XtremeSystems Forums
Go Back   XtremeSystems Forums > Hardware > Intel > Intel Info And Support
Reply
Old 06-23-2007, 11:20 PM   #1
cinders
cinders's Avatar
Been Away 18 Months - Advice on Motherboard / CPU
Hey Everyone.
I've been away from the scene for 18 months (been living abroad) and have just got back and decided to build a new machine.
It's nice to see some old faces I recognise on this forum!
Now my last setup was a watercooled FX-55 @ 3Ghz and an MSI K8N motherboard. Things have certainly moved on since then and I haven't got a clue what's popular today. Back in those days the MSI K8N was the choice of motherboard.
I was after some advice to see what the most popular CPU / Motherboard . Memory combination is for overclocking on plain old air.
I've been told you can get over 3Ghz on Air with the Core 2 Duo E6600?... Is this CPU a good choice?...
Can anyone advise me on what choice of motherboard everyone is using?...
What about memory?... When I was last on the scene OCZ VX was the enthusiasts choice.
Any help advice for my new setup would be gratefully appreciated!
Peace,
Cinders.
__________________
Desktop:
Intel Q9550 SLB8V CPU un-opened in Box
Gigabyte EG45M-UD2H un-opened in Box
8Gb DDR2 Crucial Memory un-opened in Box
2 x 1Tb WD Caviar Green (RAID-1 Storage)
80Gb Intel X25-M SSD (System)
No Graphics Card (yet)
No PSU (yet)
No Case (yet)
Laptop:
Lenovo Thinkpad X200s
4Gb DDR3 Ram
cinders is offline   Reply With Quote
Old 06-23-2007, 11:25 PM   #2
michaLcoughliN
michaLcoughliN's Avatar
Send a message via MSN to michaLcoughliN
p5kDeluxe = for mobo p35 chipset
Q6600 dropping to $266 in july22nd. (quad core) 8mb cache.
michaLcoughliN is offline   Reply With Quote
Old 06-23-2007, 11:31 PM   #3
[XC] serlv
XSDCMF
[XC] serlv's Avatar
for air cooling...
Thermalright Ultra 120 Xtreme HS with maybe a nice 75 CFM Minebea 120mm fan
or, a Tuniq Tower 120
RAM...
there are so many good, cheap choices right now
Anything with Micron D9 chips...
Crucial Ballistix, GSkill's, Mushkin, others
__________________
running octohamsters, some quadrohamsters, ... and, the kitchen sink!
Proud member of top-ranked XS teams! XS~WCG and XS~D2OL
I am DCManiak on the WCG team, ser on the D2OL team
[XC] serlv is online now   Reply With Quote
Old 06-23-2007, 11:35 PM   #4
cinders
cinders's Avatar
Thanks for the advice. Looks like I have to learn everything over again!
Do I go for DDR2 or DDR3 Ram?...
Quad C2D is out of my range - looking online now they're around £346. Ouch.
What's does the P35 chip set offer over the 965P?...
I'm looking for a middle-spec system. I don't want to go too crazy like last time!...
__________________
Desktop:
No PSU (yet)
No Case (yet)
Laptop:
4Gb DDR3 Ram
Old 06-23-2007, 11:35 PM   #5
TouGe
[XC] Xtreme Cruncher
TouGe's Avatar
Send a message via MSN to TouGe
After seeing what eva has done w/ the P5K Deluxe its hard not to recommend the board. Mine is off on RMA due to a bad BIOS flash but I'm ready to retire my 680i for it. Also, as suggestion above, if you want to stick with air, the TR 120 extreme is a very good cooler.
