XtremeSystems Forums
Go Back   XtremeSystems Forums > Hardware > Intel
Reply
Old 07-06-2007, 06:41 PM   #1
EnJoY
XIP
EnJoY's Avatar
Send a message via ICQ to EnJoY Send a message via AIM to EnJoY Send a message via MSN to EnJoY Send a message via Skype™ to EnJoY
E6850 "G0" on EVGA 680i AR
Got my new ES E6850 "G0" in today and decided to clean out the radiator at the same time. I also found that EVGA had released a new P29 bios designed specifically for these new chips, so I flashed that as well. I have only been in windows for around ~30mins, so I don't have any testing done. But here's a nice stock cpu-z/core temp shot. Overclocking results to arrive shortly...I promise.
Look at that idle temp...
Specs are the following:
CPU: E6850 (ES) G0 @ stock (1.3v set in bios)
Mobo: EVGA 680i rev. AR w/ P29 bios
RAM: Corsair 2x1GB PC2-10000C5 @ 3-3-3-6-1T 2.1v
VGA: BFG 7950GT
PSU: OCZ Powerstream 600w
Cooling: Water.
(EDIT: Check posts #55 for 4GHz prime, and #68 for 4.27GHz max!)
EnJoY is offline   Reply With Quote
Old 07-06-2007, 06:44 PM   #2
safan80
Xtreme Guru
safan80's Avatar
try 9x400 and lets see those temps!
__________________
Watercooling parts:
Pa120.3 rad (CPU)|PA120.3 (for video card)|GTZ on CPU
|stock cooling on chipset|Laing DDC w/ Petra'sTech DDCT-01s Top on cpu loop|aqua extreme 50z pump on gpu l
cpu i7 960 @???
old cpui7 920 3836A762 @ 3.7Ghz
Gigabyte EX58-UD5 F9e bios
12GB of G.skill (6 x 2GB)DDR3 perfect storm F3-16000CL8-2GBPS 7-7-7-21
2x bfg 285
new Dell 30"LCD 3008wfp oh the colors!
LG GGW-H20L
COOLER MASTER Real Power Pro RS-C50-EMBA-D2 1250watt for the cpu/mobo & video
OCZ600MXSP 600W for the hard drives
areca 1280ML with 2GB ecc of cache running in other 16x pci-e slot with battery backup running two raid 10 arrays 2TB boot array 6TB storage
sound card: Auzentech Forte 7.1 | Gigaworks S750 7.1 speakers
OSes: debian Linux unstable, and Windows XP pro x64 w/sp2| testing windows 7 x64 ultimate
safan80 is offline   Reply With Quote
Old 07-06-2007, 06:46 PM   #3
NaeKuh
Broken Gainestown
NaeKuh's Avatar
VGA: BFG 7950GT
Cooling: Water.
Uhhh... you are one lucky person to have ambients lower then 16C
Its hot as hell on the west coast. :\
__________________
Nadeshiko: i7 980 12GB DDR3 eVGA Classified
Lind: Dual Gainestown 3.07
NaeKuh is offline   Reply With Quote
Old 07-06-2007, 07:10 PM   #4
EnJoY
XIP
EnJoY's Avatar
Idle
Load
E6850 "G0" @ 3600MHz ~1.35v
33c load...
Old 07-06-2007, 07:18 PM   #5
orion23
orion23's Avatar
Not so impressive considering some E6600's can reach 3.6ghz with 1.35V or less, and that's a jump from 2.4ghz = 1.2ghz overclock
With the E6850 @ 3.0ghz, that's only a 600mhz overclock with about the same voltage!
