XtremeSystems Forums
Reply
Old 06-08-2007, 06:15 PM   #1
Dateranoth
Looking to upgrade my WC for future SLI. Need help.
I am going to start upgrading my entire system bit by bit, and I would like some input on the parts.
These components will be cooled by the loop: intel c2d 6400 (currently OC to 3.2ghz running around 68C load at 25C ambient) and an 8800GTX ( OC to 655mhz core and 2000mhz mem running at 55C load at 25C ambient). The system would need to be capable of handling another 8800GTX without losing any current OC ability, and if possible the upgrade to quad core. My current system is not capable of this.
I have come up with this parts list. I'm not sure if they are the best for what I am after or not, or if it is possible in a single loop. I'm relatively new to WC. I have a kit installed currently, with the only decent part in it the MCW60 I bought just recently for my GPU. So, my list will also include minor parts such as tubing, just in case someone sees something they think will perform better.
CPU Block: Swiftech Apogee™ GTX CPU Waterblock
Pump: Laing DDC w/ Petra'sTech DDCT-01s Top Combo (18W)
Radiator: Swiftech MCR-320 "Quiet Power" Series Radiator - Black
or
Thermochill PA120.3 Radiator
( I don't know enough about the difference. Is the PA120 worth the extra 70? )
Reservoir: ( This I do not know enough about. I assume it needs to be sized according to my radiator, but I don't have any clue to that so any suggestion would be greatly appreciated. )
Fans: 3x 120mm Yate Loon D12SL-12 (47cfm, 28dba) ( will these provide enough airflow for the rads? )
Bits and Pieces:
Petra'sTech "PT Nuke" (necessary?)
Petra'sTech "Gel-Stuff" Vibration Absorption Block ( is this necessary with the selected pump?)
120mm Sound Vibration Dampener (are these recommended for the fans?)
1/2" ID (3/4" OD) Tygon R-3603 Laboratory-Grade Tubing ( is this my best choice in size?)
5.25" Sunbeam Rheobus Fan Speed Controller - Silver ( I want a fan controller, but I was also wondering if there was such a thing as a flow sensor? I mean something that can shut down the cpu if the pump doesn't run. I had some issues with my pump not working, and it kinda worried me )
Ceramique - 22 gram tube
Worm Drive Hose clamps
Current System:
evga 680i SLI
evga 8800GTX @ 655/2000
C2D E6400 @ 3.2Ghz
4gb corsair cas4 @ 800mhz
Water cooling setup would need to be able to cool:
2x evga 8800GTX @ 655/2000
C2D E6400 @ 3.2Ghz OR possibly a quad core at some rate of overclock.
Also, any new info on the D-Tek GFX UNI-Sink (8800GTX) would be greatly appreciated, as I am now considering it after the nightmare I went through to install the individual ramsinks on the 8800.
Finally, I will probably be upgrading these parts a few at a time. So upgrade order would be useful. I was thinking: CPU block, radiator, pump/res. Though, I may just bite the bullet and upgrade it all at the same time.
Thanks in advanced for any help you can swing my way.
Dateranoth
P.S.
I'm pretty sure my current cpu block is crap, since I installed the MCW60 into the loop on the GPU, its temps dropped 30C while my CPU temps only rose like 2C, but 54idle and 68load seem pretty high for water.
D
Dateranoth is offline   Reply With Quote
Old 06-08-2007, 06:56 PM   #2
HiJon89
HiJon89's Avatar
Send a message via AIM to HiJon89
If you're looking to cool an OC'ed Core 2 Duo and an 8800GTX (possibly SLI in the future) then I'd say it's definitely worth it for you to invest in the PA120.3. In your case it is worth the extra money. You may want to consider getting a DTek FuZion instead of the Apogee GTX because the FuZion is much less restrictive, and in a loop that might have 3 blocks someday powered by a single DDC2, you're going to want all the flow you can get. So I'd either suggest getting the FuZion, or adding a second DDC2 if you do SLI some day. (The FuZion is obviously the cheaper of the two options).
Fans look good. Tubing looks good. Petra's Gel Stuff looks good. The PT Nuke or some alternative is required, especially if you get the Apogee GTX then you'll be running a mixed-metal loop. Pentosin or Zerex are the classic favorites. Vibration dampeners usually don't do very much, but they're cheap and if they make you feel better go for it (I use them )
__________________
File Server:
2x Opteron 254
4GB PC3200
RocketRaid 3520
300GB Velociraptor
7x 750GB RAID5
HD 3870 Toxic
Hauppauge PVR-500
Zippy 600W
3DMark05: 12308
3DMark03: 25820
3DMark2001: 35632
HiJon89 is offline   Reply With Quote
Old 06-08-2007, 06:58 PM   #3
whoodiestyle
well i think if u plan for quad core and 2 8800gtxs i dont think the pa 120.3 could handle it
__________________
whoodiestyle is offline   Reply With Quote
Old 06-08-2007, 08:52 PM   #4
Dateranoth
So, is there any radiator that can? On a single loop setup that is. I would go dual loop, but I really don't have the room in my case for all that.
Also, any suggestions on a reservoir?