__________________
QX 9650 | Maximus II Formula | G.SKILL 4GB (2 x 2GB) PC2 8500 | Sapphire 4850 X2 2GB| Auzen X-Fi Prelude 7.1 | 3x's WD 150GB Raptors & 2x's 1TB Seagate 7200.11 | Silverstone OP1200 | SilverStone TJ07 | Dell 2707WFP
EK-RES 250 --> Swiftech MCP655 --> Apogee GTZ --> Enzotech Sapphire NB --> Feser X-Changer 360
TouGe is offline   Reply With Quote
Old 06-23-2007, 11:37 PM   #6
Brother Esau
D.F.I Pimp Daddy
Brother Esau's Avatar
Get the E6420 I can get 3.3GHZ out of mine and get the G-SKILL DDR2 800 F2-6400PHU2-2GBHZ I have a set that I just got and I am prime stable @920MHZ @1:1 and they overclock much higher if you run unlinked!
For Motherboard I would get the D.F.I 680 LT or a P35 Board would have got the D.F.I 680 LT myself but they had released it 3 days after I finally bought the EVGA 680 i A1 which is also a very good board and I like it very much!
Alos Intel will be cutting prices on July 22nd if you can wait till then and you can pick up a Q6600 or E6850 for $266.00 there or abouts! If you cannot wait pick up the E6420 for $186.00 like I did untill price cuts as I said I run 3.2GHZ 24/7 stable on 1.33 Vcore
I have a couple month old Tuniq Tower 120 that I am getting rid of thats in Mint condition that I will let go for $40.00 if you want it?
__________________
D.F.I LanParty DK 790FXB-M3H5 ~ 7/27/2009 ~ "Beta" Bios
AMD Phenom II 720 Black Edition ~ For Bios Testing
Custom Water
2x2gb Crucial Ballistix Tracer 1333mhz 6-6-6-20
POWERCOLOR AX3870 X2 CROSSFIRE
ULTRA X3 1000w
Danger Den Torture Rack
Brother Esau is offline   Reply With Quote
Old 06-23-2007, 11:43 PM   #7
TouGe
TouGe's Avatar
If the quad is out of your price range then DDR3 will more than likely be too expensive as well. I plan on holding off on DDR3 until next year when I step up to the P38 chipset and the Nehalem processor.
I've never owned an Intel chipset before the P5K D so I can't comment on the difference but from reading Eva's post it seems to be a step up. Here's some links that might interest you:
http://www.anandtech.com/cpuchipsets...oc.aspx?i=2991
http://www.anandtech.com/cpuchipsets...oc.aspx?i=2993
http://www.anandtech.com/cpuchipsets...oc.aspx?i=2995
and of course Eva's post on this site
http://www.xtremesystems.org/forums/...d.php?t=144199
I guess it all depends on how much you want to spend but for pure overclocking you can't beat the P5K Deluxe.
__________________
Old 06-23-2007, 11:55 PM   #8
Chewbenator
Chewbenator's Avatar
I would go with DDR2 because not only are the prices insanely low right now, but DDR3 has some quirks to work out and is at the $400 mark for 2 gigs. There has been some news that DDR2 prices might be at there lowest right now, and that the prices will go up, so I would get the ram now.
As for CPU, the Q6600 @ $266 seems like the deal everyone is talking about. If you want, you can see what the new Intel and AMD chips can do this fall. But, that deal, which btw is happening on the 22nd of July, should not disappoint.
P35 has the advantage of being able to work with the new Intel chips coming out this fall. As far as overclocking there have been numerous +500 and even +600 FSB clocks on the P35, so it has an advantage in that area as well. The p5k-deluxe has been doing well around here, but offerings from Gigabyte, there are alot, have been good as well. Also on the motherboard front there is the X38, while the P35 is about on par as P965, the X38 seems to be the replacement for the 975X. If you are into Multi-GPU solutions you might want to see how this chipset plays out this fall.
__________________
i5 750 @ 3.2 Ghz, stock volts on stock cooling
4GB G.Skill DDR3-1600 7-7-7-21
Gigabyte P55-DS2
EVGA GTX260 192shader
Chewbenator is offline   Reply With Quote
Old 06-24-2007, 12:41 AM   #9
cinders
cinders's Avatar
Thanks for the advice guys - it's appreciated!...
I'm definitely going to go for the E6420 until I can buy a quad-core in July when the prices drop.
I've always admired GSKILL ram, so will get myself the sticks you recommended. DDR2 will do me nicely.
