Replacing Tuniq Tower Fan
I am getting some components together for a build when the intel cpu prices drop in july and have a couple of questions about replacing the fan supplied with the Tuniq Tower 120.
Would replacing the fan with a 120mm Sharkoon 2000, as proved a good fan in the Vapor's thread, reduce the noise or does the noise mostly come from air rushing between the fins?
Would the pressure from the fan be high enough for this purpose because I can't find any pressure figures?
How does the fan controller attach to the supplied Tuniq Tower fan, would it be easy to swap the fans, because I still want to use the supplied fan controller, or would it require wires being cut and rewired?
Thanks, Anthony
