XtremeSystems Forums
Go Back   XtremeSystems Forums > Hardware > Computer Cases
Reply
Old 06-28-2007, 01:47 AM   #1
smartasien
Modding Sidepanel, but what looks best?
I wanna mod my sidepanel but i'm not sure which way would be good.
Heres one w/ the upper window as clear plexiglass and bottom as black polyethylene black mesh.
Both windows are clear plexiglass
Heres one w/ the top black plexiglass and bottom black mesh
Both windows are black plexiglass
One w/ just one big clear plexiglass window
Yea these are just some examples I made, can you guys think of any others that might look good?
__________________
smartasien is offline   Reply With Quote
Old 06-28-2007, 01:51 AM   #2
SerialSniper
SerialSniper's Avatar
Send a message via MSN to SerialSniper
I like the second one best.
You could make a design/picture from the metal. Like flames or tribal. Or just some cool looking random shape.
__________________
SerialSniper is offline   Reply With Quote
Old 06-28-2007, 02:47 AM   #3
smartasien
true that'd b pretty cool, but i'm just a noob at dremeling i don't think i could do it lol. i'd probably screw up along the way.
__________________
Old 06-28-2007, 03:06 AM   #4
OpTioN
OpTioN's Avatar
IMO the first is the best, instead of those 2 regular 80mm fans, put in some green LED fans and it'll be awesome
OpTioN is offline   Reply With Quote
Old 06-28-2007, 11:10 AM   #5
Jimmer411
Jimmer411's Avatar
1 big black window.
Everyone does flames/tribal.
__________________
Phenom 9950BE @ 3.24Ghz| ASUS M3A78-T | ASUS 4870 | 4gb G.SKILL DDR2-1000 |Silverstone Strider 600w ST60F| XFI Xtremegamer | Seagate 7200.10 320gb | Maxtor 200gb 7200rpm 16mb | Samsung 206BW | MCP655 | MCR320 | Apogee | MCW60 | MM U2-UFO |
A64 3800+ X2 AM2 @3.2Ghz| Biostar TF560 A2+ | 2gb Crucial Ballistix DDR2-800 | Sapphire 3870 512mb | Aircooled inside a White MM-UFO Horizon |
Current Phenom overclock
Max Phenom overclock
Jimmer411 is offline   Reply With Quote
Old 06-28-2007, 12:18 PM   #6
95blackz26
i big window with cutouts in the bottom part for a couple 120mm fans or just 1.
__________________
95blackz26 is offline   Reply With Quote
Old 06-28-2007, 01:47 PM   #7
smartasien
Option, I just took some random pictures of 120mm fans off SVC i wasn't sure on the size though, its totally random.
ya i'm not into flames anyway. the blackplexiglass would b nice, but i think it might look weird since the rest of the case is silver. I've seen someone w/ a all black case w/ a black plexiglass window, and uv blue coolant, that was freaking awesome.
Iono i think the one fan acrylic cut out is kinda boring but may b i'll do that.
__________________
Old 06-28-2007, 04:01 PM   #8
C'DaleRider
C'DaleRider's Avatar
2-way mirror for your window. Lights on and you see through it.....lights off and it's a mirror. Nice effect.
__________________
Papa: Q6600 @ 3.6GHz @ 1.34V, Asus Maximus Formula, 4 x 2GB Mushkin Redline DDR2-1000, Asus HD4870, Antec Sig. 850, Lian-Li/RF case....WC'd via D-Tek FuZion w/quad nozzle, EK S-Max on NB, Laing DDC2 w/XSPC top, 2 x Feser 240's & one TC 120.1 rads.
Momma: Xeon 3210 @ 2.8GHz, Gigabyte P965-DS3, 4 x 1GB Ballistix DDR2-800, Asus HD3870 TOP, Enhance ENP5150-GH, Lian-Li/RF case, HK Champagne 2.1, Xigmatek HDT cooler
C'DaleRider is offline   Reply With Quote
Old 06-28-2007, 06:39 PM   #9
virtualrain
Whatever you do, I would have the window smaller than shown in those pics... there's no point showing the horizontal cross brace under the PSU or the drive bay rails either. Focus the attention on your motherboard and tubing with a window specifically sized for that.
If your case is silver, I like the mirror idea or some silver mesh. MNPCTech modders mesh has such a large opening in the mesh you can clearly see through it which is cool.
virtualrain is offline   Reply With Quote
Old 06-29-2007, 06:17 AM   #10
Prelector
Prelector's Avatar
I used a silver NZXT Apollo case, and replaced the side window with the ACRyan black mesh. It's a smaller opening mesh (which I wanted), so with no internal case lights, you can barely see through it. But, when the internal case lights are on (i've got a switch for them) the mesh allows you to see the internals fairly well. Basically, same idea as 2way mirror window, only the mesh gives increased cooling/venting for air systems
__________________
Black Hypercube
Processor: Intel Core 2 Duo E8400
Motherboard: DFI Lanparty JR P45-T2RS
Memory: G.SKILL GBHZ 4Gb
Video Card: BFG GTX 280 OC
Case: Lian-Li V350 Black
Power Supply: Corsair HX620W
Cooling: Thermalright SI-128 SE| Scythe Slipstream 1200rpm x3
Temps: TBD Idle | TBD Peak | 25c Ambient
Silver Apollo
Processor: Intel Core 2 Duo E6600 L632F
Motherboard: Intel D975XBX2
Video Card: BFG 8800GTS
Case: NZXT Apollo Silver Modded
Power Supply: Thermaltake Toughpower Modular 700w
Cooling: Thermalright SI-128 | Scythe S-Flex 1600rpm x3
Temps: 30c Idle | 40c Peak | 25c Ambient
Prelector is offline   Reply With Quote
Old 06-30-2007, 04:58 AM   #11
p8ntslinger676
p8ntslinger676's Avatar
I like the last one, and seeing as you are new to using a dremel it would be the easiest, just remember to take your time and dont go too fast
__________________
Media PC:[AMD x2 4800][MSI K9N-SLI][2x1gig Corsair DDR2 800][ATI 3650 AIW][Asus Xonar D2X][500gig Samsung SATA][Crap Antec Case and PSU]
p8ntslinger676 is offline   Reply With Quote
Reply
Thread Tools
Rate This Thread:
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
XtremeSystems
