11-25-2003, 06:13 AM
#1
Xtreme Mentor
1014 bios for P4C800/Deluxe
After the 1013 fiasko, a new bios for P4C800 and P4C800 Deluxe has been released on the german ftp server. Untill now no word on P4C800-E but i guess it will be up sooner or later.
Try it and post your results.
__________________
Asus Rampage II Extreme
Intel I7 920 D0 3930A @ 4.35GHz (20 X 217mhz) WC'ed
3 x 2GB G.Skill Trident 1600 @ 1740MHz (7-8-7-20-1T)
Asus 4870X2 @ 850/950MHz WC'ed
150gb Western Digital Velociraptor | 2 x 320gb Western Digital Caviar SE16 Raid0 | Seagate FreeAgent XTreme 1.5TB esata
Logitech Z-5500 | LG W2600HP 26" S-IPS LCD
MountainMods UFO | Zalman ZM-850HP psu
Watercooling setup:
1st loop -> Radiator: ThermoChill PA 120.3 | Pump: Laing DDC Ultra with Alphacool top | CPU: Swiftech Apogee XT |Chipset: Swiftech MCW-NBMAX | Tubing: PrimoFlex 1/2" Pro LRT
2nd loop -> Radiator: XSPC RX240 | Pump: Laing DDC Pro with Alphacool top |GPU: EK FC-4870X2| Tubing: PrimoFlex 1/2" Pro LRT
11-25-2003, 06:41 AM
#2
how r u joebar long time no see
__________________
11-25-2003, 12:07 PM
#3
.........are you going to try it first?  ..................
__________________
P4C800-E Dlx
2.4c @ 3.5+ ghz
Slk-800u w/T.T. Smart fan II w/ T.T. Ducting mod
2x256 OCZ EL-Gold 3700
2 x 37gig-Raptor in Raid O
ATI 9800XT
Antec TrueControl 550
11-25-2003, 12:21 PM
#4
Xtremely Large Member
We need a
__________________
I've heard it all, I've seen it all, I've done it all. I just don't remember any of it.
DFI LanParty UT NF3 | A-64 3200+ | 1Gb OCZ EL DDR PC-3500 Limited Edition
Radeon X800XT | Audigy 2 | 2x WD 74Gb Raptors | 60Gb IBM | 20Gb Maxtor
OCZ PowerStream 520w | Mach II GT Cooled
11-25-2003, 12:57 PM
#5
Originally posted by st0nedpenguin
We need a
 I cuncur
Pengy awsome pic!
A linky would be nice too
11-25-2003, 01:56 PM
#6
that guinnea pig is cute
__________________
20026 01 <-- 9500 NP (on air) CPU TEC Cooled.
Originally posted by FUGGER
Just the live video sex chat girls come to mind, not that I know anything about that
With detail settings maxed, full PS and VS support, and highest resolution available, my life runs at 60FPS solid.
11-25-2003, 02:09 PM
#7
Moderator
I'm going to flash right now and will let ya know
__________________
WORK/PLAY - - PCMark05 8,163 - - 3DMark05 15,749 -
DFI NF4 SLI DR Expert, Vapochill LS, FX60 ES SPMW 0536 "Naked" @ 3430mhz 1.70v 2xPi32 Stable
Mushkin Redline XP4000 2x1gig @ 264mhz 3-3-2-6 1T 2.8v, 7800GTX 540/1404, PC Power & Cooling 1KW
2x 74g WD Raptor Raid 0, 2x 300g Maxtor 16mb Raid 0, Maxtor 250g External, Creative X-Fi
KIDS -
MSI Neo2 w/3200+, Asus A8V Dlx w/3400+, Abit IC7-G w/2.8c, Asus P4C800 Dlx w/3.0c, DFI NF2 w/2500+
11-25-2003, 02:21 PM
#8
Moderator
No problems with flash, I used AsusUpdate from windows.
I didn't clear the CMOS after the flash as I have had problems with doing so, atleast with the 1013 bios.
__________________
KIDS -
11-25-2003, 02:49 PM
#9
........Link:
ftp://ftp.asuscom.de/pub/ASUSCOM/BIO...Chipset/i875p/
Warning:
This BIOS can only be flashed with
the following flashtool versions
(or higher versions) !
Do NOT use older versions !
ASUS LiveUpdate v5.22.02
ASUS AFUDOS v2.07
FINAL = beta Status
1014 = 1014.003
__________________
P4C800-E Dlx
2.4c @ 3.5+ ghz
ATI 9800XT
11-25-2003, 03:13 PM
#10
Tanx Thumper :thumbsup:
*update*
Had to rename the bios to P4C800.ROM and baddabing baddaboom, flashed with no problemo.
Runnin same speed, settings, yadda yadda.
11-26-2003, 06:12 AM
#11
Xtreme Mentor
Fine m8! U?
__________________
Watercooling setup:
11-26-2003, 06:14 AM
#12
Xtreme Mentor
I had no probs with 1013 bios. I'm going to flash it a post back.
__________________
Watercooling setup:
11-26-2003, 07:07 AM
#13
The 1014 for the P4C800-E Deluxe is also out, pick up a copy here.