__________________
Antec P180 SILVER
Abit P35 Pro
Intel E6750 C2D
Tuniq Tower 120 LED
OCZ 700W PSU
Crucial Ballistix 4 X 1GB PC2-6400 DDR2 800MHZ
Seagate 320GB SATA 2 HD's 7200.10 (X2)
BFG 8800GT 512MB
orion23 is offline   Reply With Quote
Old 07-06-2007, 07:19 PM   #6
louie101086
Send a message via AIM to louie101086
damn that great will it clock higher perhaps 4ghz
__________________
MY RIG: BLUE DEVIL
CASE*BLACK SILVERSTONE TJ07-MODIFIED
MONITER*32-INCH SAMSUNG WIDESCREEN LCD TV
OS*MICROSOFT XP HOME EDITION SP3
MB*GIGABYTE P35-DQ6 F9B BIOS
CPU*INTEL E7200 3.6GHZ 1.3v
RAM*2GB G.SKILL PK PC8500**DEAD**
PSU*PC POWER&COOLING BLACK QUAD 750W
HD*SATA MAXTOR 150GB 8MB CACHE & SATA WD 250 GB 16MB CACHE
GPU*GIGABYTE HD4670 @ 811/1100
MY WATERCOOLING SETUP
CPU*SWIFTECH APOGEE GTZ
PUMP*SWIFTECH MCP 655
RAD*SWIFTECH MCR320 W/ 3 SCYTHE ULTRA KAZE MED. SPEED
RES*T-LINE
TUBING*DURELENE PVC
COOLANT*DISTILLED WATER & PT NUKE
WORKLOG-Blue Devil TJ07
WORKLOG-Project X
louie101086 is offline   Reply With Quote
Old 07-06-2007, 07:40 PM   #7
XtremeTiramisu
XtremeTiramisu's Avatar
Originally Posted by orion23 View Post
Not so impressive considering some E6600 can reach 3.6ghz with 1.35V or less, and that's a jump from 2.4ghz = 1.2ghz overclock
Good point.
Almost everyone of us already has a C2D B2 stepping. The reason that makes us attracted to the new G0 stepping C2D or C2Q is not really the native 1333FSB but it's actually the lower voltage requirment from the chip clock for lock. I'd really love to see more and more solid OC results on G0 C2D/C2Q that runs cooler with lower volts clock for clock = higher OC-ability.
__________________
Xtreme Air-Cooled OC System:
Mobo: Asus Rampage Formula (X38 Edition) Rev 1.03G (BIOS: 0803)
CPU: C2Q Q6600 "G0" L723A765, VID 1.2625, 3720mhz, FSB 465*8, Vcore: 1.464, Idle/load temp: 31c/64c
CPU Heatsink: Thermalright Ultra120 Xtreme lapped (2* Scythe S-Flex SFF21F S-FDB 120mm Push-Pull configuration)
RAM: Kingston HyperX T1 2x2GB PC2-8500 (DDR2-1116)(5-5-5-15-3-52-6-3-8-3-5-4-6-4-6-14-5-1-5-5)(2.264 Vdimm)(Rated @ 2.3v default clock)
HDD: Western Digital Caviar Black 640GB WD6401AALS-00L3B (AHCI)
Video Card: XFX 8800GTS 320mb Xtreme, Core 612 Shader 1420 Mem 900 (Stock cooling)
Sound Card: Auzentech Meridian 7.1 (8788 chipset)
DVD: Pioneer 212D SATA DVD-RW
PSU: Corsair HX620W Modular
Xtreme Air Cooled Case: Antec 900 case | 3*120mm intake | 1*120mm & 1*200mm exhuast
OS: Vista Ultimate x64 SP1 Build 6001
XtremeTiramisu is offline   Reply With Quote
Old 07-06-2007, 09:18 PM   #8
Supertim0r
INTEL inside
Supertim0r's Avatar
4ghz prime stable next !
__________________
24/7 PC : Biostar Tpower P45, E8400 E0 @ 4.4ghz, 4gig G.SKILL F2-8000CL5D-4GBPQ, Asus 8800 Ultra, Corsair HX520w
benching stuff : P5K Premium, DFI LANParty Dk P35-T2RS, XBX2 <3..., few "D9" kit, few Q66 ES / E8400 / Q9550 ES, 8800GT and GTS, OCZ PS600W, Zeus 750w, Phase change, Tuniq, Ultra 120E...
