XtremeSystems Forums
Go Back   XtremeSystems Forums > Cooling > Air Cooling
Reply
Old 06-16-2007, 12:38 PM   #1
IsLNdbOi
Thinnest 120mm Case Fan?
Anyone know if there are any 120mm case fans thinner than 20mm? I need one for my Shuttle PC. I've checked Newegg, MWave, CensusPC, FrozenCPU, Performance-PCs, Directron, etc. and I haven't found anything.
IsLNdbOi is offline   Reply With Quote
Old 06-16-2007, 02:14 PM   #2
filterpunk
filterpunk's Avatar
The only thing I've seen are a couple odd Revoltec and Silenx models that pop up in Google searches. Checking both their sites though, I can't find any info about them at all.
filterpunk is offline   Reply With Quote
Old 06-16-2007, 02:33 PM   #3
cozwin
im sure ive heard of a 15 one but dont know much about it, read down a few pages im sure it came up lately
__________________
Gaming Rig
Intel E6300 (2.33 Ghz) Coolermaster Hyper tx
Asus P5N-E Sli 650i Motherboard
1 Gig Corsair Twin XMS2 (675 4,4,4,12)
Point of View 8800 Gts 320mb (620, 1602 ,920)
Creative Audigy SE
Seagate Barracuda 7200.10 - 320gb, 250gb.
cozwin is offline   Reply With Quote
Old 06-16-2007, 02:34 PM   #4
IsLNdbOi
Yeah, I've already searched SilenX and Revoltec's sites and they don't have any 120mm fans thinner than 25mm.
Old 06-16-2007, 04:27 PM   #5
burton
i think 25 is the smallest nowaday
burton is offline   Reply With Quote
Old 06-16-2007, 04:55 PM   #6
humeyboy
20mm
humeyboy is offline   Reply With Quote
Old 06-16-2007, 06:34 PM   #7
SparkyJJO
Xtremely High Voltage
SparkyJJO's Avatar
Send a message via AIM to SparkyJJO
I don't think they get any thinner. I suppose you could get 4 60mm fans that are 15mm thick and glue them together. Not very efficient though, and probably fairly noisy to get any decent airflow.
__________________
This forum requires that you wait 70 seconds between posts. Please try again in 1 seconds.
SparkyJJO is offline   Reply With Quote
Old 06-17-2007, 12:49 PM   #8
MichelinGuy
MichelinGuy's Avatar
Maybe sanding a fan flatter can do the trick. Sand it untill you are at the rotary.
MichelinGuy is offline   Reply With Quote
Old 06-17-2007, 03:41 PM   #9
bassie
Send a message via ICQ to bassie
That will messup the whole fan. And I don't think it's possible to sand of enough without damaging the fan.
Maybe ask/email shuttle?
bassie is offline   Reply With Quote
Old 06-17-2007, 05:28 PM   #10
IsLNdbOi
It's not something Shuttle would carry. I need this fan for a mod., not to replace something that came with the Shuttle.
Old 06-18-2007, 05:15 AM   #11
C'DaleRider
C'DaleRider's Avatar
I did a quick check around some fan suppliers....Nidec, Yate Loon, GlobalWin, Scythe among others.....thinnest I could find was a 20mm. Maybe someone else will have better luck. Sorry.
__________________
Papa: Q6600 @ 3.6GHz @ 1.34V, Asus Maximus Formula, 4 x 2GB Mushkin Redline DDR2-1000, Asus HD4870, Antec Sig. 850, Lian-Li/RF case....WC'd via D-Tek FuZion w/quad nozzle, EK S-Max on NB, Laing DDC2 w/XSPC top, 2 x Feser 240's & one TC 120.1 rads.
Momma: Xeon 3210 @ 2.8GHz, Gigabyte P965-DS3, 4 x 1GB Ballistix DDR2-800, Asus HD3870 TOP, Enhance ENP5150-GH, Lian-Li/RF case, HK Champagne 2.1, Xigmatek HDT cooler
C'DaleRider is offline   Reply With Quote
Old 06-19-2007, 04:38 AM   #12
Concept 5000-FX
Concept 5000-FX's Avatar
Send a message via ICQ to Concept 5000-FX Send a message via MSN to Concept 5000-FX
http://www.selwyn.co.uk/Computer+Har...40mm/17mm+Fans
__________________
CPU: Intel Core 2 Due E6600 @ 3.6GHz (24\7)|| HS: Scyth Ninja Plus + 120mm Thunderblade
MB: Asus P5W DH Deluxe|| Memory: G.Skill 4096MB 800MHz 5-5-5-15
GFX: BFG GeForce 9800GTX OCX 512MB 256MB|| HD: Western Digital 500GB SataII
Power Suplly: Enermax Liberty 400Watt|| Case: HEC Compucase 6920
Fans: Thermaltake Thunderblade 120mm Blue LED|| Monitor: Proview 22" FP226AFW
Concept 5000-FX is offline   Reply With Quote
Old 06-19-2007, 05:31 AM   #13
MichelinGuy
Originally Posted by Concept 5000-FX View Post
The thinnest 120mm fan not the smallest fan there is
Reply
Thread Tools
Rate This Thread:
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
XtremeSystems