I'm also going to go with the P5K-D Motherboard.
Brother Esau - I'd love to buy that heatsink from you. Only problem is I live in Koh Samui, Thailand. Would you be able to post it over for me?... Fedex gets here no problem. Maybe you could PM me?... I can pay you via PayPal.
My friend is going to Fed-Ex me out the GSKill RAM.
Again, thanks for all the advice.
Cinders.
__________________
Desktop:
No PSU (yet)
No Case (yet)
Laptop:
4Gb DDR3 Ram
Old 06-24-2007, 06:20 AM   #10
dnottis
Xtreme Mentor
dnottis's Avatar
E6420 - mine does up to 3712 orthos stable, great value as most will do 3.4 - 3.5 easily.
Asus P5B Deluxe - can easily vdroop mod, still overclocks better and is usually slightly faster than P5K. BIOSes have made it very stable and mature.
Get some nice (OCZ, Crucial, Mushkin) DDR2-1000 that way u have some overhead for overclocking it as well.
__________________
Q9550 @ 4.105 Ghz
Gigabyte P45 UD3P F9
G.Skill PC2-8800 DDR2-1100 8GB Memory
1/2" ID Masterkleer, Swiftech MCP-655, Thermochill PA120.3 Rad, D-Tek FuZion pro mounted, FuZion GFX 2
Cooler Master UCP 1100 Watt PSU
MSI HD5870 1Ghz (1.16v), 1300Mhz
Lian Li PC V-2000
Acer X222Wbd 22" LCD
3 x WD 640GB WD6400AAKS HD
Pic of my watercooled rig
dnottis is offline   Reply With Quote
Old 06-24-2007, 03:54 PM   #11
orion23
orion23's Avatar
Definately buy a P35 chipset board. Newer, support for 1333 FSB and Quad Core.
I own the P5K Deluxe and love it. Others seem to like the Gigabyte or the Abit P35 boards. Look around and make a decision based on your RAID needs, board layout, SATA ports...
Buy a GREAT cooler from start. Best is the Thermalright Ultra 120 (or Xtreme), followed by the cheaper Tuniq Tower 120.
For the RAM, the G.SKill will be fine, but you should be looking into DDR2-1000 or 1066 (PC2-8000, PC2-8500). DDR2 can be very cheap now days...
For the CPU, if you cannot wait, then the 6420 or the E6600 will be just fine!
__________________
Antec P180 SILVER
Abit P35 Pro
Intel E6750 C2D
Tuniq Tower 120 LED
OCZ 700W PSU
Crucial Ballistix 4 X 1GB PC2-6400 DDR2 800MHZ
Seagate 320GB SATA 2 HD's 7200.10 (X2)
BFG 8800GT 512MB
orion23 is offline   Reply With Quote
Old 06-24-2007, 07:31 PM   #12
michaLcoughliN
ram is going up in price if you already havnt noticed... Sooooo Ide purchase the ram as soon as possible because its still said to climb within the enxt month 30-40%..
Old 06-24-2007, 08:05 PM   #13
cinders
cinders's Avatar
Thanks for all the advice, it has been excellent.
I'm definitely going for the P35 chipset so I can upgrade to quad-core in the future. I'm going to go with a E6420 for now.
I live in Thailand and the only mainboard I can get out here is the:
ASUS P5K LGA 775 Intel P35 ATX Intel Motherboard - Retail
- it's not the deluxe version - will this do?...
What is the difference between this and the deluxe version?...
Looking at specs it seems the deluxe version comes with wi-fi and an extra x1 PCI-E slot?...
Thanks again,
Cinders.
__________________
Desktop:
No PSU (yet)
No Case (yet)
Laptop:
4Gb DDR3 Ram
Old 06-24-2007, 08:10 PM   #14
`danny
`danny's Avatar
I have a P5k Deluxe and love it and I imagine the vanilla version would be almost or just as good as the deluxe.