Supertim0r is offline   Reply With Quote
Old 07-06-2007, 09:35 PM   #9
GripS
GripS's Avatar
I was noting the same thing from another guy here with a 6850. Everyone drooling over the 4+ghz. Unfortunately it took almost 1.6v+ to get there. Thus far i'm not too impressed with the infamous 'G0' stepping. I like many other people here expected higher clocks on stock volts.
__________________
My Rig:
Q6600 'G0' @ 3.6ghz(8x450)1.45v / DFI Lanparty LT P35 T2R / 4gb g.skill PC8500 PK / Sapphire HD4850 / 150gb raptor(OS/Games) + 500gb WD GP(Storage) + 80gb barracuda(Linux) / OCZ 600watt GameXstream
Family Rig:
AMD Opteron 170 @ 2.6ghz / DFI nf4 Ultra-D / 2gb g.skill PC4000 HZ / evga 7600GT / WD 200gb + Maxtor 80gb / Antec NeoPower 480watt
GripS is offline   Reply With Quote
Old 07-06-2007, 09:38 PM   #10
Envydia007
Envydia007's Avatar
I myself dont care about idle temp. We want 4GHz in orthos plus core temp readings in full load
__________________
INTEL Q6600 G0 @ 3.6GHz 1.4V
MUSHKIN 2X2GB @ 1066MHz 1.9V
GPU: EVGA GTX 260 216 @ 702/1404/2000
PPU: EVGA 9800GTX KO @ 738/1836/2250
ASUS P5E X38 @ 1600MHz FSB
X-FI TITANIUM FATAL1TY
WD 76GB X 2 RAPTORS RAID 0 10KRPM
WD 1TB CAVIAR BLACK 32MB STORAGE
CORSAIR HX1000W PSU
WINDOWS 7 PRO 64-BIT OS
HANNSPREE 28" 1920X1200 RESOLUTION
Envydia007 is offline   Reply With Quote
Old 07-06-2007, 10:58 PM   #11
scwam
How did you get a 6850 when you live in the US? Do you have friends in Europe to ship to you?
__________________
Petra's Tech Shop....the best service in watercooling.
E6850 testing on air
3x7200.10's
evga 8800gtx 620/1050
Many Ballistix (where to start?)
Abit IP-35 (std)
Storm rev. 2/MCW60 GPU
Pa120.3 w/shroud Denki 38's
Samsung 225BW
scwam is offline   Reply With Quote
Old 07-06-2007, 11:03 PM   #12
ChOmP
ChOmP's Avatar
Huh? He did 4ghz at 1.49v not 1.6. Here: http://www.xtremesystems.org/forums/...9&postcount=42
ChOmP is offline   Reply With Quote
Old 07-06-2007, 11:06 PM   #13
YukonTrooper
Land of the Midnight Sun
YukonTrooper's Avatar
He has a time machine dude, haven't you heard?
__________________
For my part I know nothing with any certainty, but the sight of the stars makes me dream.
YukonTrooper is offline   Reply With Quote
Old 07-06-2007, 11:12 PM   #14
dinos22
...you two characters
dinos22's Avatar
i know these run cooler but i've also noticed with newer CPUs some of the temp probes must be faulty as they are idling at the same or less temps than ambient
so please report your ambient there and exact cooling setup
__________________
Team.AU
Got tube?