Dateranoth
Old 06-08-2007, 09:49 PM   #5
HiJon89
HiJon89's Avatar
Dateranoth
The PA120.3 won't have a problem handing an overclocked quadcore and 8800GTX SLI, but you may want to step up the fans to the ~70cfm range.
I've never used a reservoir in any of my builds, but the Swiftech MCRES-Micro seems to be very popular around here.
__________________
File Server:
2x Opteron 254
4GB PC3200
RocketRaid 3520
300GB Velociraptor
7x 750GB RAID5
HD 3870 Toxic
Hauppauge PVR-500
Zippy 600W
3DMark05: 12308
3DMark03: 25820
3DMark2001: 35632
Old 06-09-2007, 04:15 AM   #6
dnb#
dnb#'s Avatar
Send a message via ICQ to dnb#
a 120.3 rad, swiftech stealths, Swiftech MCP655, 1/2 or 3/8, swiftech gtx ?
huge amount of money but it's well spend
don't you think these stealths are pretty sweet?
__________________
The multiple screen Wallpaper topic!: http://www.xtremesystems.org/forums/...d.php?t=190723
The System wallpaper topic!: http://www.xtremesystems.org/forums/...d.php?t=180050
dnb# is offline   Reply With Quote
Old 06-09-2007, 04:32 AM   #7
elfy
elfy's Avatar
i thought the Petra'sTech "Gel-Stuff" Vibration Absorption Block wasn't recommended for use with DDCs?
elfy is offline   Reply With Quote
Old 06-09-2007, 06:03 AM   #8
Grinch
Xtreme Cruncher
Grinch's Avatar
I am using it under both my pumps with no problems at all...
__________________
750W Thermaltake Modular PSU
DFI UT X58-T3eH8
Core i7 920 @ 20 X 200 1.325V
CORSAIR XMS3 DHX 4GB (2 x 2GB) DDR3 1600
768 MB EVGA 8800GTX
1 X 36GB WD Raptor
2 X 150GB WD RAPTORS
1 X SpinPoint P Series SP2504C 250GB
1 X Maxtor 6L300S0 300GB
16 X NEC DVD Burner
7 120mm Yate Loon LED Intake Fan
4 120MM Yate Loon Exhaust Fan
28" HANNSPREE Monitor
Watercooling Loop:
1 X PA120.3
1 X PA120.2
2 X Laing DDC's w/EK-DDC Dual Turbo Top
7 X Yate Loon Blue LED Intake Fans
4 X Yate Loon Blue LED Exhaust Fans
1 X Swiftech GTZ
1 X GPU EK Fullcover Waterblock
1 X XSPC Dual Bay Reservoir 5.25" with Bubble Window
Grinch is offline   Reply With Quote
Old 06-09-2007, 08:13 AM   #9
sonofander
sonofander's Avatar
In my experience, a PA120.3 is not enought to handle a quad core and 2 8800gtxs. When I made the upgrade to Sli my temps got out of control and I HAD to add a second loop.
If you plan on an OC'd quad and Sli, it is time to start considering what it would take to fit 2 loops in your case.
__________________
Workstation
i7 920 @ 4.3 / Asus RIIE / 6gb Corsair 1600c8 / HD5870 CF
3x Vertex raid 0 / WD 1TB Black / Thermaltake 1200w
3x Dell 30" Eyefinity / Tri-loop WC MM UFO
Server
i7 920 / Gigabyte EX58-UD4P / 6gb Corsair 1600c9 / GTS 250
300gb Vrap (OS) / 12x WD 2tb (DATA)
2x Areca 1230 / Norco 4020 / Corsair 1000HX
sonofander is offline   Reply With Quote
Old 06-09-2007, 08:18 AM   #10
IanY
I am Xtreme
PA120.3 handles an overclocked quad core, and that's about it
With G80 SLI? Forget about it..
IanY is offline   Reply With Quote
Old 06-09-2007, 09:02 AM   #11
Dateranoth
Well, at the very least. The setup I listed should handle C2D and G80 SLI right? I mean, after I spend almost 500 on the WC setup, I believe the quad will have to wait a bit. Haha, don't even have the second gpu yet. My biggest concern is that it's a step in the right direction. ie, everything listed will be a long lasting performer and be usable if I have to add a second loop in the future.
Also, which is the better ( and preferrably logest lasting ) pump? The DDC-2 or MCP655?
thanks,
Dateranoth
Old 06-09-2007, 09:25 AM   #12
elfy
elfy's Avatar
cool
Old 06-09-2007, 09:38 AM   #13
IanY
I am Xtreme
thanks,
Dateranoth
You are good for now
Both pumps are of about the same quality.
Old 06-09-2007, 10:25 AM   #14
Dateranoth
Well, thanks for all the help everyone. I believe my final purchase will be these parts:
Thermochill PA120.3
D-tek FuZion CPU Water Block
Swiftech MCP655 12VDC Pump
YATE LOON 120mm D12SH-12 High Speed
Swiftech 1/2" OD tubing
Tubing Clamps
Coolant Additive
ARCTIC SILVER ARCTICLEAN
Arctic TIM lineup
Thanks again,
Dateranoth
Reply
Thread Tools
Rate This Thread:
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
XtremeSystems
