06-03-2007, 11:13 PM
#1
Apogee GT mounting v BX2
So it seems that you cannot mount the Apogee GT vertically (with one barb beneath the other) because of the blue ramsinks that get in the way.
The only solution would be either to remove the ramsinks or rotate the block so the barbs are on the left/right of eachother.
Is there any noticeable decrease in performance, rotating the block?
Thanks.
EDIT: Cancel that, I can't seem to get the apogee GT to go on at all, vertically or horizontally without it touching the blue heatsinks.
Anybody else have this problem? What did you do to remedy it?
EDIT 2: Jumped the gun a bit. It fits horizontally... only barely. The mounting bracket is pushing quite hard against one of the ramsinks, but it does fit, and that is comforting.
__________________
"Language cuts the grooves in which our thoughts must move" | Frank Herbert, The Santaroga Barrier
i7 920 3924A 205x21 / 4315 | 4870x2 | EVGA M-ATX X58 | 6GB Corsair Dominator | Corsair HX1000 | Intel X25-M 160 G2 | OCZ Vertex 60 | WD 320 || Apogee XT - XSPC FC | (2)DDC3.2 | (2)PA 120.2 | (2)BI SR-1 120 || MM H2G0
06-03-2007, 11:14 PM
#2
...you two characters
Thanks.
blue ramsinks from what?
__________________
Team.AU
Got tube?
Originally Posted by Gautam
In the old days, LN2 benching was "cheating". Then LOD was "cheating". And so on and so forth...
06-03-2007, 11:16 PM
#3
Xtreme Cruncher
Huh? What ramsinks????
__________________
e6400
gigabyte ds2r
7600gs 256mb
crappy ram you don't want to know about
crappy hard drive you don't want to know about
crappy case you don't want to blah blah blah
Homemade watercooling  mounted with zipties for the most part
06-03-2007, 11:18 PM
#4
Xtreme Supporter
It's the mosfet heatsinks. One of my boards mounted fine vertically, but the other two needed a little Dremmel action with a sanding drum.
__________________
BERT: Intel DX48BT2, E8500, 2x 1G OCZ Plat DDR3-1800, 2xATI HD 3850, 450x9.5
ERNIE: Intel DX38BT, Q9300, 2x 1G OCZ Plat DDR3-1800, ATI HD 3650, 400x7.5
RALPH,ELMO,MONSTER: Intel 975XBX2, Q6600, 2x 1G OCZ DDR2-1066, 356x9
COOKIE,OSCAR: DFI BloodIron, Q6600, 2x 1G OCZ DDR2-1066, stock
GTJ's Intel 975XBX2 Bad Axe 2 Guide including the Memory Calculator
GTJ's Intel DX38BT/DX48BT2 Bone Trail Memory Calculator
06-03-2007, 11:25 PM
#5
I've got it mounted fine horizontally now. The Apogee didn't want to go vertically and I don't have my dremel with me.
Does anybody know if horizontally mounting the block suffers a performance decrease?
__________________
06-03-2007, 11:43 PM
#6
Incorrect orientation of the waterblock will result in a 2-3C gain. I lost 2C when I corrected my mount. You want the Swiftech logo to be upright (as in readable) instead of sideways.
__________________
MM Extended U2-UFO CYO (Duality front, Standard back, Horizontal Mobo brace) Anodized Black || eVGA X58 || Intel i7 920 || 6 GB Corsair Dominator PC3-12800|| eVGA 295GTX || Asus Xonar Essence STX || VisionTek 650 TV Tuner || 1 300GB WD Velociraptor || 1TB WD's Black Ed. || LG 22X DVD-Writer || Lite-On 20x DVD-Writer || Corsair CMPSU-1000HX PSU
CPU Loop: DDC-2 w/ XSPC Reservoir Top -> Swiftech GTZ -> Thermochill PA120.3 (Push: 3 Scythe S-Flex G)
GPU Loop: DDC-2 w/ XSPC Reservoir Top -> (Koolance VID-NX295 FC block) ->Thermochill PA120.3 (Push: 3 Scythe S-Flex G)
Chipset Loop: DDC-2 w/ XSPC Reservoir Top -> Alphacool Silentstar Dual HD waterblock enclosure -> Bitspower Black Freezer eVGA x58 MOSFET-> Bitspower Black Freezer eVGA x58 NB -> Thermochill PA120.2 (Pull: 2 Scythe S-Flex G)
2 x Dell 2408FPW LCD || Logitech Z-5500 Digital 5.1 || Logitech G9 Mouse || Logitech G15 LCD Keyboard || Logitech Quickcam Ultravision || Sennheiser Headphones
06-04-2007, 12:05 AM
#7
Drat. Oh well, I don't have the tools to sand down the mofset sinks with me, and I am too impatient to wait until tomorrow. I will see how this mount goes.
__________________
06-04-2007, 12:47 AM
#8
2 degrees can be gained simply by having a better mount. I've gained as much as 5 degrees before simply remounting my block.
I presume you only swapped the orientations once and therefore, your temp decrease could very well be a product of better mount / thermal paste distribution.
Are there any HARD results out there showing this?
__________________
06-04-2007, 06:45 AM
#9
why would a horizontal vs vertical orientation make any difference
I have always had my storm rev2 in horizontal oreintation
__________________
My Heat
L629F221 e6600 @3600 1.4v D-Tek Fuzion
Badaxe2 bios 2747 rev 505 1.3v vFSB/1.575v MCH
2 x 2GB Corsair XMS@DDR 800 5-5-5-5-18@1.85
x1900xt MCW60
Rad: PA120.3 3YL SL/ Pump: DDC2 w/ Petra's top 7/16in ID masterkleer
Seagate 320gb 7200.10/ 200gb 7200.8 SATA
X-Fi music/SH-203B/H62L/LH-20A1L
Corsair HX620w /Acer AL2223W/modded TJ07
06-04-2007, 07:22 PM
#10
That's quite true. Gabe provided his input on another topic that the correct orientation for the GT would result in a 2-3C temp drop.
__________________
| Thread Tools |
| Display Modes |
Rate This Thread |
Linear Mode
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
HTML code is Off
