've run multiple loops in the past, I'm sort of keen on going the other way.
Thank for all the input guys.
__________________
no, for it just worked out that way since i only have to use a short piece of tubing in between the barbs, which by the way was no fun using 7/16" tubing.
__________________
I see. Thanks.
Yes, I used to struggle with thin walled 7/16's around 1 D5. 2 must have been nigh impossible and incredibly frustrating.
EDIT: 16 votes for series, 17 for separate. Haha.
__________________
well the pump was a dream compared to putting it on 1/2" plumbing copper, i cut up the end of the tubing 2 times trying to get it on... i had to use soap and boiling water. what a pain.
__________________
