XtremeSystems Forums
Go Back   XtremeSystems Forums > Cooling > Air Cooling
Reply
Old 06-04-2007, 11:44 AM   #1
silverphoenix
silverphoenix's Avatar
Send a message via AIM to silverphoenix
Show your PWM cooling
If you don't have stock PWM cooling show it here. From air to water to whatever. I need ideas even DIY. I need to cool my quad GT's pwm without hacking the stock one. I found only one place that sells waterblocks but it will cost me close to 85-90 USD to get it to me. So Post away!!
silverphoenix is offline   Reply With Quote
Old 06-07-2007, 04:47 AM   #2
celemine1Gig
IT Engineer in the making
celemine1Gig's Avatar
Send a message via ICQ to celemine1Gig
Doesn't look too pretty , but it works.
http://www.fh-augsburg.de/~madocer/B...D955XBK016.jpg
__________________
celemine1Gig is offline   Reply With Quote
Old 06-07-2007, 05:05 AM   #3
Origin_Unknown
Xtreme Cruncher
Origin_Unknown's Avatar
wow, that looks ghetto.... what was the original heatink that was used?
__________________
E8500 - G.Skill F2-8000CL5D-4GBPQ 4*2GB PC 8000 - DFI LT X38 T2R
Palit 8800GTS 640Mb - Lian-Li A71 w/ 6 * Noctua NF-P12 - Corsair TX750
Thermalright Ultra Extreme - HR03 - HR05 IFX *2
We'll Keep the Red Flag flying high - Because Man United will never die
Origin_Unknown is offline   Reply With Quote
Old 06-07-2007, 07:05 AM   #4
xenoasd
xenoasd's Avatar
wow pointy. indeed doesnt look pretty lol
__________________
E6600 - 3.6Ghz @ 1.4V
Thermalright Ultra-120 Extreme + S-FLEX SFF21F 120mm Fan
Asus P5B-Deluxe WiFi-AP
Crucial Ballistix DDR2-1000 2GB
eVGA 8800GTS SuperClocked 320MB 650/1900
Creative X-Fi XtremeMusic
Corsair HX520W
Antec 900 Case
3DMark06 - 13,078
xenoasd is offline   Reply With Quote
Old 06-07-2007, 09:52 AM   #5
celemine1Gig
The original board (Intel D955XBK) doesn't use any additional PWM cooling.
Fact is: My solution might not look too shiny, tidy and what not, but it outperforms any of those premade solutions.
Points that most people forget when it comes to PWM cooling:
1.) The Mosfets are normally designed to dissipate the heat into the PCB they're soldered onto, and not into heatsinks that are placed on the plastic package. The heatsinks will help, but not as much as some poeple think they do.
2.) You'll never get close to perfect contact when you try to use one heatsink for more than one FET.
3.) If the PWM designs would be better, we wouldn't need that much PWM cooling in the first place. IMHO, if you'd design a good power regulation circuit that would cost more, you could safe some money on the extreme heatsinks that some companies use ATM (new MSI boards for example with the extreme heatpipe designs). But that's just my 2 cents.
__________________
Old 06-07-2007, 10:01 AM   #6
silverphoenix
Did you use ceramique adhesive? I would like the option of putting the stock cooling back on. I would like to have individual ones but then I can't clamp them down and probably have to use adhesive.
I have a spare package of thermaltake copper bga sinks but they are quite puny.
Old 06-07-2007, 10:39 AM   #7
Der_KHAN
Xtreme 3DTeam Member
Der_KHAN's Avatar
i think the stock heatsink on the quad gt should be enough if u replace the thermal pad with some ceramique
__________________
24/7 stable:.