__________________
11-26-2003, 09:27 AM
#14
Cheers St0ned :thumbsup:
Any reports as yet anywhere?
Will flash tomorrow
__________________
Intel P4 3.2 EE || Asus P4C800-E || Prometia Mach II || 2 x 256Meg HyperX 3500 || Antec TrueControl|| Sapphire Radeon 9800XT || 2x Raptors || Samsung 172T
OCAU 3DMark Team || 3DMark Compare: 26847 || World of Britney|| PCDB Entry
"Sundance is weird. The movies are weird. You actually have to think about them when you watch them. " -Britney Spears
11-26-2003, 09:52 AM
#15
It's going down quite well on the ABXForums, no reports of dead boards yet.
__________________
11-26-2003, 11:27 AM
#16
........Flashed and up and running  . PLEASE DO NOT JUST DOWNLOAD THE BIOS WITHOUT READING THE READ-ME..........
__________________
P4C800-E Dlx
2.4c @ 3.5+ ghz
ATI 9800XT
11-26-2003, 07:45 PM
#17
So does this BIOS make anything better ?? My boards been great, no problems, so dont se any reason to flash, well unless I could get some FSB
11-26-2003, 07:50 PM
#18
hey guys, u should wait for like a week before u flash anything on asus. After a week check the boards and see if the guineas complain of fuggered boards!
__________________
E6600 SL9S8 Malay
ASUS P5W64( no mods )
Mushkin (2 x 1GB) XP2-6400
ATI x850xt
2 x 150GB WD Raptor RAID
Thermalright Ultra-120
SilverStone ST56ZF 560W
11-26-2003, 08:00 PM
#19
.......I flash for the pure excitement of it.............
......found by "peroni" over at ABX:
- Fix extended F8 Menu that cant show all Devices,if you used more than one removables, HDD, and cdrom and BEV
- Revise extended memory size(16K--->64K)
- Revise Ultra DMA Mode max limit(ultra DMA mode 6--->5)
- Mute beep sound for USB device plug-in/plug-out
- Support new CPUs. Please refer to our website at: http://www.asus.com.tw/support/cpus...cpusupport.aspx
- Fix the system hangs after clear CMOS
__________________
P4C800-E Dlx
2.4c @ 3.5+ ghz
ATI 9800XT
11-27-2003, 07:49 AM
#20
Xtreme Mentor
Flashed it with no probs yet.
__________________
Watercooling setup:
11-27-2003, 11:51 AM
#21
No probs at all either
__________________
11-27-2003, 03:37 PM
#22
Banned
I flashed & found them to be worse than the 1007 Finals I was previously using.
11-27-2003, 04:30 PM
#23
I flashed 1014 yesterday but see no major improvements at all...especially with 5-4 divider, etc. Expected more from Asus but didn't get much!
11-27-2003, 06:13 PM
#24
Im having HUGE probs with this POS board. I dont like it and you cant make me like it
9/10 it wont even post and I sit here for 20 mins pressing reset and DEL or INS and then get into bios and make one change - eg put fsb 5 less - and then reboot and then again no post and we have to go thru the 20 min charade again....fooking pissing me off.....I want my Abit dammit
Had the above problems with both 1009 and 1014. Its not the cpu either cos I am rock solid at 4ghz for over an hour and then I use Windows reboot and then the PC wont POSt???!!!! A simple reboot from Windows and then the pc wont even post...now come on.....
I find the problem in the ranges of 245 to 255fsb and its mainly with the 5:4 divider. I put to 1:1 and we can POST and get into Windows straight away - well most times
Anyways, see how it goes today. When I get my 2nd P4C800-E back from RMA Im going to be selling both ASAP and grabbing a MAX3 :thumbsup:
__________________
11-27-2003, 10:36 PM
#25
Just deleted over 900 PMs
Is your HyperX 3500 CH5? Mine didn't like CH5 either.
__________________
Desktop:
NZXT Zero
Central Processing: ABIT IP35 Pro / Core 2 Duo E6850 @ 3.6Ghz / 4GB G.Skill F2-8000CL5D-4GBPQ
Cooling Station: Enzotech Ultra-X / Sharkoon Silent Eagle 120mm / Modded IP35 Pro Heatsink System
Storage Subsystem: WD Raptor 150GB / WD Caviar 640GB / WD GP 1TB / Samsung 18x DVD-R/RW
Networking Department: D-Link DIR-655 / Realtek Gigabit NIC
Visual Processing and Display: EVGA GTX 260 896MB Superclocked / BenQ 24" 1920x1200 LCD
Tonal Processing and Delivery: Auzentech X-Fi Prelude / Onkyo TX-SR304 / Athena S.5 5.1 / Velodyne VX-10
Peripheral Input: Razer Deathadder / Logitech LX710 / Steelseries 5L
Power Delivery: Corsair 620HX / APC BX1300LCD UPS
Midnight Blue Dell Inspiron 1720
Core 2 Duo T7500 @ 2.2Ghz
4GB PQI PC6400
NVIDIA 8600M GT 256MB @ 625/1250/1024
WD Scorpio 250GB (5,400RPM)
17" 1920x1200 LCD
< Nikon D300 >
| Thread Tools |
| Display Modes |
Rate This Thread |
Linear Mode
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
HTML code is Off