__________________
Intel E6420~3504mhz@1.43V
ASUS P5K Deluxe
2x1GB Crucial Ballistix 5-5-5-10@DDR1051
EVGA 320MB 8800GTS~610/1840
574GBs Of Storage
OCZ GameXStream 700W PSU
Thermalright Ultra 120 Extreme
Logitech G15 & MX518
Thermaltake Armor Series
Fiber out --> Headroom 2005 DAC --> Little Dot II++ --> Senn HD595s
`danny is offline   Reply With Quote
Old 06-25-2007, 03:43 AM   #15
cinders
cinders's Avatar
Again, thanks for the advice. I have everything sorted out now except for the RAM.
Can anyone recommend me 2Gb Of DDR2-1000 or 1066 RAM (2 x 1Gb)
I've been looking online this seems like a good deal:
OCZ Gold 2GB (2 x 1GB) 240-Pin DDR2 SDRAM DDR2 1000 (PC2 8000) Dual Channel Kit Desktop Memory Model OCZ2G10002GK - Retail @ $169
or
G.SKILL 2GB (2 x 1GB) 240-Pin DDR2 SDRAM DDR2 1066 (PC2 8500) Dual Channel Kit Desktop Memory Model F2-8500CL5D-2GBHK - Retail @ $179
Any other suggestions?
Thanks,
Cinders.
__________________
Desktop:
No PSU (yet)
No Case (yet)
Laptop:
4Gb DDR3 Ram
Old 06-25-2007, 10:32 AM   #16
orion23
orion23's Avatar
Best RAM:
http://www.buy.com/prod/crucial-ball...204681868.html
$140 shipped, and if you use google checkout, you can get a $10 discount making it $130 for the best RAM, + you get cool LED's!
__________________
Antec P180 SILVER
Abit P35 Pro
Intel E6750 C2D
Tuniq Tower 120 LED
OCZ 700W PSU
BFG 8800GT 512MB
Old 06-25-2007, 07:55 PM   #17
cinders
cinders's Avatar
Originally Posted by orion23 View Post
Best RAM:
Thanks orion - Ordered!... Now I have to get my friend to post them to Thailand!...
I notice you have 3 drives in your system - how you got them configured?... All in RAID-0 or two in RAID-0 and one separate for redundancy?...
__________________
Desktop:
No PSU (yet)
No Case (yet)
Laptop:
4Gb DDR3 Ram
Old 06-25-2007, 08:15 PM   #18
CedricFP
CedricFP's Avatar
God those Ballistix Tracers are cheap.
Here in HK, we don't get cheap GMH
I got my GSkill HZ's for 1600 HKD - thats about 200 USD. This was just 3 weeks ago as well. All the other stuff is Patriot or Super Talent - none of the models with GMH...
__________________
"Language cuts the grooves in which our thoughts must move" | Frank Herbert, The Santaroga Barrier
i7 920 3924A 205x21 / 4315 | 4870x2 | EVGA M-ATX X58 | 6GB Corsair Dominator | Corsair HX1000 | Intel X25-M 160 G2 | OCZ Vertex 60 | WD 320 || Apogee XT - XSPC FC | (2)DDC3.2 | (2)PA 120.2 | (2)BI SR-1 120 || MM H2G0
CedricFP is offline   Reply With Quote
Old 06-26-2007, 03:07 AM   #19
Soulburner
Just deleted over 900 PMs
Soulburner's Avatar
The G.Skill HZ's are down to $115 @ Newegg. The cheaper version with the red heatspreader is around $85.