Originally Posted by Gautam View Post
In the old days, LN2 benching was "cheating". Then LOD was "cheating". And so on and so forth...
dinos22 is offline   Reply With Quote
Old 07-06-2007, 11:19 PM   #15
The Nemesis
The Nemesis's Avatar
Another ES G0 stepping thread I sure hope we're not all getting excited for nothing. Now crank that thing to 4Ghz on air and run orthos
__________________
WorkStation
» Intel Core 2 Quad Q9450 L810B906@ 3.8GHz 1.35v » CoolIT Systems Domino A.L.C. » Asus Maximus II Formula » Visiontek All in Wonder HD Premium » 2GB Crucial 8500's 16FD's w/OCZ ramcool
» One Western Digital Raptor WD740ADFD » Samsung SH-S183L» Creative Audigy 2 Platnium » 700w OCZ GameXStream » Antec 900
The Unicorn
» Intel i7 920 3849B028 » Asus Rampage II Gene » BFG GTX 280's SLI » 6GB Kingston HyperX T1 Series » Antec Quattro 1000w PSU » Antec P180 Mini White
» Cooling : Swiftec Apogee GT w/i7 Mounting Adaptor » Swiftech MCW-NBMAX Northbridge Cooler » Swiftec MCP350-DDC1 » Swiftech MCR220-QP Res w/Scythe SlipStreams 110CFM
The Poseidon (Under Going Refit)
» 3GB Corsair Dominator TR3X3G1866C9DF » Tagan /\+ CS Black Pearl WCR
» Cooling : Thermochill PA120.2 w/Scythe SlipStreams 110CFM
The Yamato (BenchStation)
» Intel i7 950 3847A991 » EVGA Classified 760 » Two EVGA CO-OP Edition GeForce GTX 295's Quad SLI or Two Sapphire 5850's CF» 6GB Corsair Dominator GT TR3X6G1866C7GTF » Corsair 850HX 850W PSU » Microcool Banchetto 101
» Cooling : Dragon F1 Extreme Edition(LN2) » Custom SS by RunMc » Swiftech's Apogee GTZ » Swiftec MCP355/Laing DDC-2 w/XSPC Acrylic Reservoir » Swiftech MCR320 QP w/Scythe SlipStreams 110CFM
The Nemesis is offline   Reply With Quote
Old 07-07-2007, 12:05 AM   #16
EnJoY
XIP
EnJoY's Avatar
4GHz is certainly possible...but for how long?
Here's me just into windows. Since then I quickly ran pi 1m and now I think I am going to load up prime and call it a night. To be very honest, I don't see it being stable at this voltage for prime (1.55v). I should also mention that the temperatures at this speed and voltage are much more normal now (50c load), but still way cooler than my old Allendale, and it was lapped!
I'll update tomorrow with the best results I can get at 4GHz and beyond (if the board and chip will continue to cooperate.
Oh, and for those who are wondering whether or not the results from this chip will represent retail, I have no idea, in my experience ES's usually don't, but there are always exceptions. All I know is, I'm having fun.
Old 07-07-2007, 03:03 AM   #17
ineedaname
ineedaname's Avatar
I'm sorry but what kind of water cooling is this? Are you using a TEC?
Also what are your ambient temps for those?
Unless you're using a TEC I REALLY doubt those temps are real. No offense to you or anything as I really do appreciate your posting. I'm just really skeptical about whether core temp is reporting accurate temps.
__________________
CPU: Q6600 @ 3.6ghz G0 Week 37B
Mobo: Asus P5k Deluxe
Cooler: TRUE 120 (150cfm Delta)
2xHR-05
2xHR-09
Mem: G.Skill 4x1Gb 6400HZ
Vid: HIS 4850
HDD: 80Gb 16mb Cache Raptor
500Gb 7200.11 Seagate
PSU: Enermax Noisetaker 600w
Case: Thermaltake Armor (4x120mm 104CFM Panaflo)
3dmark06: 16k
ineedaname is offline   Reply With Quote
Old 07-07-2007, 03:59 AM   #18
Solarfall
Xtreme Guru
Solarfall's Avatar
Send a message via AIM to Solarfall Send a message via MSN to Solarfall
where do people find these ES samples ??
btw sweet temps EnJoY... keep tweaking bro.
