XtremeSystems Forums
Go Back   XtremeSystems Forums > Software > Operating Systems
Reply
Old 06-30-2007, 06:00 PM   #1
EnJoY
XIP
EnJoY's Avatar
Send a message via ICQ to EnJoY Send a message via AIM to EnJoY Send a message via MSN to EnJoY Send a message via Skype™ to EnJoY
Unable able to sign on to Live Messenger (Error Code: 80048820)
As the title says, for seemingly no reason at all, I am now unable to sign in to Windows Live Messenger. I haven't changed anything, but now it pops up with this message with the following:
I don't what why it's happening, but it started occurring about a week ago and it's got me puzzled. I need Live Messenger for many important contacts, so I can't just stop using. I have uninstalled and reinstalled with the latest version, including the latest beta, several times and cleaned my system out with CCleaner in between and still nothing.
Any help?
EnJoY is offline   Reply With Quote
Old 06-30-2007, 06:10 PM   #2
rommel
I had the same problem on my laptop at home. I've uninstalled messenger and rebooted and it didn't help. There are 7 pc's at home with messenger on them. I found on another forum that it could be my router, it's uPnP capabilites may have used up all the available ports for messenger. Messenger would only open without errors if I was to unplug my ehternet cable from my laptop. Anyways to make a long story short, I reset my router(not factory default reset, just a reboot), released my laptop's ip lease and renewed it and it worked. Maybe you could give this a try, Good Luck.
__________________
Rommel
Intel DQ35JO bios v1056
Q6600
GeCube ATI HD3870 CAT 9.6
4GB Crucial Anniversary 3-3-3-12 @ 2.2v (All Dead Now, All Died with no memory O/C after 1 yr)
Waiting on Replacement Ballistix
2x WD Velociraptor 150GB RAID0
4x WD 500GB 16MBCache 7200RPM Data Drives
Enermax Infiniti 720W
Antec 900
Optiarc DVD RW AD-5170A
W7 RC Ultimate Build 7232
rommel is offline   Reply With Quote
Old 06-30-2007, 06:46 PM   #3
EnJoY
XIP
EnJoY's Avatar
Thanks. I'm actually not even on a router at the moment though. And I actually just released and renewed my IP earlier today to no avail.
Old 06-30-2007, 06:49 PM   #4
Rattle
I hate windows live messanger, i still use msn 7.5, everytime i use the new one i have issues.
__________________
i7 860/True 120
GA P55 UD6/4gb Ripjaws
HD5850/Benq G2400WD
XFI Titanium/beyer dt770 pros
Klipsch PM 2.1/WD 640 Black
Corsair 750/HAF 932
HEAT
Rattle is offline   Reply With Quote
Old 06-30-2007, 06:56 PM   #5
Ashraf
Royal Administrator
Ashraf's Avatar
Windows Live Messenger is junk like Norton exactly. When you uninstalled it completely, the files are still floating around on your hard disk.
Ashraf is offline   Reply With Quote
Old 06-30-2007, 07:06 PM   #6
Ashraf
Royal Administrator
Ashraf's Avatar
Error code: 80048820
http://www.computerperformance.co.uk...e_80048820.htm
Extended error code: 80048412
http://imunplugged.spaces.live.com/b...6E6!2180.entry
Old 06-30-2007, 07:17 PM   #7
EnJoY
XIP
EnJoY's Avatar
Haha....don't laugh, but my date was somehow set at August 30th, rather than June. Yea, I'm dumb.
Thanks guys.
Old 06-30-2007, 07:31 PM   #8
Rattle
i have done that more than once
__________________
i7 860/True 120
HD5850/Benq G2400WD
Corsair 750/HAF 932
HEAT
Old 07-01-2007, 12:49 AM   #9
justin_c
Xtreme Cruncher
justin_c's Avatar
try this, fixed some of my msn woes:
make a txt file, enter this
regsvr32 Dssenh.dll /s
regsvr32 Gpkcsp.dll /s
regsvr32 Slbcsp.dll /s
regsvr32 Sccbase.dll /s
regsvr32 Softpub.dll /s
regsvr32 Wintrust.dll /s
regsvr32 Initpki.dll /s
regsvr32 Rsaenh.dll /s
regsvr32 Mssip32.dll /s
regsvr32 Cryptdlg.dll /s
regsvr32 Msxml3.dll /s
then save, rename it to a .bat extension, then execute with messenger closed. then startup again. it reregisters some broken dlls.
justin_c is offline   Reply With Quote
Reply
Thread Tools
Rate This Thread:
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
XtremeSystems