__________________
Desktop:
NZXT Zero
Central Processing: ABIT IP35 Pro / Core 2 Duo E6850 @ 3.6Ghz / 4GB G.Skill F2-8000CL5D-4GBPQ
Cooling Station: Enzotech Ultra-X / Sharkoon Silent Eagle 120mm / Modded IP35 Pro Heatsink System
Storage Subsystem: WD Raptor 150GB / WD Caviar 640GB / WD GP 1TB / Samsung 18x DVD-R/RW
Networking Department: D-Link DIR-655 / Realtek Gigabit NIC
Visual Processing and Display: EVGA GTX 260 896MB Superclocked / BenQ 24" 1920x1200 LCD
Tonal Processing and Delivery: Auzentech X-Fi Prelude / Onkyo TX-SR304 / Athena S.5 5.1 / Velodyne VX-10
Peripheral Input: Razer Deathadder / Logitech LX710 / Steelseries 5L
Power Delivery: Corsair 620HX / APC BX1300LCD UPS
Midnight Blue Dell Inspiron 1720
Core 2 Duo T7500 @ 2.2Ghz
4GB PQI PC6400
NVIDIA 8600M GT 256MB @ 625/1250/1024
WD Scorpio 250GB (5,400RPM)
17" 1920x1200 LCD
< Nikon D300 >
Soulburner is offline   Reply With Quote
Old 06-26-2007, 03:14 AM   #20
shiznit93
shiznit93's Avatar
do you mean this http://www.newegg.com/Product/Produc...2E16820231098?
Are those also the good mircon chips?
__________________
Core i5 750 3.8ghz, TRUE 120 w/Panaflo M1A 7v
ASRock P55 Deluxe
XFX 5870
2x2GB GSkill Ripjaw DDR3-1600
Samsung 2233RZ - Pioneer PDP-5020FD - Hyundai L90D+
Raptor WD1500ADFD - WD Caviar Green 1.5TB
X-FI XtremeMusic w/ LN4962
Seasonic S12-500
Antec P182
shiznit93 is offline   Reply With Quote
Old 06-26-2007, 05:55 AM   #21
orion23
orion23's Avatar
Standard operation, all independent. I do have AHCI enabled though!
I've never bothered with RAID, don't even know the advantages. Some say it might be faster. One day when I'm bored enough I'll give it a shot!
__________________
Antec P180 SILVER
Abit P35 Pro
Intel E6750 C2D
Tuniq Tower 120 LED
OCZ 700W PSU
BFG 8800GT 512MB
Old 06-26-2007, 06:28 AM   #22
shiznit93
shiznit93's Avatar
Not a very Xtreme statement sir...
__________________
ASRock P55 Deluxe
XFX 5870
Seasonic S12-500
Antec P182
Old 07-16-2007, 08:38 AM   #23
entropy
entropy's Avatar
RAID generally faster in server applications, or where high sustained transfer rates are req, really depends on the RAID type, controller, and application. For most benching or user applications a fast Raptor or Hitachi would be best.
The best part about RAID is adding redundancy to your data.
To the OP, I can highly recommend the E6600. Getting over 3Ghz should be cake, I don't even have to raise Vcore.
entropy is offline   Reply With Quote
Old 07-16-2007, 10:42 AM   #24
StealthyFish
Send a message via AIM to StealthyFish Send a message via MSN to StealthyFish Send a message via Yahoo to StealthyFish
ouch, i got my 2 kits of tracer for 80 after MIR.
__________________
-----------------Main Setup-----------------
Processor: Intel C2D E4600ES @ 3.4 Ghz
Motherboard: Abit AW9D-Max
Heatsink: Cooler Master GeminII HSF
Graphics Card: eVGA 6800GS 515//1320 (hacked SLI)
RAM: 2x 1Gb GeIL Ultra UDCA= DDR2 800Mhz cas 4
RAM: 2x 1Gb Crucial Tenth Anniversary DDR2 667Mhz cas 3
Hard Drive (Primary): 1 x 200Gb Seagate EIDE
Hard Drive (Secondary): 1 x Seagate 160GB SATA
Hard Drive (Secondary): 1 x Seagate 300Gb SATAII
DVD-RW Drive: 1 x Lite-on CD-RW/DVD-RW
Power Supply: Antec Basiq 500W
StealthyFish is offline   Reply With Quote
Old 07-26-2007, 10:44 PM   #25
cinders
cinders's Avatar
Has this happened yet?...
I really want to get this CPU!
__________________
Desktop:
No PSU (yet)
No Case (yet)
Laptop:
4Gb DDR3 Ram
Reply
Thread Tools
Rate This Thread:
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
XtremeSystems