__________________
Evga X58 sli under cascade
http://www.xtremesystems.org/forums/...d.php?t=219788
Evga X58 Sli ultimate overclocking/ overview/ discussion thread
http://www.xtremesystems.org/forums/...d.php?t=221082
proud owner of E8600 Q822A435
Solarfall is offline   Reply With Quote
Old 07-07-2007, 06:01 AM   #19
DMH
DMH's Avatar
ES can probably be found in E-Bay
DMH is offline   Reply With Quote
Old 07-07-2007, 08:53 AM   #20
EnJoY
XIP
EnJoY's Avatar
ES can be found from many people, you just have to know who they are and be in their trust.
As for the ocing, the board is giving me some stability problems right now, I'm gonna try a few more things. Prime was a big no no at 4ghz with that voltage with a hard reset. We'll see what I have to do to get it stable.
Old 07-07-2007, 08:55 AM   #21
EnJoY
XIP
EnJoY's Avatar
The watercooling is a AquaXtreme MP05-LE cpu block, a Swiftech MCW60 gpu block, a Laing D5 pump, and a Black Ice Pro 3 radiator with Yate Loons.
Old 07-07-2007, 09:15 AM   #22
aussie-revhead
aussie-revhead's Avatar
Good work there son , keep it going
Of course we are excited - some people are impossible to please...
yeah what percentage of all c2d can do that? We have plenty of overclockers here in Aus and I bet we dont even have one here that can do that...
Australia Coke FTW!!!
LOL @ Cathar
__________________
Gamer CM-690 EP45-DS3R Q8200 8GB GTX275 Fbox e2160 - EP35.DS3 - 9600gso (UNTIL GTX295 come down)NetBox EG45M E4300 64GB Falcon W7 sff PB- (G92 vmod - 17887) (2x4870 24956) Folding for team 24
http://www.youtube.com/watch?v=OFsbfEIy3Yw
aussie-revhead is offline   Reply With Quote
Old 07-07-2007, 01:43 PM   #23
ziddey
Send a message via AIM to ziddey
canadian sprite sucks compared to us sprite. i think their coke sucked too, but i don't recall. at least not as much as their sprite.
__________________
E8400 8x500=4000 | ABIT IP35-E
2x2GB Tracer PC2-6400 1:1 500MHz 5-5-5-15 2.0V
Galaxy 8800GT 800/2000/1100 1.3V | 80GB X25-M G2 + 1.5TB 7200.11 | XFiXG
Fuzion | MCW60 | DDC2+Petra | Coolrad22T+BIP1
Merom 13x133=1733 1MB L2 0.950V
ziddey is offline   Reply With Quote
Old 07-07-2007, 02:15 PM   #24
YukonTrooper
Your right. US Sprite and Coke probably contains twice the sugar and therefore tastes better. Fine with me, look at the obesity in the States .
You should concentrate on where it counts. US beer sucks compared to Canadian beer. +10 for Canada.
BTW how did you manage to start talking about Sprite and Coke in a thread about a processor?
__________________
Old 07-07-2007, 02:19 PM   #25
Emerica
Xtreme Cruncher
Emerica's Avatar
Send a message via AIM to Emerica Send a message via MSN to Emerica
Wow man you've got some really nice temps on that chip. Good luck getting 4GHZ stable.
__________________
Workstation :
Q6600 @ 3.2ghz/Scythe Infinity (Screw mount mod)
GA-P35-DS3L (F7)
4GB G.Skill @ 400mhz 4-4-4-12
BFG Nvidia 7600gt
WD 250GB SATAII 16MB (OS/Programs)
Seagate 250GB SATAII 16MB (Storage)
NEC DVD+/-RW
Antec NeoHE 550W
X-Fi Xtreme Music
Razer Copperhead
MS Natural Ergonomic 4000 (Best KB ever!)
Windows 2008 Enterprise Server x64
Laptop:
Dell Latitude D610 - Pentium M 750 1.86Ghz / 1GB RAM
Emerica is offline   Reply With Quote
Reply
Thread Tools
Rate This Thread:
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
XtremeSystems
