XtremeSystems Forums
Reply
Old 09-16-2009, 09:54 PM   #1
badboyze
Question can GTX 360 handle this loop ?
Hey Guys, Can GTX 360 rad handle a QX9650 (OC'd to 4.0Ghz) and two GTX 285 FTW's in SLI ? i'm planning to use the kaze 3000's in push pull setup.
Do you think i'll need another 240mm rad ?
I also have a feser 240mm but i dont know where to mount that in the obsedian 800 case
badboyze is offline   Reply With Quote
Old 09-16-2009, 09:55 PM   #2
Kylzer
Kylzer's Avatar
Send a message via MSN to Kylzer
Depends what brand of rad.
__________________
Kylzer is offline   Reply With Quote
Old 09-16-2009, 10:00 PM   #3
badboyze
I bought the GTX 360 from danger den ( it is a HWLabs rad though )
Old 09-16-2009, 10:10 PM   #4
Chicken Patty
Chicken Patty's Avatar
Send a message via AIM to Chicken Patty Send a message via MSN to Chicken Patty
I honestly would leave the cards on air bro, I mean at least me I change cards often so watercooling it will just be a waste.
However now to answer your question, I think it'll be ok. Temps might not be as good as just the CPU, but I think you will still be better off than on AIR. Just do it man.
__________________
Core i7 920
EVGA X58 Motherboard
Nanya 6GB (3 x 2GB)
PNY 9800GX2
PCP&C 860W PSU
CPU cooled by Prolimatech Megashadow
Chicken Patty is offline   Reply With Quote
Old 09-16-2009, 10:11 PM   #5
faster3200
faster3200's Avatar
You should be good. The GTX rads are fantastic with that fan setup.
__________________
"Everything is amazing and nobody is happy".
- Louis CK
faster3200 is offline   Reply With Quote
Old 09-16-2009, 10:11 PM   #6
Chicken Patty
Yeah, they love high CFM fans
__________________
Core i7 920
Nanya 6GB (3 x 2GB)
PNY 9800GX2
PCP&C 860W PSU
Old 09-16-2009, 10:14 PM   #7
faster3200
faster3200's Avatar
Yes they do. With some rough guessing as to the total heat load (is 600w fair?) going based on Martin's charts he would be at <5C delta, which is quite good.
__________________
- Louis CK
Old 09-16-2009, 10:21 PM   #8
Chicken Patty
see now, if he had an i7, he'd be needing something like a MO-RA
But yeah I think that rad will behave good with tall that in the loop, I have a GTX 480 for my i7, and that rad is wonderful man. Honestly, my next rad will be HW Labs
__________________
Core i7 920
Nanya 6GB (3 x 2GB)
PNY 9800GX2
PCP&C 860W PSU
Old 09-17-2009, 01:39 AM   #9
alacheesu
It will handle that loop easily with those fans.
alacheesu is offline   Reply With Quote
Old 09-17-2009, 02:58 AM   #10
bladechai
bladechai's Avatar
Kaze 3000 in a push pull... this is certainly not going to be quiet....
__________________
Lian Li PC-A77B, Core i7 965 @ 3.6MHz (1.35v), Asus MB-R2E, 12GB Corsair Dominator 1600MHz DDR3, Enermax Revolution85+ 1250W, XFX GTX295 SLI, Asus Xonar Essence STX, WD VelociRaptor 300GBx2, OCZ Vertex 120GB SSD, Alphacool Laing DDC-Pump 12V Ultra Water Tankx2, Koolance VID-NX295x2, Koolance MB-ASR2E, Koolance DRAM Cooler for MB-ASR2E, Koolance MVR-40 VReg Blockx2, Koolance Inline 120mm Reservoir, PrimoFlex Pro LRT 7/16" ID (5/8" OD) Black Tubing[/b], Feser X-Changer 240mm and 360mm Xtreme Performance Radiators, SCYTHE S-FLEX™ "G" 120mm 1900 rpmx6, Dell 3008WFP Ultrasharp 30" Monitor,
Logitech Illuminated Keyboard, Razer Mamba Mouse, Vista Ultimate 64 Bit SP2
bladechai is offline   Reply With Quote
Old 09-17-2009, 05:08 AM   #11
badboyze
Bladechai : Yes you are right, i have heard them running around 2800rpm and boy they are loud , but i'm more worried about performance .. and those fans are a must to tame GTX 360 beast
alacheesu : Thanks for your input
Chicken Patty : Thanks for the advice, yes i have heard that many times that i7 will need more rading and probably a separate loop i love my qx9650 so i didn't upgrade my cpu
faster3200 : thanks for the advice, i think 600W is a good guess.
Yup! i feel like i'm running 6 turbines when i hear those fans
Thanks m8
Old 09-17-2009, 05:13 AM   #12
badboyze
Now that I figured GTX 360 alone can handle that loop, do you guys think that a push/pull setup will fit at the top of obsedian ? i hope the top don't fall apart .. i like obsedian because of the cable mang. and the nice black color .. any other case would be better for me
Old 09-17-2009, 06:46 AM   #13
millertime359
Xtreme Mentor
millertime359's Avatar
There are a couple of build logs with them. I haven't seen anyone with pics of the rad and MB mounted yet though. It might work with a little patience though.
If you had to, you could just mount it out side the case. There are other cases that would have more room, but I'm in the same boat as you. I REALLY like that case. From the photos I have seen so far, it seems really well thought out.
__________________
Project Millertime: The Core I5 build
Crunching/folding box on air: AMD Athlon X2 7750 Black Edition; Sapphire Radeon HD 4830; Gigabyte MA78GM-US2H; Lian Li PC-V351; Windows 7 RC
millertime359 is offline   Reply With Quote
Old 09-17-2009, 07:48 AM   #14
Caoder
Caoder's Avatar
Send a message via MSN to Caoder
man how thick would a push pull on those rads be O.O;;
Caoder is online now   Reply With Quote
Old 09-17-2009, 08:05 AM   #15
Hondacity
Hondacity's Avatar
skinnee's review of the hw gtx 360
http://skinneelabs.com/Radiators/HWL...60/GTX360.html
3000 is too noisy...the kaze 2000rpm fans should be adequate....
__________________
Hondacity is offline   Reply With Quote
Old 09-17-2009, 03:01 PM   #16
Chicken Patty
i have four of the 2000rpm ones and they are not bad at all. I would get those better.
__________________
Core i7 920
Nanya 6GB (3 x 2GB)
PNY 9800GX2
PCP&C 860W PSU
Old 09-18-2009, 05:19 PM   #17
badboyze
Thumbs up
Thanks for all the valuable suggestions guys.
Newegg has obsidian 800D in stock now!!
millertime359 - just bought mine now..
I'm thinking of doing a worklog expect loads of questions guys ..
Thanks all again
Old 09-18-2009, 05:23 PM   #18
millertime359
Xtreme Mentor
Thanks all again
Yet another build log that will make me itch for that case.
Good luck.
__________________
Reply
Thread Tools
Rate This Thread:
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
Powered by vBulletin® Version 3.7.0
Copyright ©2000 - 2009, Jelsoft Enterprises Ltd.
XtremeSystems