Core 2 Duo E6600 L630A767.. 3.8GHz 1.44V water
Abit AB9 Quad GT. . . . . . . ... Bios 16B, 423x9 VTT1.4 mch1.55
2x2048MB GSKILL PC-8000... 529MHz 5-5-5-15-Auto 2T 2.1V (F2-8000CL5D-4GBPQ)
Gigabyte GTX 280 1GB. . . . .. 700/1500/1250 stock volts, water
MSI 8400GS 512MB. . . . . . .. stock, passive
19" + 22" + 19" Screens. . . . SoftTH 1.09RC1, Multihead=0, CUDA 2.3 for Win7 x64
Logitech G25. . . . . . . . . . . ..Heusinkveld PAD, Momo Team 11.8", Klenn Wheel Adapter
X-45, TIR3p+6dof
3DMark 01: 39205 | 03: 20425 | 05: 20032 | 06: 12164
Der_KHAN is offline   Reply With Quote
Old 06-07-2007, 10:44 AM   #8
Nosfer@tu
OCTeamDenmark Staff
Nosfer@tu's Avatar
Send a message via MSN to Nosfer@tu
You MODDED THE OUT THAT BOARD
__________________
OCTeamDenmark.com Staff
Cooled and sponsored by Coolerkit.dk
Gigabyte EP45 Extreme | QX9770
2x1 Gb G.skill DDR3 PC3-16000
2xFoxconn 3870, Vcore,Vmem,OCP,Cap mods.
22" Samsung 225BW | Antec 1000 Watt
Mach 2 GT (moddet by t!m) | MX510 - Func F10s
Nosfer@tu is offline   Reply With Quote
Old 06-07-2007, 10:49 AM   #9
silverphoenix
it is but it's also connected via heatpipe to the NB heatsink, which is being replaced with an MCW30, I don't want to cut the heatpipe and void warranty. I have an old socket A glacialtech hsf I can try to modify. Do you guys think the TT BGA ramsinks are enough? I've read posts about how even the swiftech BGA sinks aren't enough.
Old 06-07-2007, 01:17 PM   #10
celemine1Gig
I used my own thermal adhesive. You just have to mix two component epoxy 1:1 with thermal paste (not any, is appropriate!). There's nothing wrong with using the stock cooling, as long as the temps are OK. I modded my D955XBK as seen in the pics, because the PWM got really hot without cooling. And I don't like the fact that the PWM heats up all the other components.
Those BGA heatsinks look too small, and copper isn't really the best chioce for this application. Those tiny copper sinks would heat up horribly fast and without active ventilation they'd probably worsen the cooling situation, instead of improving it.
I'd advise you to not use these little sinks.
Yeah, you could probably say that. Didn't want to brag about it. Especially because I didn't really have the time to test the boards potential, yet.
BTW, this is a Intel Engineering Sample board. Intel 955x ES and ICH7R with "SECRET" printed onto it.
Hope to finally get a Conroe/Allendale soon, to really be able to test the board. Did I say "option to choose 400MHz default FSB"?
__________________
Old 06-07-2007, 01:27 PM   #11
silverphoenix
Like I said before I don't want to permanently attach them. The TT ramsinks do have thermal tape on them, and there will be a fan sitting right on top of them. I will try to mod the old alu socket A hsf.
Old 06-07-2007, 01:40 PM   #12
Stocky
Stocky's Avatar
This is what I bodged together for my QuadGT a little while back:
It doesn't look too bad, but the PWMs still get extremely toasty!
OT: Does anyone else hear clicking sounds (a bit more squeaky than a HD)from that area of the mobo?
__________________
Stocky is offline   Reply With Quote
Old 06-07-2007, 02:36 PM   #13
silverphoenix
what is that?
Old 06-07-2007, 02:39 PM   #14
celemine1Gig
And like I said, there's nothing wrong with using the stock PWM cooling, which also means using the stock mounting, which I assumed to be some kinda bolts and springs and thermal paste between the fets and the heatsinks. All assuming that the temps are at an OK level.
[/IMG]http://www.killsound.com/forum/PWM%20Mod.jpg[/IMG]
Did you ever check the fets temps before and after the mod? As I wrote above: Using full copper heatsinks for this application is kinda bad in most cases.
__________________
Old 06-07-2007, 02:49 PM   #15
silverphoenix
I can't use stock fet cooling, it is physically soldered to a heatpipe to the NB, which get's wayy to hot when I'm overclocking. So I need something to replace the stock setup.
I'm gonna actually try something, if it works I'll show you guys hehe.
Old 06-07-2007, 06:30 PM   #16
Navig
Navig's Avatar
Here's my HR-09 on an IN9 (start post#47). This is a bit of a special case--the PWM chips are extremely fragile.
Otherwise, I'd recommend, as above, cutting up a standard heatsink, and applying a single heatsink per mosfet.
Navig is offline   Reply With Quote
Old 06-08-2007, 12:16 AM   #17
jarman
I like that Navig
jarman is offline   Reply With Quote
Reply
Thread Tools
Rate This Thread:
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
XtremeSystems
